Re: More 727 questions oil feed holes
[Re: VernMotor]
#613259
02/14/10 02:14 PM
02/14/10 02:14 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
What's the reasonig behind enlarging it?
[Re: VernMotor]
#613265
02/14/10 04:23 PM
02/14/10 04:23 PM
Posts: 761 Southington Ct.
turbobitt
Southington Ct.
This feed hole will supply lube oil to the front clutch bushing. I wouldn't enlarge it. To much oil in the front clutch area will just make it more difficult for the clutches to squeeze it out during apply. FWIW, I've been starting to add this feed hole on my later pumps that don't have it for more direct/beter bushing lube oil. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#613266
02/14/10 05:49 PM
02/14/10 05:49 PM
Posts: 25,969 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Nearly everybody in the business enlarges that hole, some go as large as 1/8" which is the size in the pic in the OP.
The clearance between the discs dictates how much fluid will have to be squeezed out on application, the idea is to increase to volume of the flow through the discs for cooling.
[Re: turbobitt]
#613273
02/15/10 09:06 PM
02/15/10 09:06 PM
John_Kunkel
Rio Linda, CA
So if there is already a full volume of fluid in this area , then why make this hole bigger ? Again, looking for some hard data.
How do you know that the factory size hole supplies "full volume" in a performance situation. Got hard data?
Most, if not all the modifications I've done are based on my own testing, or at least from trial and error.
How do you "test", got a dyno?
Why do you question this mod? What's the possible downside of enlarging the hole?
[Re: QWK_ENUF]
#613275
02/15/10 09:25 PM
02/15/10 09:25 PM
dartman366
Mt. Vernon, Ohio
anybody see this post ![](/ubbthreads/images/graemlins/whistling.gif)
https://board.moparts.org/ubbthreads/show...e=0#Post5795766
I agree, this is the kind of post we can all learn from, so let's not let it die an early death, sometime's the way thing's are written can be taken the wrong way, when in reality it may of not been intended that way. ![](/ubbthreads/images/graemlins/Twocents.gif)
I used to have problem's with 904's not holding up,,I tried a lot of these mod's and now I have some pretty good success with them after reading the thing's that John Kunkle, John Cope, and 440Jim have written and applied to my home built tranny's ![](/ubbthreads/images/graemlins/thumbs.gif)
