Re: Hemi Heater Adapters
[Re: RAT PATROL]
#507656
10/26/09 11:11 AM
10/26/09 11:11 AM
Posts: 1,039 Redwood City Ca.
B1arno
Redwood City Ca.
I am running a big block Chevy water pump on my 392 and the pump has 2 threaded holes I assumed were for the heater hoses. Its a little hard to see, but one of the holes is right on top of the pump. Arno
[Re: RAT PATROL]
#507660
10/29/09 12:20 AM
10/29/09 12:20 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
as said in earlier post ,,,HOT HEADS has what you want,,or as said,, hot heads also has a aluminum plate that you can use on the back of the head,,same location as in the front of the head for the cross over,,,hot heads aluminum plate is thereaded for a pipe fitting ,,which works out well or you can do what i did,before hot heads came out with this nice looking plate,,,
get a piece of flat plate,,drill it for the mounting holes,,weld a bung on it for the pipe,,on side of your heater needs to come from a hotter source then the water pump,,2 hoses running off the water wont produce much heat at all,,then a plate on the other side to hide your engine temp sender,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#507661
11/02/09 10:52 AM
11/02/09 10:52 AM
Posts: 406 Oregon,USA
RAT PATROL
Oregon,USA
Waiting for parts for the heater so I thought I'd piddle around in the trunk for a while. What is it you ask.
[Re: RAT PATROL]
#507663
11/12/09 02:07 AM
11/12/09 02:07 AM
fstfish66
levittown pa
sweet,,,,,,,,,,,
[Re: RAT PATROL]
#507668
11/30/09 11:40 AM
11/30/09 11:40 AM
fstfish66
levittown pa
loooks great, i agree EAT then go out to the garage,, i pulled my rear apart swapping from a 4.56 to a 3.91 in my barracuda
