Re: weight savings from power to man. steering???
[Re: dragula426]
#563826
12/27/09 10:58 AM
12/27/09 10:58 AM
Posts: 6,295 U.S.
moparniac
U.S.
it was 26lbs total in my challenger..... I switched to the flaming river unit!
Mopar Performance
[Re: moparniac]
#563827
12/27/09 11:06 AM
12/27/09 11:06 AM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
I had an aluminum housing "fast ratio" stock gear box{found in a junkyard},in my Cuda. iirc, mine was around 25-30 lbs different also. When I bought the car it had the heavy power gear box and the pump laying in the interior.
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: springers340dart]
#563829
12/27/09 12:51 PM
12/27/09 12:51 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
you'll also be gainging horsepower going to a manual box. one less thing the engine is turning.
I don't know if I buy that one. It's only robbing power if you're turning the wheel.
#563830
12/27/09 02:21 PM
12/27/09 02:21 PM
BradH
Not from my experience, which was worth 38 lbs. of weight loss and showed up as essentially nothing on the ET slip.
[Re: gsmopar]
#563831
12/27/09 03:39 PM
12/27/09 03:39 PM
Posts: 189 Newark, OH
springers340dart
Newark, OH
i'm not sure about that. its another pulley the engine is turning weather your turning or not. i may be wrong but i had an aspen that had power steering and ac and took both those off and picked up 3 - 4 tenths.
[Re: gsmopar]
#563832
12/27/09 03:41 PM
12/27/09 03:41 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
even if you dont use any torque in a straight line, there is significant weight in the pulley, pump rotor, and belt that must be accelerated. anytime you cut that weight, the engine will be happier.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: mshred]
#563834
12/27/09 07:09 PM
12/27/09 07:09 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
On my mustang no powersteering belt was worth a tenth. This car already had an underdrive pulley as well. I used to keep a shorter belt with me that I would change at the track to bypass the power steering. I got lazy and just found that tenth elsewhere later on though.
68 Barracuda Formula S 340
