Re: Double flare tubing tool
[Re: Moneypit6]
#605755
02/06/10 12:14 PM
02/06/10 12:14 PM
Posts: 1,290 New Kent, Va.
bobbyb
New Kent, Va.
I had the same problem with one I bought from Sears. It was suppose to do double flares but the clamp on the tool wouldn't hold the tubing in position while flaring. I could use some tips also or a GOOD tool that actually works right.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
[Re: jcc]
#605765
02/06/10 12:58 PM
02/06/10 12:58 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
After years of frustration with the $50? Summit type tools, I dropped a few hundred on the real hydraulic double flare tools, and glad I did.
I was temped on one of them, sure look like a nice way to go.
On the tool topic, I just bought an A/C hose crimper, sure works nice ![](/ubbthreads/images/graemlins/grin.gif)
[Re: Moneypit6]
#605766
02/06/10 12:59 PM
02/06/10 12:59 PM
Challenger 1
Cincinnati, Ohio
" Does that make sense?"
It certainly does, but in this case the clamps are both bottomed. It has a slight bulge in the area of the tube because it's flexing. I C-clamped on each side to complete the squeeze but this stuff is stubborn. I can mill more off of the clamp but was just wondering if there was a good trick without squeezing the *ell out of the tube and making it look smaller after the install. I'm beginning to think I have to size it so that it actually pinches the tube down a little and makes it's own shoulder.
Try what I said first on a fresh peice of tube. You don't want the tube colasped where you gripe it either. It it's leaving a crimp mark, then it will work without any milling.
[Re: RapidRobert]
#605767
02/06/10 01:00 PM
02/06/10 01:00 PM
OzHemi
Garden Grove, CA
But don't forget that the dimple in the holder has to be the right angle too
thanks OZ . Holy Moses I forgot about the angle on the other side would have to match also . Sounds like I better just pony up & get a Summitt (they're cheap)(now I know why) assuming that the ends can be filed so it will clamp down tight
Maybe moneypit will give you a deal on a slighty used one ![](/ubbthreads/images/graemlins/drumhit.gif)
[Re: 62maxwgn]
#605770
02/06/10 01:26 PM
02/06/10 01:26 PM
OzHemi
Garden Grove, CA
If you are going to any amount of double flaring,go to a refrigeration parts supplier and buy a Imperial-Eastman.It's tube holder (attached) won't slip no matter what size tube.It's still USA made and will last forever.In tools,you get what you pay for. :twocents
Nice looking tool! ![](/ubbthreads/images/graemlins/thumbs.gif)
And I agree....that A/C crimper I just got is a good quality tool, and just makes the job go smooth and easy...I bought my flare tools a little bit ago, and wasn't aware of that style, sure looks good.
