Solid cam with non adjustable rockers
#579300
01/10/10 11:56 PM
01/10/10 11:56 PM
Posts: 1,180 clarks summit pa
73cuda340
clarks summit pa
Im guessing not, but is it possible to run non adjustable shaft mounted rocker arms on an engine with a solid cam?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Solid cam with non adjustable rockers
[Re: 73cuda340]
#579302
01/10/10 11:58 PM
01/10/10 11:58 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
No. you must be able to adjust the lash with solids.
[Re: 73cuda340]
#579303
01/11/10 12:00 AM
01/11/10 12:00 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
well..how are you going to adjust the lash with non adjustable rockers
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#579304
01/11/10 12:01 AM
01/11/10 12:01 AM
73cuda340
clarks summit pa
I know its a stupid question but I figured it didnt hurt to ask.
[Re: mike s]
#579307
01/11/10 12:10 AM
01/11/10 12:10 AM
70AARcuda
las vegas
and you think the non adjustable rockers will hold up to the spring pressure for a solid cam with the adjustable push rods???
Tony
[Re: 70AARcuda]
#579309
01/11/10 12:16 AM
01/11/10 12:16 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Depends on the cam....something super mild would....but I agree it's not a great idea.
I ran stock rockers with a crane hyd with .528 intake lift/.552 exhaust lift (242/252 @ .050 duration) with Edelbrock heads and their stock springs for 3 years with no problems. Any more spring pressure than that....and you will start poking pushrods through the rockers. Just my
[Re: 73cuda340]
#579312
01/11/10 02:01 AM
01/11/10 02:01 AM
Posts: 31,049 Oregon
AndyF
Sure, that is how the NASCAR guys do it these days to save weight. Costs a lot of money though because they have to buy pushrods in 0.005 increments.
[Re: Dodgem]
#579317
01/11/10 03:16 PM
01/11/10 03:16 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Back when the 392 Hemi was King of the fuelers most guys ran the adjustable pushrods with stock rockers which were cast.Spring open pressures were only about 350lbs then.Max lifts were only about.550 Less than that they could work but that should be the high limit.
Leave the gun.......take the Cannoli's....Mike
