Conversion:318/904 to 340/727 #572366
01/04/10 02:48 PM
01/04/10 02:48 PM
Valley of the Sun, AZ
cudagerry Offline OP
I do not have a flex plate or torque converter for the 340/727.
Will the ones from the 318/904 work? (This is a fairly mild 340 build.)
Oh, and what about the trans shifter linkages, are they the same?
Re: Conversion:318/904 to 340/727 [Re: cudagerry] #572367
01/04/10 03:57 PM
01/04/10 03:57 PM
NY usa
540challenger Offline
NY usa
The flexplate will bolt on the motor.
But the bolt pattern on the convetor might be different
The B/M flexplate is a nice fix for that. uit has both bolt patterens on it.
The convertor won't 904 and 727 use have different amount of splines on the input shafts.
Also what year 340? some were internal others were enternally balanced.
the shift linkage will work on both 904/727
also the drive shaft will nned a new yoke and to be cut down. The 727 is longer and has a different spline.
Re: Conversion:318/904 to 340/727 [Re: cudagerry] #572368
01/04/10 04:03 PM
01/04/10 04:03 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Driver's side block mounting lugs are a bit closer together on a 340 but they can be adapted to the 318 bracket with either a spacer or washers.
Re: Conversion:318/904 to 340/727 [Re: Reggie] #572369
01/04/10 06:41 PM
01/04/10 06:41 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
Why not just use the 904 and existing parts and you have a bolt in assembly? The 904 will easily handle most street driven 340's.
904 Equipped
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Conversion:318/904 to 340/727 [Re: DragDart360] #572370
01/04/10 09:17 PM
01/04/10 09:17 PM
Now that's a thought. I have a rebuilt 727, I guess I could just refresh the 904, it was working fine other than the typical leak(s).
Then, if I wanted, I could put in the 8 3/4 rear and the 727 at the same time.
It's for a 70 Barracuda, I guess I just always had it in my mind that the 727 and 8 3/4 was the way to go for the higher performance applications.
Say, doesn't the 904 have a shorter 1st gear ratio also?
Re: Conversion:318/904 to 340/727 [Re: cudagerry] #572371
01/04/10 10:52 PM
01/04/10 10:52 PM
scratchnfotraction Offline
yes it does...takes less HP to turn the 904 also
wouldnt use a lopo lock up 904 for a performance rig though
A999 from a truck/van/cop car/5th ave would be a heavy duty unit
