Trans. Temp gauge
#604712
02/05/10 07:47 AM
02/05/10 07:47 AM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
Would you install one on your car?
I was just shuffling through some old boxes I had and found a an Autometer trans temp gauge (matches the other 4 gauges in my car now) and pondering on an installation if needed. I dunno though. I don't tow anything. I have a trans cooler and an overdrive...what are the chances of it heating up?
Where does it thread into anyways? It has a probe similar to a water jacket temp. Looks like a 3/8 NPT
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Trans. Temp gauge
[Re: Pyper70]
#604714
02/05/10 01:06 PM
02/05/10 01:06 PM
RapidRobert
yes take the pan off & as maximus said drill a hole somewheer in the side where the probe wont hit the VB (& iirc a 1/2" hole) then a locknut and nylon gasket will go on either side of the pan on the threads to lock it in place. Ideal place is in a special T fiting in the (front) trans cooler line where the oil is the hottest as it's just coming out of the TC but the pan temp reading will be close enough
