Page 4 of 5 1 2 3 4 5
Re: Ring & Pinion pattern help needed PLEASE! [Re: VernMotor] #514004
11/07/09 01:48 PM
11/07/09 01:48 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Just a thought, went back and looked at some of the pix, were the tubes welded at housing ?
If housing was maybe at one time repaired with heat or pinion race bore repaired , LIKE MY 60, pretty much impossible to get a textbook pattern
Re: Ring & Pinion pattern help needed PLEASE! [Re: RussW] #514005
11/07/09 04:18 PM
11/07/09 04:18 PM
Erda, UT
67Charger Offline OP
Erda, UT
Not as far as I know, but it is just a $100 housing from a Ford pickup, so who really knows. No tube-to-housing welds. I brought the pictures down to Bob Lambeck since I had to go by there anyway, and he said run it. The conflicting/angled patterns show that this set may be impossible to get "perfect", but it is well within the acceptable range as is. I'll still measure the housing as Bob George suggested.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #514006
11/07/09 04:40 PM
11/07/09 04:40 PM
Cab_Burge Online work
Cab_Burge  Online Work
Dan, the used Dana 4.10 OEM gear set I put in my Duster (same housing as yours probally, 3.125 axle tubes diameter) looked decent on the drive side but I could not get a decent looking pattern on the coast side, I did have to have the gear set glass beaded to get the rust off of it before trying to set it up I tried sevral different depths and ended up leaving it looking like your latest one It is quiet and faster than the 8 3/4 was I agree with "Bucks up" Bob on running it the way it is now
Re: Ring & Pinion pattern help needed PLEASE! [Re: Cab_Burge] #514007
11/08/09 10:09 AM
11/08/09 10:09 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Not telling you what to do,just some more advise. Take it to a reputable mechanic with experience and have him recheck everything.What do you have to lose after all the time you spent,and minimize your risk of ruining a good set of gears. He might find the problem and you will be more knowledgable for your next set.
Re: Ring & Pinion pattern help needed PLEASE! [Re: B G Racing] #514008
11/08/09 10:54 AM
11/08/09 10:54 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I wouldn't run it like that. that thing will knife edge the gears before long. I would send them back to strange if I were confident it wasn't something else before running them. send them the pics and see what they tell you.
Re: Ring & Pinion pattern help needed PLEASE! [Re: Quicktree] #514009
11/08/09 09:11 PM
11/08/09 09:11 PM
Erda, UT
Erda, UT
Axle centerline is .046 above (away from the pinion) the mating surface of the caps.
3.125 - .046 = 3.079
I need to get the top of the pinion 3.079" below the cap face? I measure to the shiny machined face, right?
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #514010
11/09/09 12:37 AM
11/09/09 12:37 AM
Erda, UT
Erda, UT
Just measured it... Currently I'm coming up with 3.107" from the bearing cap mating surface to the machined face of the pinion.
3.107 - 3.079 = .028 more shim needed.
If I add .028 more shim, I don't think there is any way I'll make it fit back together. That will put me at .071 beind the pinion. My first set of pics in this post (Attempt #17) was with it at .060, and everyone said pull out, less shim.
Something's not adding up.
Re: Ring & Pinion pattern help needed PLEASE! [Re: B G Racing] #514011
11/09/09 02:07 AM
11/09/09 02:07 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
If you don't know the correct pinion depth it can be calculted by measuring the thickness of the pinion head and subtracting it from the mounting distance for a Dana 60(3.125").The difference will be the depth that the pinion should be installed.If your pinion is marked +- a number,add or subtract it in thousands to your pinion depth.
Actually pinion depth for a Dana 60 is 5.000" minus pinion head thickness.
Re: Ring & Pinion pattern help needed PLEASE! [Re: 446acuda] #514012
11/09/09 02:29 AM
11/09/09 02:29 AM
Erda, UT
Erda, UT
0.046 surface below centerline
3.107 surface to pinion face
1.844 pinion thickness
4.997
This is well within the stacked tolerances of my measuring methods.
Ths says I am very close. Whay would the pattern not come with it? The coast pattern has consistently stayed slanted throughout the range of adjustments I've made.
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #514013
11/09/09 02:35 AM
11/09/09 02:35 AM
Dan, do you have the instruction sheet from Strange for those type and material gears? If not I do, I will look at that sheet if you want me to or I can FAX or mail you a copy if you want I think Strange instructions shows a lot different acceptable patterns than the Mopar service manuls and the instructions from Richmond do
Re: Ring & Pinion pattern help needed PLEASE! [Re: Cab_Burge] #514014
11/09/09 02:39 AM
11/09/09 02:39 AM
Erda, UT
Erda, UT
The gears did not have ANY paperwork with them... If you can fax them I would really appreciate it. Unfortunately, I only have a fax at my office which will open at 7am tomorrow. I'll PM you my number.
Thanks!
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #514015
11/09/09 02:41 AM
11/09/09 02:41 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
what measuring tool did you use to measure the cap mating surface to the bottom of the bearing bore?
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #514016
11/09/09 02:45 AM
11/09/09 02:45 AM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
Re: Ring & Pinion pattern help needed PLEASE! [Re: 446acuda] #514017
11/09/09 02:54 AM
11/09/09 02:54 AM
Erda, UT
Erda, UT
I used 3 methods with results within .001 of each other.
1) straightedge across the face with digital calipers measuring between the bottom of the bore and the edge
2) same straightedge across the bore, but used the depth probe on the bottom and subtracted the thickness of the edge
3) Inserted the race, and used the straightedge across the cover mounting surface and used feelers to measure the gap between the race and surface, then measured down from the edge to the mating surface, subtracted the gap between the race and the edge, and that told me how much of the cup was ABOVE the mating surface. subtract 1/2 of the race OD, and that gave me the C/L distance above the surface.
These are $300 Fowler certified/calibrated digital calipers, not some cheapie set.
My inaccuracy comes from measuring down to the pinion face. My straightedge won't quite span the case directly over the pinion. I can just barely catch the edge of the machined face, so I may be .001 or .002 off.
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #514018
11/09/09 03:08 AM
11/09/09 03:08 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
so the depth probe had a ball end? I was wondering if you may have used a flat end depth micrometer that wouldn't actually touch the bottom, giving you a low measurement, but that doesn't look like that's the case...especially since you hit it within .001" using different methods.
Re: Ring & Pinion pattern help needed PLEASE! [Re: 446acuda] #514019
11/09/09 08:01 AM
11/09/09 08:01 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Check to make sure the cap is cut on the c/l.
DO NOT assume that it is cut perfectly when measuring to the top of the pinion.
Re: Ring & Pinion pattern help needed PLEASE! [Re: Cab_Burge] #514020
11/09/09 08:36 AM
11/09/09 08:36 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Don't we love setting up Dana spicer rear ends, especially the Dana 60 Do you have a set of set up bearings? If not get some I remember paying Bob Lambeck $75.00 to set the gears up in my Dana for the four speed Hemi Cuda, best money ever spent I charge $150.00 now and it still takes 8 hrs+ to do one usually
It took me two-half days. I had to walk away from it on the first day I was so frustrated.
The best pattern that I achieved was made getting the pinion depth right-on to what the manufacturer recommended. The problem is the depth changed when preload was applied to the pinion, so it was a lot of trial and error.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Ring & Pinion pattern help needed PLEASE! [Re: The Shadow] #514021
11/09/09 10:21 AM
11/09/09 10:21 AM
Erda, UT
Erda, UT
What does the cap have to do with it?
I'm measuring from the mating surface, not the cap. Are you suggesting the cap may be cut too deep and bottoming before securing the bearing, therefore allowing movement?
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #514022
11/09/09 10:40 AM
11/09/09 10:40 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
The bottom line is always the pattern. Even if you put it in with a tool it still gets tweaked by looking at the pattern. I don't know why your coast is looking like it does but i am not there. you have been all over with the pinion shim and this is the best you have gotten. If you are sure this is the best you can get and all the preloads are right run it.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Ring & Pinion pattern help needed PLEASE! [Re: bigtimeauto] #514023
11/09/09 11:20 AM
11/09/09 11:20 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
