Header Gaskets #591862
01/23/10 08:44 PM
01/23/10 08:44 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
I keep getting header leaks!!! Does anyone know what the best header gasket to use is?
Re: Header Gaskets [Re: RBSat66] #591863
01/23/10 09:18 PM
01/23/10 09:18 PM
alot of people have reported (on here) that remflex is the best hands down.
Re: Header Gaskets [Re: RapidRobert] #591864
01/23/10 09:30 PM
01/23/10 09:30 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
A little Hi-Temp copper rtv applied to any gasket really helps them seal.
Copper rtv with copper gaskets is bulletproof, and reusable many times over.
Re: Header Gaskets [Re: RBSat66] #591865
01/23/10 09:31 PM
01/23/10 09:31 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I've been using the copper gaskets from SCE for many years with no problems.I've used them on 2 different engines,still work great.
Nautilus Racing-
Re: Header Gaskets [Re: RapidRobert] #591866
01/23/10 09:38 PM
01/23/10 09:38 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
That was the gasket I was thinking of and couldn't remember the name. Thanks for the information.
Re: Header Gaskets [Re: Chris2581] #591867
01/23/10 09:38 PM
01/23/10 09:38 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I found the crush type copper gaskets to work like crap. No way I can torq those header bolts down tight enough to crush the gasket to get a good seal.
Re: Header Gaskets [Re: DaytonaTurbo] #591868
01/23/10 10:54 PM
01/23/10 10:54 PM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
this is a trick a buddy told me and i used it and for 2.5years no leaks, buy 2sets of the mr. gasket header gasket not copper, take black rtv and glue both sets together, let them set over night, then install the next day, snug them up on the first, do not over tight, then after you crank the engine and say drive to store and back, while the engine is still hot, go over and back sure all the bolts are snug, the you should be okay,
Re: Header Gaskets [Re: cornet684me] #591869
01/24/10 07:56 AM
01/24/10 07:56 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We use the Mr Gasket Ultra seals.Never any leaks.Ive even reused them.My kid finally had to replace one after 6 years and it was one that was reused.Rocky
Chrysler Firepower
Re: Header Gaskets [Re: RBSat66] #591870
01/24/10 09:04 AM
01/24/10 09:04 AM
Valrico FL
1toolguy Offline
1toolguy  Offline
Valrico FL
I got a year out of the last copper gaskets I tried. They started leaking again on the dyno, the shop owner told me to make a cut in the "spreader" between the tubes. Just a hacksaw width cut will allow everything to expand and contract seperately and keep the gasket from moving around and eventually leaking.
I haven't had time to try it yet but it makes sense to me.
Re: Header Gaskets [Re: therocks] #591871
01/24/10 09:04 AM
01/24/10 09:04 AM
NJ
440challenger Offline
NJ
remflex
Re: Header Gaskets [Re: 440challenger] #591872
01/24/10 11:53 AM
01/24/10 11:53 AM
Southern Utah
440Laser Offline
super street
440Laser  Offline
super street
Southern Utah
Percy multi layer aluminum. They will SEAL it and are reusable.
Re: Header Gaskets [Re: 440Laser] #591873
01/24/10 12:28 PM
01/24/10 12:28 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Some times cutting the header flanges make the problem worse rather than better. BTDT
Re: Header Gaskets [Re: RBSat66] #591874
01/24/10 09:45 PM
01/24/10 09:45 PM
bristol tn
jbcuda Offline
jbcuda  Offline
bristol tn
i use remflex on my 440 with hooker headers have had no problems. amazon.com about 28.00 free shipping for a set. works for me
Re: Header Gaskets [Re: jbcuda] #591875
01/24/10 10:02 PM
01/24/10 10:02 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
I have raced many cars over the past years. All 440's or BB Stroker Engines. Some had the heavy Hooker fenderwell headers which are very hard on gaskets. If Felpro still makes them in their performance gaskets that is the ticket for you. They are not the ones that come in the full Gasket set. They are blue one piece. They are expensive but you will only buy one set and you will be able to re-use them year after year. I never put any sealers on them.
I wish I could remember the number for you!
Joe Sr.
Re: Header Gaskets [Re: joewhite440] #591876
01/24/10 10:28 PM
01/24/10 10:28 PM
Nanuet, NY
3
383BeepBeep Offline
383BeepBeep  Offline
Nanuet, NY
Remflex and forget about it.
1969 Plymouth Roadrunner - 383- 4 Speed - Dana 60 4:10
Re: Header Gaskets [Re: 383BeepBeep] #591877
01/24/10 10:46 PM
01/24/10 10:46 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
I always make my own outta the Mr. gasket header material. Ive tried damn near every hemi header gasket and nothing lines up correctly so i just made my won
Re: Header Gaskets [Re: stumpy] #591878
01/25/10 07:06 AM
01/25/10 07:06 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Worked for me on a set of crappy Hookers.
What type of headers are they?
Re: Header Gaskets [Re: Pntastar69] #591879
01/25/10 11:22 AM
01/25/10 11:22 AM
Az
Crizila Offline
Crizila  Offline
Az
I run "Gibson" #9245 on my SB mag heads. Great fit - no leaks.
Fastest 300
Re: Header Gaskets [Re: Crizila] #591880
01/25/10 02:35 PM
01/25/10 02:35 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
