518 stuck in 2nd gear #546918
12/06/09 12:08 PM
12/06/09 12:08 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
What would cause it to stick in 2nd gear? It is a 92 so I know it is not limp mode. It has manual low but if you take off in 2nd or D it just takes off in 2nd and stays there. Neutral Park and reverse are fine.
Re: 518 stuck in 2nd gear [Re: HotRodDave] #546919
12/06/09 12:20 PM
12/06/09 12:20 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
could be a stuck governor,a sticking TV or a stuck shift valve
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 518 stuck in 2nd gear [Re: dusturbd340W5] #546920
12/06/09 03:39 PM
12/06/09 03:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Make sure the kickdown moves freely.
Re: 518 stuck in 2nd gear [Re: HotRodDave] #546921
12/06/09 08:14 PM
12/06/09 08:14 PM
ill
dennismopar73 Offline
ill
i take it is a overdrive in a shadow??
or a van
if its stuck in 2 it is in limp thats what they do
it so you can drive to saftey
you can try changing the 2 speed sensor
1 that is between the 2 trans lines right above the selinoid pack
the other is straight across it about 8 "
the 1 will moe than likley have a bunch of 'crap' on it
there will be you're issue
these are mangnets on the ends so they only pick up metal
so you can guess whats wrong after that
Re: 518 stuck in 2nd gear [Re: dennismopar73] #546922
12/07/09 11:13 AM
12/07/09 11:13 AM
Kalispell Mt.
Kalispell Mt.
It is not stuck in limode because it is not computer controlled except the OD. There is also only one speed sensor. It is not a stuck throttle valve because it would shift either too high or too low but not just hang in one gear, especially second. It might be a hung govenor, I guess that could hang it in one gear.
Re: 518 stuck in 2nd gear [Re: HotRodDave] #546923
12/07/09 12:07 PM
12/07/09 12:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
None of the 727 transmissions are computer controlled when it comes to 1/2/3 shifts except when you get into the RE trans with the electronic governor circuit.
I used to know what caused this as we would have it happen on the Diesel trans we upgrade, start off in second, but I can't off the top of my head remember what caused it, something to do with pressure , but this was on an RE trans ....
carry on
Re: 518 stuck in 2nd gear [Re: HotRodDave] #546924
12/07/09 11:40 PM
12/07/09 11:40 PM
Kissimmee Fl.
Kissimmee Fl.
I run a trans shop and can tell you a stuck gov,a stuck 1-2 shift valve will cause a 2nd gear start and I have seen a stuck TV valve do weird things other that early or late shifts.
Re: 518 stuck in 2nd gear [Re: HotRodDave] #546925
12/08/09 04:15 PM
12/08/09 04:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A test gauge on the governor pressure test port will tell you if the governor is the problem, if the governor tests OK the problem is likely a stuck 1-2 shift valve.
Re: 518 stuck in 2nd gear [Re: John_Kunkel] #546926
12/09/09 10:38 AM
12/09/09 10:38 AM
Kalispell Mt.
Kalispell Mt.
I don't have the truck in front of me right now so just asking if witch port is for the govenor? Isn't there one for the OD and one for govenor on the extension housing?
I can't seem to find witch one is witch in AllmostData
Re: 518 stuck in 2nd gear [Re: HotRodDave] #546927
12/09/09 11:27 AM
12/09/09 11:27 AM
Kalispell Mt.
Kalispell Mt.
8psi @ idle
12 PSI @ 50
Re: 518 stuck in 2nd gear [Re: HotRodDave] #546928
12/09/09 01:27 PM
12/09/09 01:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
8psi @ idle
12 PSI @ 50
is that 50 MPH ?? if so that's low ...
Re: 518 stuck in 2nd gear [Re: JohnRR] #546929
12/09/09 01:46 PM
12/09/09 01:46 PM
Kalispell Mt.
Kalispell Mt.
Yes 50mph. I figured it was low so I pulled the governor and the little valve was stuck a little so I polished it up a little with some steel whool and it moves freely now. I hope thats all the problem was, now if I can figure out how the governor goes back together
Re: 518 stuck in 2nd gear [Re: HotRodDave] #546930
12/09/09 01:59 PM
12/09/09 01:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 518 stuck in 2nd gear [Re: stumpy] #546931
12/09/09 02:03 PM
12/09/09 02:03 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
gov pressure has to be under 3 psi at stops in gear or it will not downshift to first
Re: 518 stuck in 2nd gear [Re: gtx6970] #546932
12/09/09 06:26 PM
12/09/09 06:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As Bill stated, the high pressure at idle is the reason it won't downshift and the low pressure at speed is the reason it won't upshift to 3rd. You need about 10 psi of governor pressure for every 10 mph.
Re: 518 stuck in 2nd gear [Re: John_Kunkel] #546933
12/09/09 09:33 PM
12/09/09 09:33 PM
Kalispell Mt.
Kalispell Mt.
Is there something in the VB that could cause this? There is no differance after all that.
On a side note I did notice the trans is a 94 and there is a recall for snow plows in 94, is there a way to update the spacer plate like the recall plate? Dodge won't sell me a plate and they won't install it because the truck is a 92 ramcharger, not the original one.
Re: 518 stuck in 2nd gear [Re: HotRodDave] #546934
12/09/09 11:20 PM
12/09/09 11:20 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline
Take it to someone who knows what to do with it....your not putting brakes on it ..don't become a parts replacer it needs to be diagnosed ...correctly.
Re: 518 stuck in 2nd gear [Re: 70Challengerse] #546935
12/10/09 01:33 AM
12/10/09 01:33 AM
Kalispell Mt.
Kalispell Mt.
I am not new to this, I have rebuilt sucessfully many touque flites 3 and 4 spd, hydraulic and electronic. I am not a parts replacer, I am a profesional mechanic ASE master certified too, how many "parts replacers" do you know that happen to have a trans preasure tester or a very expensive Solus scanner? I also have enought spare parts in my garage to build another 4 of thease things from scratch but I just wanted to fix this one without building another and it has turned into fixing someone elses mess, just once in a while something comes along that just stumps a guy and so I figured a few more heads might be helpfull. Mabey I am just overthinking this and over looking something simple, so I thought I would ask for some ideas.
To the rest of you, THANK YOU SO MUCH for the help!
I noticed it has a shift kit in it, looks like a TF-2 with the updated preasure spring and stuff, mabey they screwed something up there
Re: 518 stuck in 2nd gear [Re: HotRodDave] #546936
12/10/09 10:28 AM
12/10/09 10:28 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
If it's not already in a little Nash Rambler, put it into a little Nash Rambler, look for a Cadillac, make sure your horn goes, Beep Beep, Beep Beep, Beep Beep Beep, pull up along side the Cadillac, roll down your window, and ask the driver of the Cadillac, "Hey Buddy how do I get this out of second gear........."
Good luck, and have a Happy Holidays.
Re: 518 stuck in 2nd gear [Re: HotRodDave] #546937
12/10/09 12:23 PM
12/10/09 12:23 PM
ill
ill
this is a test only a test
