Page 2 of 5 1 2 3 4 5
Re: Twin Turbo Big Block *video* [Re: Defbob] #582653
01/15/10 04:55 PM
01/15/10 04:55 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
low RPM and boost dont get along well.
at least you built a completed system.
Re: Twin Turbo Big Block *video* [Re: Defbob] #582654
01/15/10 05:04 PM
01/15/10 05:04 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
The Turbos are too small. i should have gotten T4's, but i figured these would make boost off of idle and almost act like a supercharger
Ya, sounds good up until you hit 3k at WOT and stop making power/start detonating like crazy .
Re: Twin Turbo Big Block *video* [Re: topbrent] #582655
01/15/10 05:28 PM
01/15/10 05:28 PM
Andrews,In. U.S.of A.
67_Satellite Offline
No comment on turbine size,but are those oil feed lines supported?Vibration induced cracking and leakage would ruin your day quickly. I ran mine with braided -6 line to be safe.
Re: Twin Turbo Big Block *video* [Re: Defbob] #582656
01/15/10 05:58 PM
01/15/10 05:58 PM
ELYRIA,OH
ELYRIA,OH
not that you would want to bandaid or rig it all up but i wonder if you could us a bleedoff valve to get rid of some of the exhaust before the turbo's.
Re: Twin Turbo Big Block *video* [Re: Defbob] #582657
01/15/10 06:37 PM
01/15/10 06:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
btw, it makes 2lbs idling at 1000rpm
how? I had a paxton on a very mild 440 w/ not much stall and in N I'd get no boost no matter the rpms? My understanding is unless the engine has a load, and in N it shouldn't you should have no boost???? even at highway speeds my boost was minimal. Does a turbo(s) work different?
Coming soon!!!!
Re: Twin Turbo Big Block *video* [Re: Mr.Yuck] #582658
01/15/10 07:58 PM
01/15/10 07:58 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Tim,
Two things come to mind, First is that the turbine and/or the housing A/R is much to small. Second - the Backpressure will most likley climb very fast and create valve float and other issues before you get in any usable RPM band.
If possible, I would try and plumb a gage port in at least one of the manifolds and monitor backpressure. In a perfect system, It should be near a 1:! ratio around your usable power band. It looks like in your case the Backpressure is going to be way to high and climb while your boost drops.
Another thing that may happen is turbo overspeed. You may bust the compressor wheel if you spin it up to fast with that backpressure.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Twin Turbo Big Block *video* [Re: Defbob] #582659
01/15/10 08:48 PM
01/15/10 08:48 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Your blow off valve should be manifold referanced and your wastegate bottom port should manifold referanced .
You should have vacuum at idle .
There is something out of whack.
You should see the blow off valve open at idle and slam shut when you chop the throttle if you have all that boost.
The exhaust manifold length has nothing to do with it.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Twin Turbo Big Block *video* [Re: Mr.Yuck] #582660
01/15/10 09:02 PM
01/15/10 09:02 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I looked at the gauge. I must retract the 2lbs at idle statement it is not making boost at idle
Re: Twin Turbo Big Block *video* [Re: Defbob] #582661
01/15/10 09:05 PM
01/15/10 09:05 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
the wastegates and blowoff are plumbed correctly. I just hope this holds together for a couple good passes at Lebannon Valley for Muscle Palooza. Al, the manifolds did glow when breaking in the cam
Re: Twin Turbo Big Block *video* [Re: Defbob] #582662
01/15/10 09:28 PM
01/15/10 09:28 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I was wrong. I double checked a diagram. I have the blowoff reference on the wrong side of the carb. Thanks guys for the info and getting me to double check things
Re: Twin Turbo Big Block *video* [Re: Defbob] #582663
01/15/10 09:33 PM
01/15/10 09:33 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Tim,
What ae the specs on the turbos ?
Allan G.
Re: Twin Turbo Big Block *video* [Re: turbobitt] #582664
01/15/10 10:12 PM
01/15/10 10:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
do you have your fuel boost referenced?
Coming soon!!!!
Re: Twin Turbo Big Block *video* [Re: Mr.Yuck] #582665
01/15/10 11:36 PM
01/15/10 11:36 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
the mechanical fuel pump is boost referenced and surprisingly works
Re: Twin Turbo Big Block *video* [Re: turbobitt] #582666
01/15/10 11:38 PM
01/15/10 11:38 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Tim,
Allan G.
T3/T4 Turbos
T3 Flange to Manifold
- 5 Bolt Hot Side Downpipe Flange
- .50 A/R Compressor
- .63 A/R Turbine
- 3" Inlet & 2" Outlet
- 1/8 NPT Oil Inlet
- 350 WHP capable
- 5~30 PSI Working Pressure
- Computer Balanced Individually
Re: Twin Turbo Big Block *video* [Re: Defbob] #582667
01/15/10 11:55 PM
01/15/10 11:55 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Tim,
Allan G.
T3/T4 Turbos
- .63 A/R Turbine
- 1/8 NPT Oil Inlet
- 350 WHP capable
What is the size of the turbine wheel or spec."P" trim? or "Q"? Millimeters if known?
.63 are prolly gonna give a ton of back pressure.
How much seat pressure are you running on the valves? 150 or more?
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!) 03 Mach1
Re: Twin Turbo Big Block *video* [Re: tilt] #582668
01/16/10 09:38 AM
01/16/10 09:38 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
i don't know the trim. The springs are the ones that come on Edelbrock RPM heads
Re: Twin Turbo Big Block *video* [Re: Defbob] #582669
01/16/10 09:45 AM
01/16/10 09:45 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that's what I did too. When I was told how to do it I was like...what no way that's going to work.
Re: Twin Turbo Big Block *video* [Re: Mr.Yuck] #582670
01/16/10 10:29 AM
01/16/10 10:29 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
i have a turbo book from 1980
Re: Twin Turbo Big Block *video* [Re: Defbob] #582671
01/16/10 11:43 AM
01/16/10 11:43 AM
Mid-Ohio
Bakaruda432 Offline
mopar addict
Bakaruda432  Offline
mopar addict
Mid-Ohio
I would love to see that thing on a chassis dyno.
My computor couldn't see the vid but those pics are hot!
Re: Twin Turbo Big Block *video* [Re: Bakaruda432] #582672
01/16/10 12:54 PM
01/16/10 12:54 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I just hooked up the throttle and return springs. I also mounted the pods for the gauges to be inside. I will mount the shifter today and torque the car up against the converter and see how it handles it. then I will do some burnouts and video it
