Solid cam with non adjustable rockers #579300
01/10/10 11:56 PM
01/10/10 11:56 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Im guessing not, but is it possible to run non adjustable shaft mounted rocker arms on an engine with a solid cam?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Solid cam with non adjustable rockers [Re: 73cuda340] #579301
01/10/10 11:58 PM
01/10/10 11:58 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Only if you use adjustable pushrods (which are rare nowadays).
Re: Solid cam with non adjustable rockers [Re: 73cuda340] #579302
01/10/10 11:58 PM
01/10/10 11:58 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
No. you must be able to adjust the lash with solids.
Re: Solid cam with non adjustable rockers [Re: 73cuda340] #579303
01/11/10 12:00 AM
01/11/10 12:00 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
well..how are you going to adjust the lash with non adjustable rockers
Tony
70 AARCuda Vitamin C
Re: Solid cam with non adjustable rockers [Re: 70AARcuda] #579304
01/11/10 12:01 AM
01/11/10 12:01 AM
clarks summit pa
clarks summit pa
I know its a stupid question but I figured it didnt hurt to ask.
Re: Solid cam with non adjustable rockers [Re: 70AARcuda] #579305
01/11/10 12:02 AM
01/11/10 12:02 AM
Central Valley, CA.
Central Valley, CA.
You could with adjustable pushrods....
Re: Solid cam with non adjustable rockers [Re: Quicksilver440] #579306
01/11/10 12:06 AM
01/11/10 12:06 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
correct
Leave the gun.......take the Cannoli's....Mike
Re: Solid cam with non adjustable rockers [Re: mike s] #579307
01/11/10 12:10 AM
01/11/10 12:10 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
and you think the non adjustable rockers will hold up to the spring pressure for a solid cam with the adjustable push rods???
Tony
Re: Solid cam with non adjustable rockers [Re: mike s] #579308
01/11/10 12:10 AM
01/11/10 12:10 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Anyone even still make adjustable pushrods for our motors?
Re: Solid cam with non adjustable rockers [Re: 70AARcuda] #579309
01/11/10 12:16 AM
01/11/10 12:16 AM
Central Valley, CA.
Central Valley, CA.
Depends on the cam....something super mild would....but I agree it's not a great idea.
I ran stock rockers with a crane hyd with .528 intake lift/.552 exhaust lift (242/252 @ .050 duration) with Edelbrock heads and their stock springs for 3 years with no problems. Any more spring pressure than that....and you will start poking pushrods through the rockers. Just my
Re: Solid cam with non adjustable rockers [Re: DaytonaTurbo] #579310
01/11/10 12:32 AM
01/11/10 12:32 AM
Mooresville, NC
I
Intense RT Dan Offline
I
Mooresville, NC
I think Smith Brothers does.
Re: Solid cam with non adjustable rockers [Re: Intense RT Dan] #579311
01/11/10 12:54 AM
01/11/10 12:54 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I would think the stock rockers would need pressure on them to keep oiling under control .I can imagine the noise they would make.
Re: Solid cam with non adjustable rockers [Re: 73cuda340] #579312
01/11/10 02:01 AM
01/11/10 02:01 AM
AndyF Offline
AndyF  Offline
Sure, that is how the NASCAR guys do it these days to save weight. Costs a lot of money though because they have to buy pushrods in 0.005 increments.
Re: Solid cam with non adjustable rockers [Re: DaytonaTurbo] #579313
01/11/10 08:20 AM
01/11/10 08:20 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
http://www.summitracing.com/parts/CRO-70009-16/
http://www.summitracing.com/parts/CRO-70006-16/
Ahh and ones for SOLID lifters
http://www.summitracing.com/parts/CRO-70010-16/
Re: Solid cam with non adjustable rockers [Re: 73cuda340] #579314
01/11/10 11:01 AM
01/11/10 11:01 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
If you are running much spring pressure be sure
to use the thick rockers.
Re: Solid cam with non adjustable rockers [Re: demonH1B] #579315
01/11/10 01:02 PM
01/11/10 01:02 PM
Manitoba, Canada
Manitoba, Canada
Still cheaper than cast rockers. Just don't go nuts with spring pressures. Anyone run these on the street these days?
Re: Solid cam with non adjustable rockers [Re: DaytonaTurbo] #579316
01/11/10 02:46 PM
01/11/10 02:46 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My old set for hydraulic lifters (MP ones) is on my buddies 440 crane cam street car! Pain in the but to set! LOL!!
Re: Solid cam with non adjustable rockers [Re: Dodgem] #579317
01/11/10 03:16 PM
01/11/10 03:16 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Back when the 392 Hemi was King of the fuelers most guys ran the adjustable pushrods with stock rockers which were cast.Spring open pressures were only about 350lbs then.Max lifts were only about.550 Less than that they could work but that should be the high limit.
Re: Solid cam with non adjustable rockers [Re: mike s] #579318
01/11/10 03:24 PM
01/11/10 03:24 PM
michigan woods
imfixinmopars426 Offline
michigan woods
if its a small block,find some old 273 adjustables for cheap,and run em. i find them for 40-50 at swaps.they would be A LOT easier to adjust them compared to the stupid adj p/rods!
oh,and no question is stupid if you dont know the answer,thats why this forum if one of the best!
Re: Solid cam with non adjustable rockers [Re: imfixinmopars426] #579319
01/11/10 04:29 PM
01/11/10 04:29 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Ahh small block i assume everyone has a 440??
My Bad!! small block with solids
