I guess the XR block is here? #579047
01/10/10 08:30 PM
01/10/10 08:30 PM
Q
Quicktree Offline OP
Q
http://www.hughesengines.com/TechArticles/smallblockfromritterracing.php
why would you build a race block that wont except roller lifters without a lot of grinding?
Re: I guess the XR block is here? [Re: Quicktree] #579048
01/10/10 08:36 PM
01/10/10 08:36 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Probably thinking guys will use keyway rollers....
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: I guess the XR block is here? [Re: DemonDust] #579049
01/10/10 08:57 PM
01/10/10 08:57 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Nice looking block but why didn't they use screw in soft plugs.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: I guess the XR block is here? [Re: Quicktree] #579050
01/10/10 09:01 PM
01/10/10 09:01 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Same reason MP did it with the R3's.
Order a 48 if you want ease of roller lifter installation....
To be honest, not alot of applications I'd ever order a 59* block for these days. Stock J/X/Edelbrock head apps that would be about it.
I'm doing a hyd roller 59* XR1 for member, but am not doing link bar lifters in it
Just knowing how much issue Kent has had with the castings in the valley area, I probably will never do a 59* XR1 with link bar solid rollers. If I do, the sonic tester will be used heavily...
This post reminds me I need to talk to Kent about our royalty checks now that blocks are shipping LOL.
Re: I guess the XR block is here? [Re: RyanJ] #579051
01/10/10 09:08 PM
01/10/10 09:08 PM
Q
Q
Ryan would my 59* indy heads work with a 48*xr?
Re: I guess the XR block is here? [Re: Quicktree] #579052
01/10/10 09:44 PM
01/10/10 09:44 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
Ryan
your thinking grind off the headbolt bosses..?
and not hitting water..!!
to get the kind of clearence a link bar lifter needs?
360-1's would stay 59*? or ?
the way it is..what lifter are you refering to for 48*?
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: I guess the XR block is here? [Re: Quicktree] #579053
01/10/10 11:21 PM
01/10/10 11:21 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
No magnum motor mounts lots of late model truck guys won't be able to use the block easily. Looks like it could be a good deal on a nice block.
Re: I guess the XR block is here? [Re: Quicktree] #579054
01/11/10 09:46 AM
01/11/10 09:46 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Yes... just need to clearance heads for pushrods. More rocker ratio you run, the easier it is. (less clearancing)
Re: I guess the XR block is here? [Re: RyanJ] #579055
01/11/10 11:41 AM
01/11/10 11:41 AM
this this is 9.60 deck height?
its not available yet...?
cheapst
[image][/image]
Re: I guess the XR block is here? [Re: cheapstreetdustr] #579056
01/11/10 12:45 PM
01/11/10 12:45 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
So these must all use pushrod oiling now it looks like? I don't see the standard head oiling feed in the block.
I like the cam tunnel being blocked off. I wonder how much power that windage is worth?
Also, it's nice to see the HUGE water jacket holes gone from the front of the deck...
Re: I guess the XR block is here? [Re: HotRodDave] #579057
01/11/10 03:22 PM
01/11/10 03:22 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
That was one of my wishes for this block. Truck guys are gonna have to stick to R blocks or fab some different mounts.
Re: I guess the XR block is here? [Re: DemonDust] #579058
01/11/10 04:19 PM
01/11/10 04:19 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
A front motor plate will take care of that problem
Re: I guess the XR block is here? [Re: Devilbrad] #579059
01/11/10 06:13 PM
01/11/10 06:13 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
X2
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: I guess the XR block is here? [Re: dizuster] #579060
01/11/10 06:21 PM
01/11/10 06:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I like the cam tunnel oil return
I'm assuming the the hole at the front is the oil
supply port like a R-3 dry sump block(they referred
to it as oil pressure, where I would call it oil
supply OR oil IN)... sure looks beefy up in the lifter
valley
Re: I guess the XR block is here? [Re: MR_P_BODY] #579061
01/11/10 06:33 PM
01/11/10 06:33 PM
Q
Q
only problem I see with the high dolar cast blocks is you can loose them with a broken rod bolt or something. no way to repair them. by the time everything is said and done it will be close to 5k
Re: I guess the XR block is here? [Re: Quicktree] #579062
01/11/10 07:18 PM
01/11/10 07:18 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
At one time ryan was going to do my engine with a 48* r3 with the 4.250 bore+/- and the 4.250 stroke, then i found that the r3 block needed extencive work/money.So i took the 59* x block to finish my 449.....We need to see someone build an engine from a to z around this block,so we can have an idea of how much coin is going to need...
Re: I guess the XR block is here? [Re: Quicktree] #579063
01/11/10 08:52 PM
01/11/10 08:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the price for buying new... you could do like I
did, I got my R3 block at a swap meet at Indy, it was
new but I got it for $800 9.2 deck, siamese cyl
Re: I guess the XR block is here? [Re: MR_P_BODY] #579064
01/11/10 09:00 PM
01/11/10 09:00 PM
Q
Q
I had an R3 block but sold it
Re: I guess the XR block is here? [Re: Quicktree] #579065
01/12/10 08:58 AM
01/12/10 08:58 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Hughes said the blocks were 3100 how much is a new R3 block now days .Also mp makes a R3 block for the magnum guys dont they
Re: I guess the XR block is here? [Re: MR_P_BODY] #579066
01/12/10 09:21 AM
01/12/10 09:21 AM
Finland
mafo Offline
mafo  Offline
Finland
Do you have anymore of those 800$ blocks?
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
