Hemi Heater Adapters #507655
10/26/09 09:54 AM
10/26/09 09:54 AM
Oregon,USA
RAT PATROL Offline OP
Oregon,USA
Who makes the adapters on the front of the 392 Hemi heads for running a heater? I am running a chev water pump. The thermostat is on the drivers head but I need basically a Tee on the passenger head for the crossover and heater hose attachment.
Re: Hemi Heater Adapters [Re: RAT PATROL] #507656
10/26/09 11:11 AM
10/26/09 11:11 AM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
I am running a big block Chevy water pump on my 392 and the pump has 2 threaded holes I assumed were for the heater hoses. Its a little hard to see, but one of the holes is right on top of the pump.
Arno
Re: Hemi Heater Adapters [Re: RAT PATROL] #507657
10/26/09 02:27 PM
10/26/09 02:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Hemi Heater Adapters [Re: John_Kunkel] #507658
10/26/09 06:25 PM
10/26/09 06:25 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
If there is room, you could possibly come off the water ports on the back of the cylinder heads. HotHeads part number 21603. Tell Bob that I sent you.
TR Waters
Re: Hemi Heater Adapters [Re: TrWaters] #507659
10/27/09 09:28 AM
10/27/09 09:28 AM
Oregon,USA
Oregon,USA
The motor on the stand is one I built for my sister. This is my motor and it has (had) a hot heads crossover, but I want to put a heater in the car, cool nights in the northwest. I guess I can just add a tee on the passenger side head for heater supply and tee into the inlet side of the pump for the return. I paid to have this done, shop went out of business, did not get all my parts back, or money. Glad I didn't lose the car.
Re: Hemi Heater Adapters [Re: RAT PATROL] #507660
10/29/09 12:20 AM
10/29/09 12:20 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
as said in earlier post ,,,HOT HEADS has what you want,,or as said,, hot heads also has a aluminum plate that you can use on the back of the head,,same location as in the front of the head for the cross over,,,hot heads aluminum plate is thereaded for a pipe fitting ,,which works out well or you can do what i did,before hot heads came out with this nice looking plate,,,
get a piece of flat plate,,drill it for the mounting holes,,weld a bung on it for the pipe,,on side of your heater needs to come from a hotter source then the water pump,,2 hoses running off the water wont produce much heat at all,,then a plate on the other side to hide your engine temp sender,,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Hemi Heater Adapters [Re: fstfish66] #507661
11/02/09 10:52 AM
11/02/09 10:52 AM
Oregon,USA
Oregon,USA
Waiting for parts for the heater so I thought I'd piddle around in the trunk for a while. What is it you ask.
Re: Hemi Heater Adapters [Re: RAT PATROL] #507662
11/11/09 12:01 AM
11/11/09 12:01 AM
Oregon,USA
Oregon,USA
Not getting anything done from LA but will be back home in a couple weeks and start again.
Re: Hemi Heater Adapters [Re: RAT PATROL] #507663
11/12/09 02:07 AM
11/12/09 02:07 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
sweet,,,,,,,,,,,
2015 cherokee
2013 R/T classic
Re: Hemi Heater Adapters [Re: fstfish66] #507664
11/23/09 10:37 AM
11/23/09 10:37 AM
Oregon,USA
Oregon,USA
I had Sunday off, so after the storm and power outage I began again.
Re: Hemi Heater Adapters [Re: RAT PATROL] #507665
11/23/09 10:39 AM
11/23/09 10:39 AM
Oregon,USA
Oregon,USA
And then I got out the big hammer.
Re: Hemi Heater Adapters [Re: RAT PATROL] #507666
11/23/09 10:42 AM
11/23/09 10:42 AM
Oregon,USA
Oregon,USA
I tried to hide the hoses as much as possible.
Re: Hemi Heater Adapters [Re: RAT PATROL] #507667
11/30/09 10:33 AM
11/30/09 10:33 AM
Oregon,USA
Oregon,USA
And then I added some fuel lines, what else do you do on thanksgiving.
Re: Hemi Heater Adapters [Re: RAT PATROL] #507668
11/30/09 11:40 AM
11/30/09 11:40 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
loooks great, i agree EAT then go out to the garage,, i pulled my rear apart swapping from a 4.56 to a 3.91 in my barracuda
2015 cherokee
2013 R/T classic
