weight savings from power to man. steering??? #563825
12/27/09 10:45 AM
12/27/09 10:45 AM
duluth mn.
dragula426 Offline OP
duluth mn.
does anyone know the exact amount of weight savings by switching over to a manual box on a 69 b- body? totals for the power steering box, pump, fluid etc.?? i'm looking to save a few pounds, and am wondering if it's worth it. ( power steering is so nice on the street)
Re: weight savings from power to man. steering??? [Re: dragula426] #563826
12/27/09 10:58 AM
12/27/09 10:58 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
it was 26lbs total in my challenger..... I switched to the flaming river unit!
Mopar Performance
Re: weight savings from power to man. steering??? [Re: moparniac] #563827
12/27/09 11:06 AM
12/27/09 11:06 AM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
I had an aluminum housing "fast ratio" stock gear box{found in a junkyard},in my Cuda. iirc, mine was around 25-30 lbs different also. When I bought the car it had the heavy power gear box and the pump laying in the interior.
When you decide to quit, THAT is the moment when you would've succeeded..
Re: weight savings from power to man. steering??? [Re: KatFysh] #563828
12/27/09 11:41 AM
12/27/09 11:41 AM
Newark, OH
springers340dart Offline
Newark, OH
you'll also be gainging horsepower going to a manual box. one less thing the engine is turning.
Re: weight savings from power to man. steering??? [Re: springers340dart] #563829
12/27/09 12:51 PM
12/27/09 12:51 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I don't know if I buy that one. It's only robbing power if you're turning the wheel.
Re: weight savings from power to man. steering??? [Re: springers340dart] #563830
12/27/09 02:21 PM
12/27/09 02:21 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Not from my experience, which was worth 38 lbs. of weight loss and showed up as essentially nothing on the ET slip.
Re: weight savings from power to man. steering??? [Re: gsmopar] #563831
12/27/09 03:39 PM
12/27/09 03:39 PM
Newark, OH
Newark, OH
i'm not sure about that. its another pulley the engine is turning weather your turning or not. i may be wrong but i had an aspen that had power steering and ac and took both those off and picked up 3 - 4 tenths.
Re: weight savings from power to man. steering??? [Re: gsmopar] #563832
12/27/09 03:41 PM
12/27/09 03:41 PM
pennsylvania
poboyengineering Offline
pennsylvania
even if you dont use any torque in a straight line, there is significant weight in the pulley, pump rotor, and belt that must be accelerated. anytime you cut that weight, the engine will be happier.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: weight savings from power to man. steering??? [Re: poboyengineering] #563833
12/27/09 07:06 PM
12/27/09 07:06 PM
Toronto
mshred Offline
mshred  Offline
Toronto
but will it potentially even shave a tenth off your e/t? i can understand the weight savings, but does the pulley eat that much?
Re: weight savings from power to man. steering??? [Re: mshred] #563834
12/27/09 07:09 PM
12/27/09 07:09 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
On my mustang no powersteering belt was worth a tenth. This car already had an underdrive pulley as well. I used to keep a shorter belt with me that I would change at the track to bypass the power steering. I got lazy and just found that tenth elsewhere later on though.
68 Barracuda Formula S 340
Re: weight savings from power to man. steering??? [Re: Bad340fish] #563835
12/27/09 07:31 PM
12/27/09 07:31 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have seen a 8 HP gain( that is uasaully close to .08 at the track on a 3000 lb bracket car) on two differnt motors on two differnet engine dynos by removing a tight water pump belt only, no alternator or anything else being driven Besides it makes changing the spark plugs so much eaiser on the B-RB motors, no hurting your hands on the hot steering box in the summer Weight savings + comfort, priceless
