Page 1 of 3 1 2 3
Double flare tubing tool #605754
02/06/10 11:48 AM
02/06/10 11:48 AM
California
Moneypit6 Offline OP
California
I bought a tool from Summit to do some 3/8" steel fuel line with. I cut some practice pieces to learn on. I'm having a big problem with the tubing just slipping through the holder. That's with the holder fully tightened with C clamps on each side of the press. Is there a trick to keeping the tubing from pushing through the holder! Not sure what else I can do.
Any help here would be appreciated.
70 Roadrunner almost ready to come off the rotisserie smile
Re: Double flare tubing tool [Re: Moneypit6] #605755
02/06/10 12:14 PM
02/06/10 12:14 PM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I had the same problem with one I bought from Sears. It was suppose to do double flares but the clamp on the tool wouldn't hold the tubing in position while flaring. I could use some tips also or a GOOD tool that actually works right.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: Double flare tubing tool [Re: Moneypit6] #605756
02/06/10 12:17 PM
02/06/10 12:17 PM
Haven't run into that but I've only used my buddies Rigid brand which is pretty good piece. I'd suspect that they didn't machine it right maybe not enough off of the 2 faces that meet so not enough clamping force. I'm thinking that you could can wrap something real thin around the tubing to make up for that like some thin metal shim material from your hardware store?
Re: Double flare tubing tool [Re: Moneypit6] #605757
02/06/10 12:22 PM
02/06/10 12:22 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've got a 45° double flare and a 37° single flare tool and both grib the line fine when you tighten them down hard. Did use a friends ages ago and his would slip too (even using pliers to really crank it down tight), think as mentioned must just be ones machined poorly perhaps
If you have the clamps as tight as possible and it still slips, maybe call Summit and see if they will change it for another one...
Re: Double flare tubing tool [Re: Moneypit6] #605758
02/06/10 12:33 PM
02/06/10 12:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I know what your talking about, the cheaper tools will do that. You can make it work by tightening the end of the tool closest to the tube first, then tighten the farthest away second. Tightening the longer end of the tool last gives it more leverage to grip the tube better. Does that make sense?
Re: Double flare tubing tool [Re: OzHemi] #605759
02/06/10 12:35 PM
02/06/10 12:35 PM
OzHemi I've been wondering about this since I have a 45 & want to do some 37's on some AN tubing/fittings. Is the only diff the angle on the nub as I want to just turn one down or turn another one (to get 37)???. On the orig Q & not visualizing how it is but are there 2 places on the end where the 2 sides come together like a pair of calipers that could be trimmed a bit for more clamping force along the 2 faces? I think the only caveat is you need to end up w the tapered point still centered over the tubing
Re: Double flare tubing tool [Re: RapidRobert] #605760
02/06/10 12:38 PM
02/06/10 12:38 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I think so...I've used it a bunch of times now to do AN stuff and it's worked great. I hadn't thought of turning a 45° down...just ordered the other one. But don't forget that the dimple in the holder has to be the right angle too
Re: Double flare tubing tool [Re: Moneypit6] #605761
02/06/10 12:49 PM
02/06/10 12:49 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
After years of frustration with the $50? Summit type tools, I dropped a few hundred on the real hydraulic double flare tools, and glad I did.
Re: Double flare tubing tool [Re: Challenger 1] #605762
02/06/10 12:53 PM
02/06/10 12:53 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
If you tighten the wrong end first, it doesn't hold near as well.
DRIVE EM, DONT HIDE EM.
Re: Double flare tubing tool [Re: OzHemi] #605763
02/06/10 12:53 PM
02/06/10 12:53 PM
thanks OZ . Holy Moses I forgot about the angle on the other side would have to match also . Sounds like I better just pony up & get a Summitt (they're cheap)(now I know why) assuming that the ends can be filed so it will clamp down tight
Re: Double flare tubing tool [Re: Challenger 1] #605764
02/06/10 12:55 PM
02/06/10 12:55 PM
California
California
" Does that make sense?"
It certainly does, but in this case the clamps are both bottomed. It has a slight bulge in the area of the tube because it's flexing. I C-clamped on each side to complete the squeeze but this stuff is stubborn. I can mill more off of the clamp but was just wondering if there was a good trick without squeezing the *ell out of the tube and making it look smaller after the install. I'm beginning to think I have to size it so that it actually pinches the tube down a little and makes it's own shoulder.
Re: Double flare tubing tool [Re: jcc] #605765
02/06/10 12:58 PM
02/06/10 12:58 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I was temped on one of them, sure look like a nice way to go.
On the tool topic, I just bought an A/C hose crimper, sure works nice
Re: Double flare tubing tool [Re: Moneypit6] #605766
02/06/10 12:59 PM
02/06/10 12:59 PM
Cincinnati, Ohio
Cincinnati, Ohio
Try what I said first on a fresh peice of tube. You don't want the tube colasped where you gripe it either. It it's leaving a crimp mark, then it will work without any milling.
Re: Double flare tubing tool [Re: RapidRobert] #605767
02/06/10 01:00 PM
02/06/10 01:00 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Maybe moneypit will give you a deal on a slighty used one
Re: Double flare tubing tool [Re: Moneypit6] #605768
02/06/10 01:14 PM
02/06/10 01:14 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you are going to any amount of double flaring,go to a refrigeration parts supplier and buy a Imperial-Eastman.It's tube holder (attached) won't slip no matter what size tube.It's still USA made and will last forever.In tools,you get what you pay for. :twocents
Re: Double flare tubing tool [Re: 62maxwgn] #605769
02/06/10 01:23 PM
02/06/10 01:23 PM
California
California
"If you are going to any amount of double flaring,go to a refrigeration parts supplier and buy a Imperial-Eastman."
Now we're talking. Wish I would have knew that before. I certainly agree with the good tool theory. I just didn't know I would have this problem.
The clamp slips on the tube no matter what side is tightened first. I think I'll mill a few thousands off and go from there.
Re: Double flare tubing tool [Re: 62maxwgn] #605770
02/06/10 01:26 PM
02/06/10 01:26 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Nice looking tool!
And I agree....that A/C crimper I just got is a good quality tool, and just makes the job go smooth and easy...I bought my flare tools a little bit ago, and wasn't aware of that style, sure looks good.
Re: Double flare tubing tool [Re: 62maxwgn] #605771
02/06/10 01:29 PM
02/06/10 01:29 PM
north west, IN
larry890 Offline
larry890  Offline
north west, IN
I repair lots of fuel and brake line, and have noticed that the od sizes differ on several different brands of line. causing them to slip in the clamp.
Re: Double flare tubing tool [Re: OzHemi] #605772
02/06/10 01:30 PM
02/06/10 01:30 PM
California
California
Imperial Eastman 525-F
I just checked this tool out on their site. It's single flare only. Their double flair tools look like everyone elses!??
Re: Double flare tubing tool [Re: Moneypit6] #605773
02/06/10 01:40 PM
02/06/10 01:40 PM
USA
Slider Offline
super gas
Slider  Offline
super gas
USA
�Hunt down those Chevies and Fords and crush �em like bugs!� ~ Tom Hoover
(O=o=====o=O)
Page 1 of 3 1 2 3
