Re: Header Gaskets
[Re: RBSat66]
#591863
01/23/10 09:18 PM
01/23/10 09:18 PM
RapidRobert
alot of people have reported (on here) that remflex is the best hands down.
Re: Header Gaskets
[Re: RBSat66]
#591865
01/23/10 09:31 PM
01/23/10 09:31 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I've been using the copper gaskets from SCE for many years with no problems.I've used them on 2 different engines,still work great.
Re: Header Gaskets
[Re: DaytonaTurbo]
#591868
01/23/10 10:54 PM
01/23/10 10:54 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
this is a trick a buddy told me and i used it and for 2.5years no leaks, buy 2sets of the mr. gasket header gasket not copper, take black rtv and glue both sets together, let them set over night, then install the next day, snug them up on the first, do not over tight, then after you crank the engine and say drive to store and back, while the engine is still hot, go over and back sure all the bolts are snug, the you should be okay,
Re: Header Gaskets
[Re: cornet684me]
#591869
01/24/10 07:56 AM
01/24/10 07:56 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
We use the Mr Gasket Ultra seals.Never any leaks.Ive even reused them.My kid finally had to replace one after 6 years and it was one that was reused.Rocky
Chrysler Firepower
Re: Header Gaskets
[Re: stumpy]
#591878
01/25/10 07:06 AM
01/25/10 07:06 AM
Posts: 2,757 Gilbertsville, PA 19525
Pntastar69
Some times cutting the header flanges make the problem worse rather than better. BTDT
Worked for me on a set of crappy Hookers.
What type of headers are they?
Re: Header Gaskets
[Re: Pntastar69]
#591879
01/25/10 11:22 AM
01/25/10 11:22 AM
Posts: 7,506 Az
Crizila
Az
I run "Gibson" #9245 on my SB mag heads. Great fit - no leaks.
Fastest 300
