More 727 questions oil feed holes #613258
02/14/10 01:33 PM
02/14/10 01:33 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
What size should I Drill this feed hole out to ?
Re: More 727 questions oil feed holes [Re: VernMotor] #613259
02/14/10 02:14 PM
02/14/10 02:14 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
What's the reasonig behind enlarging it?
Re: More 727 questions oil feed holes [Re: WILD BILL] #613260
02/14/10 02:45 PM
02/14/10 02:45 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
don't know on that hole but make sure you blend the hole into the outer groove. any question's come see me.
Re: More 727 questions oil feed holes [Re: dartman366] #613261
02/14/10 03:00 PM
02/14/10 03:00 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I beleve you are talking about this.
That is not the hole I am showing. The pic I have up is one thats been drilled already.It is one of John K pics.The hole I am showing is from the pump to feed/lube the the front clutchs. I think ..
Re: More 727 questions oil feed holes [Re: VernMotor] #613262
02/14/10 03:45 PM
02/14/10 03:45 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
yes I am.
Re: More 727 questions oil feed holes [Re: VernMotor] #613263
02/14/10 04:05 PM
02/14/10 04:05 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
The hole sprays oil on the front clutches. B&M Trans Kit instructions say to open hole to 3/32" ~ 0.090". Original hole size is 0.060" or less. The later model 727s do not have this hole, and the clutches get lube thru a different circuit.
John
Re: More 727 questions oil feed holes [Re: DusterW2] #613264
02/14/10 04:10 PM
02/14/10 04:10 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Thank you again !
Re: More 727 questions oil feed holes [Re: VernMotor] #613265
02/14/10 04:23 PM
02/14/10 04:23 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
This feed hole will supply lube oil to the front clutch bushing. I wouldn't enlarge it. To much oil in the front clutch area will just make it more difficult for the clutches to squeeze it out during apply.
FWIW, I've been starting to add this feed hole on my later pumps that don't have it for more direct/beter bushing lube oil.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: More 727 questions oil feed holes [Re: turbobitt] #613266
02/14/10 05:49 PM
02/14/10 05:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nearly everybody in the business enlarges that hole, some go as large as 1/8" which is the size in the pic in the OP.
The clearance between the discs dictates how much fluid will have to be squeezed out on application, the idea is to increase to volume of the flow through the discs for cooling.
Re: More 727 questions oil feed holes [Re: John_Kunkel] #613267
02/14/10 09:44 PM
02/14/10 09:44 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
So do we blindly follow the masses and just do it without understanding the reasoning ? Is it needed ? Do we have any data to support this modification ?
Clutch material and groove vs. no groove among other things will also impact this.
Not trying to be a PITA or wise a$$ but I've seen to many modifications done simply because the other guy has done them. Would be very interested in any real world data to support this modification.
Allan G.
Re: More 727 questions oil feed holes [Re: VernMotor] #613268
02/15/10 11:28 AM
02/15/10 11:28 AM
NC
440Jim Offline
440Jim  Offline
NC
I like this mod to lube the sprag and associated parts. 1/16" dia hole added.
Re: More 727 questions oil feed holes [Re: 440Jim] #613269
02/15/10 11:30 AM
02/15/10 11:30 AM
NC
440Jim Offline
440Jim  Offline
NC
And here are some reference dimensions to help locate the lube hole.
Re: More 727 questions oil feed holes [Re: 440Jim] #613270
02/15/10 11:44 AM
02/15/10 11:44 AM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Yes I aready got that done Jim Thanks
Re: More 727 questions oil feed holes [Re: turbobitt] #613271
02/15/10 03:16 PM
02/15/10 03:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
How many of the mods that you perform are fairly standard?
As to the reasoning think about this, in 1st gear the front cluth drum turns 80% of input shaft speed but in the opposite direction; so the surface speed of the discs is 180% of input shaft speed; lots of drag there. The extra volume of fluid helps keep the surfaces well lubricated and helps cooling especially at the higher rpm's that race cars turn.
Maybe so but the fact remains that fluids don't compress, so the actual volume of fluid that is present between the discs is the same no matter how much extra volume passes between them and that extra volume that needs to be "squeezed out" seems to be your original arguing point.
Re: More 727 questions oil feed holes [Re: John_Kunkel] #613272
02/15/10 03:45 PM
02/15/10 03:45 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
So if there is already a full volume of fluid in this area , then why make this hole bigger ? Again, looking for some hard data.
My interest is from the fact that I have had issues witht he direct drum bushing getting worn or producing fine material in the oil. I have had this issue on a few of my own transmissions with the common thing being that they both have extra clutches and therfore may have increased the mass of the drum assembly. I have added this hole to my later style pumps to see if it will help in delivering lube oil to this area. I have not inspected it since I done this modification so I have no data to share but at least I'm attempting to back it up with an A/B testing.
In this case with a transmission with the hole already there I would argue that if it was OK from the factory then why increase it ? If you have any data(not aome elaborate theory)to share then please post it as I'm looking to learn.
Most, if not all the modifications I've done are based on my own testing, or at least from trial and error. Have I used shift kits before and done there modifications ? of course.. BUT I take the time to understand the efects of those modifications. I'm not claiming to invent anything or be on the cutting edge of anything but would like to have a full understanding of any particular modification. I've spent many hours on my valve bodies, as well as my TH400 stuff trying to understand and map out the fluid flow and its effects.
Allan G.
Re: More 727 questions oil feed holes [Re: turbobitt] #613273
02/15/10 09:06 PM
02/15/10 09:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
How do you know that the factory size hole supplies "full volume" in a performance situation. Got hard data?
How do you "test", got a dyno?
Why do you question this mod? What's the possible downside of enlarging the hole?
Re: More 727 questions oil feed holes [Re: VernMotor] #613274
02/15/10 09:14 PM
02/15/10 09:14 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
WAXER
Re: More 727 questions oil feed holes [Re: QWK_ENUF] #613275
02/15/10 09:25 PM
02/15/10 09:25 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
anybody see this post
https://board.moparts.org/ubbthreads/show...e=0#Post5795766
I agree, this is the kind of post we can all learn from, so let's not let it die an early death, sometime's the way thing's are written can be taken the wrong way, when in reality it may of not been intended that way.
I used to have problem's with 904's not holding up,,I tried a lot of these mod's and now I have some pretty good success with them after reading the thing's that John Kunkle, John Cope, and 440Jim have written and applied to my home built tranny's
Re: More 727 questions oil feed holes [Re: dartman366] #613276
02/15/10 09:51 PM
02/15/10 09:51 PM
NC
440Jim Offline
440Jim  Offline
NC
FWIW, (take it or leave it),
I learned a lot from John Kunkel and John Russo (DusterW2). But I always read and make my own decisions. He is usually right...
I like the added fluid to cool the front (direct) clutch disks in my race car. I also believe this mod helps increase the flow.
Re: More 727 questions oil feed holes [Re: 440Jim] #613277
02/15/10 10:01 PM
02/15/10 10:01 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
And fluid to them holes would come from the hole I am talking about drilling so you have all them holes and space to fill with a .060 hole. this deal is almost like splash oiling. Am I thinking about this right ?
