Trans. Temp gauge #604712
02/05/10 07:47 AM
02/05/10 07:47 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Would you install one on your car?
I was just shuffling through some old boxes I had and found a an Autometer trans temp gauge (matches the other 4 gauges in my car now) and pondering on an installation if needed. I dunno though. I don't tow anything. I have a trans cooler and an overdrive...what are the chances of it heating up?
Where does it thread into anyways? It has a probe similar to a water jacket temp. Looks like a 3/8 NPT
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Trans. Temp gauge [Re: Pyper70] #604713
02/05/10 12:52 PM
02/05/10 12:52 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Got one on my car, installs on the trans pan. Make sure you put it somewhere you have internal clearance for the sensor. If you have a high stall convertor on the street it really helps to know trans temp.
Re: Trans. Temp gauge [Re: Pyper70] #604714
02/05/10 01:06 PM
02/05/10 01:06 PM
yes take the pan off & as maximus said drill a hole somewheer in the side where the probe wont hit the VB (& iirc a 1/2" hole) then a locknut and nylon gasket will go on either side of the pan on the threads to lock it in place. Ideal place is in a special T fiting in the (front) trans cooler line where the oil is the hottest as it's just coming out of the TC but the pan temp reading will be close enough
