Re: got some ?s for you guys
[Re: leavitt4]
#565154
12/28/09 07:10 PM
12/28/09 07:10 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
I know free is nice and all BUT if he is giving you that stuff with the stipulation you "HAVE" to use it in your car I would pass on the stuff and look for some cheap or free mopar stuff to use in the car or find a GM car to use the chevy stuff. I know its been done many,many times befor but Me personally,I would never use a Gm drivetrain in any of my mopars, If I had a GM drivetrain I would find a GM to put it in Thats just me so on to your questions, I have put camaro subframes under mopars but I like the Mustang II style frontends better. and I don't care for the 12 bolt rear ends with the "C" clips, a 8 3/4 is stronger and better to narrow, but you could have ford or mopar ends put on a 12 bolt, but you need the right axels to be able to shorten them or get after market ones(not cheap) Ron...
[Re: OzHemi]
#565162
01/07/10 12:22 AM
01/07/10 12:22 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
early stangs got an 8 inch, 4 1/2 bolt pattern,,and from what ive read drop right in to a mopar A body
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#565163
01/07/10 12:41 AM
01/07/10 12:41 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
K codes were 9" IIRC..(maybe A codes too?)
[Re: 1972cudaguy]
#565166
01/19/10 10:57 PM
01/19/10 10:57 PM
Posts: 10,588 Freeport IL USA
poorboy
Freeport IL USA
sometimes rodders overlook another front end swap that's not too hard . While the Mustang front end is one of the best for a narrower 30's + 40's car , there's the cross torsion bar Aspen F body set up . One of the Mopar mags had an article on it , can't recall which tho
Having put an F body front clip under a 35 Dodge, I can tell you they are too wide, and the torsion bars and subframe brackest extend beyond the front fenders of the mid 30s sheetmetal. There are other issues with the F body clip as well. Though they can be made to work, sort of, they are not the best choice for early (or any in my opinoin) street rod. And I'm a hard core Mopar guy. Gene
[Re: poorboy]
#565167
01/20/10 08:28 AM
01/20/10 08:28 AM
Posts: 684 Amherst , Ohio
1972cudaguy
Basement Office
Basement Office
Amherst , Ohio
I believe you're right there Gene . Maybe the article was for putting one under a late 40's , early 50's car which is a tad wider
