Re: 70 Challenger T/A - Engine Detailing - Whats correct?
[Re: Troy]
#511181
11/06/09 09:30 AM
11/06/09 09:30 AM
Posts: 2,304 WI
RestoRick
WI
Here is a photo of the cowl. You can see how the yellow goes over the top of the back paint. Even in this photo it look like a smooth black paint.
Correct, the black was applied first, then masked off before the topcoat color. As Troy points out, you can see some bleed back of topcoat color under the masking. Non TA/AAR cars had the blackout applied after topcoat color.
As for the type of black... my belief is it was organisol. I have a perfect organisol sample on hand right now; it's a very fine texture, that can be easily mistaken for smooth especially if dirty & aged. Logic... AAR's were painted in the same sequence... however, the AAR also had the fender tops, door & quarter upper edges sprayed at the same time as the cowl & fender banding. Why would two different kinds of black be used?
The real dead give away to identify it is to clean it well and look close to see the metallic flecks.
Rick
[Re: Troy]
#511184
11/06/09 12:34 PM
11/06/09 12:34 PM
Posts: 2,304 WI
RestoRick
WI
Doing great Troy! Very possible... I haven't seen them all Funny how anytime words like "detailing, details, OE, etc." are in a thread subject, how fast the topic drifts!!
[Re: autoxcuda]
#511185
11/06/09 12:48 PM
11/06/09 12:48 PM
Posts: 1,102 Ont, Canada
moparo
Ont, Canada
yes all before color was applied
performancecarrestorations.com
[Re: moparo]
#511186
11/06/09 01:36 PM
11/06/09 01:36 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
The valve cover looks to be later with the raise circle in the front.
Not sure what you mean by "later"? It is a 1970 car & the photo was taken in 1970.
The low mile T/A has the same style.
Since more than one style of washer bottle was available, I am sure it was pretty random as to which one ended up on which car.
[Re: Alaskan_TA]
#511187
11/06/09 01:42 PM
11/06/09 01:42 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
On the blackout.... One of the engineering drawings states; "Apply blackout paint or organisol paint in areas indicated" This is no doubt why some of you have found original cars one way or the other.
[Re: moparo]
#511188
11/06/09 01:44 PM
11/06/09 01:44 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
With the exception of the rocker pinchweld area.
[Re: RestoRick]
#511189
12/04/09 03:19 PM
12/04/09 03:19 PM
Posts: 679 N. Dak.
RareTA
super street
super street
N. Dak.
Rick
I dissagree with the black first. This is the tear down of my T/A. You can see in this photo the yellow was first then the black. Download the pic and enlarge it.
[Re: RareTA]
#511190
12/05/09 02:36 PM
12/05/09 02:36 PM
Posts: 18,157 Mass
DAYCLONA
Mass
As with "mass production" of anything, cars, trucks, kids toys, etc,....there may be factory prints, procedures, etc, they all change as production gets underway, some are due to mistakes, some are due to "experimentation", or penny pinching as production is underway,...in the case of different blacks, for black outs,....might have run out of "that" paint that day, and substituted something else, or a certain procedure was done at another work station on the line and Gomer used the "wrong" paint, or what was substitued on purpose or accident ,....back in the day it was Human intervention/mistakes on the line, not robots programed with a set of perimeters
[Re: DAYCLONA]
#511191
02/26/15 10:58 AM
02/26/15 10:58 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Mike, This thread is a blast... Now that I have my own T/A, I'm discovering things... One of my latest detailing questions is the center carb vent and it's relationship with the breather on the pass. valve cover. I see in the picture above and your factory illustration, the 340 pictures had all three nipples; 1. air cleaner base 2. Carb float bowl vent 3. gas tank vent
I thought #3 was only for California Emissions cars in '70 and then bacame standard on all cars starting in '70. I have seen a lot of T/A's and AAR's and haven't seen many, if any, with the gas tank vent. If that's the case and it was only for California emissions, then a production T/A and AAR would have the breather with 2 nipples, both on top, not the bottom-smallest one for the gas tank vent line...
No?
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: Alaskan_TA]
#511194
02/27/15 01:39 AM
02/27/15 01:39 AM
hemi68charger
Houston, Tx
On the non-N95 cars the port on the middle carb was open to the atmosphere.
Get out of here !!!! Well, I would have never thought that.... Thanks Barry....
[Re: mopar346]
#511196
02/27/15 05:20 PM
02/27/15 05:20 PM
Posts: 4,952 northwest USA
NANKET
northwest USA
The question I have been running through my mind is was there a stub hose attached or was it bare.
The one at Wellborn's has one and pictures of my car right out of the barn has none. I run with none and believe it correct.
Please define "right out of the barn", are we talking Hamtramck, MI in the spring of 1970? Or sometime later. As you know those will pull out quite easily sometimes.
[Re: mopar346]
#511198
02/28/15 12:30 AM
02/28/15 12:30 AM
hemi68charger
Houston, Tx
...The one at Wellborn's has one and pictures of my car right out of the barn has none. I run with none and believe it correct.
I'm supposed to talk to Tim tonight or this weekend, I'll ask him. Do you have any pictures of what you're talking about.
[Re: hemi68charger]
#511200
02/28/15 02:28 AM
02/28/15 02:28 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
This is on his blue TA, a survivor from all accounts.
Careful, your character's showing!
