518 stuck in 2nd gear
#546918
12/06/09 12:08 PM
12/06/09 12:08 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
What would cause it to stick in 2nd gear? It is a 92 so I know it is not limp mode. It has manual low but if you take off in 2nd or D it just takes off in 2nd and stays there. Neutral Park and reverse are fine.
Re: 518 stuck in 2nd gear
[Re: HotRodDave]
#546919
12/06/09 12:20 PM
12/06/09 12:20 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
could be a stuck governor,a sticking TV or a stuck shift valve
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: HotRodDave]
#546921
12/06/09 08:14 PM
12/06/09 08:14 PM
Posts: 2,177 ill
dennismopar73
ill
i take it is a overdrive in a shadow?? or a van if its stuck in 2 it is in limp thats what they do it so you can drive to saftey you can try changing the 2 speed sensor 1 that is between the 2 trans lines right above the selinoid pack the other is straight across it about 8 " the 1 will moe than likley have a bunch of 'crap' on it there will be you're issue these are mangnets on the ends so they only pick up metal so you can guess whats wrong after that
[Re: dennismopar73]
#546922
12/07/09 11:13 AM
12/07/09 11:13 AM
HotRodDave
Kalispell Mt.
It is not stuck in limode because it is not computer controlled except the OD. There is also only one speed sensor. It is not a stuck throttle valve because it would shift either too high or too low but not just hang in one gear, especially second. It might be a hung govenor, I guess that could hang it in one gear.
[Re: HotRodDave]
#546923
12/07/09 12:07 PM
12/07/09 12:07 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
None of the 727 transmissions are computer controlled when it comes to 1/2/3 shifts except when you get into the RE trans with the electronic governor circuit. I used to know what caused this as we would have it happen on the Diesel trans we upgrade, start off in second, but I can't off the top of my head remember what caused it, something to do with pressure , but this was on an RE trans .... carry on
[Re: HotRodDave]
#546925
12/08/09 04:15 PM
12/08/09 04:15 PM
Posts: 25,854 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A test gauge on the governor pressure test port will tell you if the governor is the problem, if the governor tests OK the problem is likely a stuck 1-2 shift valve.
[Re: John_Kunkel]
#546926
12/09/09 10:38 AM
12/09/09 10:38 AM
HotRodDave
Kalispell Mt.
I don't have the truck in front of me right now so just asking if witch port is for the govenor? Isn't there one for the OD and one for govenor on the extension housing? I can't seem to find witch one is witch in AllmostData
[Re: HotRodDave]
#546928
12/09/09 01:27 PM
12/09/09 01:27 PM
JohnRR
U.S.S.A.
8psi @ idle 12 PSI @ 50
is that 50 MPH ?? if so that's low ...
[Re: gtx6970]
#546932
12/09/09 06:26 PM
12/09/09 06:26 PM
John_Kunkel
Rio Linda, CA
As Bill stated, the high pressure at idle is the reason it won't downshift and the low pressure at speed is the reason it won't upshift to 3rd. You need about 10 psi of governor pressure for every 10 mph.
[Re: John_Kunkel]
#546933
12/09/09 09:33 PM
12/09/09 09:33 PM
HotRodDave
Kalispell Mt.
Is there something in the VB that could cause this? There is no differance after all that.
On a side note I did notice the trans is a 94 and there is a recall for snow plows in 94, is there a way to update the spacer plate like the recall plate? Dodge won't sell me a plate and they won't install it because the truck is a 92 ramcharger, not the original one.
[Re: 70Challengerse]
#546935
12/10/09 01:33 AM
12/10/09 01:33 AM
HotRodDave
Kalispell Mt.
I am not new to this, I have rebuilt sucessfully many touque flites 3 and 4 spd, hydraulic and electronic. I am not a parts replacer, I am a profesional mechanic ASE master certified too, how many "parts replacers" do you know that happen to have a trans preasure tester or a very expensive Solus scanner? I also have enought spare parts in my garage to build another 4 of thease things from scratch but I just wanted to fix this one without building another and it has turned into fixing someone elses mess, just once in a while something comes along that just stumps a guy and so I figured a few more heads might be helpfull. Mabey I am just overthinking this and over looking something simple, so I thought I would ask for some ideas. To the rest of you, THANK YOU SO MUCH for the help! I noticed it has a shift kit in it, looks like a TF-2 with the updated preasure spring and stuff, mabey they screwed something up there
[Re: HotRodDave]
#546936
12/10/09 10:28 AM
12/10/09 10:28 AM
Posts: 644 Owego, NY
JBurch
Owego, NY
If it's not already in a little Nash Rambler, put it into a little Nash Rambler, look for a Cadillac, make sure your horn goes, Beep Beep, Beep Beep, Beep Beep Beep, pull up along side the Cadillac, roll down your window, and ask the driver of the Cadillac, "Hey Buddy how do I get this out of second gear........." Good luck, and have a Happy Holidays.
