Alright, I'm at a loss - my engine's killing carbs *DELETED* #505231
10/24/09 12:35 PM
10/24/09 12:35 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Post deleted by sharpie
Re: Alright, I'm at a loss - my engine's killing carbs [Re: sharpie] #505232
10/24/09 12:41 PM
10/24/09 12:41 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Carb diagnosis without being there is next to impossible, but as a guess? I'd say you still have a fuel contamination issue somewhere.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: sharpie] #505233
10/24/09 12:43 PM
10/24/09 12:43 PM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
I don't know that this will fix your problem but if your filter was full of junk I would remove the tank, clean it out and blow out the lines. You might be getting garbage in your carb(s).
Re: Alright, I'm at a loss - my engine's killing carbs [Re: ScottSmith_Harms] #505234
10/24/09 12:45 PM
10/24/09 12:45 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I fought carb problems for months once, changed them out, rebuilt, etc. It turned out that the laser pickup im my malory ignition was dusty.
2 seconds with a q-tip fixed it.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: sharpie] #505235
10/24/09 12:50 PM
10/24/09 12:50 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
May not be your problem, just going to "toss" it out there,.......sounds very similar to a "ghost" problem I onced chased, it was eventualy found to be very minute rust particles, unseen by the human eye that were clogging/gunking up the fuel system,....apon initial tank inspection the tank seemed clean,.....but condensation (from sitting) had formed fine rust particles on the ceiling of the gas tank, didn't find this until I had rebuilt the carb, replaced the pump, the fuel filter, replaced the fuel lines, etc, etc ,......finally after still having bouts of intermitten days of good and bad running, I finally installed a clear sight, smallest micron gas filter I could, then the rust started showing up on the screen, the rust, being so small, was more like a film, not particles, but none the less it was clogging the small passages of the carb,.....replaced the tank, flushed the system, never had a problem afterwards
Mike
Re: Alright, I'm at a loss - my engine's killing carbs [Re: Alaskan_TA] #505236
10/24/09 12:52 PM
10/24/09 12:52 PM
Queens, NYC
Racer413 Offline
Racer413  Offline
Queens, NYC
sounds like a vacuum leak. I'd guess the base gasket since you change the carb and it goes away for a bit. Maybe the mount flange on the manifold is warped. Try doubling the gaskets.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: sharpie] #505237
10/24/09 12:58 PM
10/24/09 12:58 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I then found that the fuel filter was full of garbage, so I replaced it.
That old fuel filter that you replaced, how old was it? Did you ever replace it?
You bought this car non running, correct?
Have you unscrewed the gas tank sending unit and look inside? Are you sure it still has a tank "sock" (screen filter) on it?
Re: Alright, I'm at a loss - my engine's killing carbs [Re: DAYCLONA] #505238
10/24/09 01:03 PM
10/24/09 01:03 PM
take the carb off & flush it good w starting fluid & hang a container of clean gas above it like a bag of plasma in a hospital & now see if your OK
Re: Alright, I'm at a loss - my engine's killing carbs [Re: Racer413] #505239
10/24/09 01:05 PM
10/24/09 01:05 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
It sounds like the fuel has trash in it, most likely rust or something stopping up the carbs, if it was ignition, it would most likely act the same with any carb, even a vacuum leak, i would check the fuel filter (cut it open) to see whats in it, there must be small particals getting through & stopping up the metering in the carbs, this will cause idle issues & stalling/hard starting.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Alright, I'm at a loss - my engine's killing carbs [Re: autoxcuda] #505240
10/24/09 01:06 PM
10/24/09 01:06 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Could fuel really be giving me intermittent problems like this?
The fuel filter I replaced was actually pretty new. I know some garbage is coming through the lines. Maybe it's time to clean the tank, because I haven't messed with any of that yet.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: sharpie] #505241
10/24/09 01:11 PM
10/24/09 01:11 PM
So Cal
So Cal
Yes, yes.. The time is now.
If you can see a "bunch of garbage" in the little amount if miles you've put on that new fuel filter you need to follow the issue upstream. "some garbage" is too much garbage.
Do you have pictures of the fuel filter garbage you have in it now? How many miles on this second? filter?
Re: Alright, I'm at a loss - my engine's killing carbs [Re: ScottSmith_Harms] #505242
10/24/09 01:11 PM
10/24/09 01:11 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Sounds like the small passages are getting clogged in areas you can't clean easily during a carb rebuild. I have a junk brand new 600 Edelbrock a customer put on without a fuel filter because the previous carb "stopped working". When I pulled the tank tons of the most fossilized gas and crud I've ever seen came out. The bottom of the float bowls had a cement like substance that was impervious to a 48 hour carb cleaner soak. I suspect that same substance is inside the small passages I can't get to with a small wire and compressed air does not push it out.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: sharpie] #505243
10/24/09 01:13 PM
10/24/09 01:13 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I don't build a car without replacing the tank the lines and the pick up. 40 year old sludge builds up and breaks away slowly. I've cut solid looking lines only to have them crumple from rot.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: sharpie] #505244
10/24/09 01:14 PM
10/24/09 01:14 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Allot of these guys are giving you good advice. I make it a plan to replace the gas tank (or at least have it boiled and sealed which often costs more than a new tank) and most other fuel related wear items with just about any old car I buy, most of them will benifit from it because tank rust and varnish build up is so common and can easily cause ongoing fuel contamination headaches.
If I were you I'd start shopping for a new tank, sending unit, assosiated small rubber lines & clamps, a new filter, and flush the heck out of the new fuel pump and carb (I'd probably tear down the carb again to be sure it's clean) that will likely end your problems, and if it turns out to be something else it sure wouldn't hurt in the long run to do it anyway.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: ScottSmith_Harms] #505245
10/24/09 02:00 PM
10/24/09 02:00 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Alright, so I am going to cut my losses right now and sell it. I don't have the money for all of this anymore. I've already put too much into the car to begin with, and it's nowhere near where I want it.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: sharpie] #505246
10/24/09 02:08 PM
10/24/09 02:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
You're giving up that easy? Heck it's not that expensive, all in you'll probably only spend $300.00 or so, and that's a reach.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: ScottSmith_Harms] #505247
10/24/09 02:15 PM
10/24/09 02:15 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
You'd never believe it if you saw what I was paid annually, but I am having serious issues with money right now, and probably will continue for the next, oh, 19 years or so.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: ScottSmith_Harms] #505248
10/24/09 02:17 PM
10/24/09 02:17 PM
So Cal
So Cal
I saw new tanks a Fall Fling for $170 or so.
A raditor shop might clean it out for $50. A new sending unit pickup screen is under $10.
Fact is, if you want to sell it you have to get it running. The loss in selling it the way it's running now is more than $300.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: sharpie] #505249
10/24/09 02:25 PM
10/24/09 02:25 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Try taking the two air mixture screws out spraying some carb cleaner down inside them. Blow some compressed air into the holes if you can.
Find another carb to borrow that you know runs right. This way you can isolate if it's the carb or dirt in the fuel system. Find another member who lives close to help you sort it out if you have to.
Re: Alright, I'm at a loss - my engine's killing carbs [Re: Neil] #505250
10/24/09 03:22 PM
10/24/09 03:22 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
It does sound like a large vaccuum leak. Check the back of the intake manifold. I put an intake manifold on a small block one time and there was a space on the rear between the manifold and block. I did not notice it at first because when I first put the manifold on, in ran like a raped ape. About a week later it was acting exactly as you stated above. I replaced the car with one I knew was good and same thing. The firewall did not give access to see it. It was on a derby car (5th ave). When I cut the firewall out from the inside to make clearance for the dist, I could see it plain as day, part of the intake manifold gasket was missing. It was only a derby car so I wadded some RTV in there rather than replacing the intake gasket, problem solved. I am not saying this is the corresct way, but check the intake manifold gaskets. Don't over look the cheap fix.
Good Luck
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
