Re: I guess the XR block is here?
[Re: Quicktree]
#579050
01/10/10 09:01 PM
01/10/10 09:01 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
http://www.hughesengines.com/TechArticles/smallblockfromritterracing.php
why would you build a race block that wont except roller lifters without a lot of grinding?
Same reason MP did it with the R3's.
Order a 48 if you want ease of roller lifter installation....
To be honest, not alot of applications I'd ever order a 59* block for these days. Stock J/X/Edelbrock head apps that would be about it.
I'm doing a hyd roller 59* XR1 for member, but am not doing link bar lifters in it
Just knowing how much issue Kent has had with the castings in the valley area, I probably will never do a 59* XR1 with link bar solid rollers. If I do, the sonic tester will be used heavily...
This post reminds me I need to talk to Kent about our royalty checks now that blocks are shipping LOL.
[Re: RyanJ]
#579051
01/10/10 09:08 PM
01/10/10 09:08 PM
Quicktree
Ryan would my 59* indy heads work with a 48*xr?
[Re: Quicktree]
#579052
01/10/10 09:44 PM
01/10/10 09:44 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
Ryan your thinking grind off the headbolt bosses..? and not hitting water..!! to get the kind of clearence a link bar lifter needs?
360-1's would stay 59*? or ?
the way it is..what lifter are you refering to for 48*?
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: Quicktree]
#579053
01/10/10 11:21 PM
01/10/10 11:21 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
No magnum motor mounts lots of late model truck guys won't be able to use the block easily. Looks like it could be a good deal on a nice block.
[Re: Quicktree]
#579054
01/11/10 09:46 AM
01/11/10 09:46 AM
RyanJ
moparts member
moparts member
State College, PA
Yes... just need to clearance heads for pushrods. More rocker ratio you run, the easier it is. (less clearancing)
[Re: HotRodDave]
#579057
01/11/10 03:22 PM
01/11/10 03:22 PM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
That was one of my wishes for this block. Truck guys are gonna have to stick to R blocks or fab some different mounts.
[Re: dizuster]
#579060
01/11/10 06:21 PM
01/11/10 06:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
So these must all use pushrod oiling now it looks like? I don't see the standard head oiling feed in the block.
I like the cam tunnel being blocked off. I wonder how much power that windage is worth?
Also, it's nice to see the HUGE water jacket holes gone from the front of the deck...
Yeah I like the cam tunnel oil return I'm assuming the the hole at the front is the oil supply port like a R-3 dry sump block(they referred to it as oil pressure, where I would call it oil supply OR oil IN)... sure looks beefy up in the lifter valley
[Re: Quicktree]
#579062
01/11/10 07:18 PM
01/11/10 07:18 PM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
only problem I see with the high dolar cast blocks is you can loose them with a broken rod bolt or something. no way to repair them. by the time everything is said and done it will be close to 5k
At one time ryan was going to do my engine with a 48* r3 with the 4.250 bore+/- and the 4.250 stroke, then i found that the r3 block needed extencive work/money.So i took the 59* x block to finish my 449.....We need to see someone build an engine from a to z around this block,so we can have an idea of how much coin is going to need...
[Re: Quicktree]
#579063
01/11/10 08:52 PM
01/11/10 08:52 PM
MR_P_BODY
Thats the price for buying new... you could do like I did, I got my R3 block at a swap meet at Indy, it was new but I got it for $800 9.2 deck, siamese cyl
[Re: MR_P_BODY]
#579064
01/11/10 09:00 PM
01/11/10 09:00 PM
Quicktree
I had an R3 block but sold it
