changing exhaust manifold #484021
09/30/09 09:17 AM
09/30/09 09:17 AM
Slidell, la.
1BAD383 Offline OP
08 SRT Challenger
1BAD383  Offline OP
08 SRT Challenger
Slidell, la.
The driver side exhaust manifold cracked. Got another manifold and gaskets. The front stud stayed in and removed the nut. The next 3 were bolts, which came out. The next was a stud that came out. The last one was the long special bolt that came out. Replaced the 3 old bolts with stainless steel bolts and lock washers. Replaced the stud that came out with a new steel stud and reused the long special bolt. Used ultra copper high temp RTV silicone gasket maker on the bolts and the stud that was replaced. Cleaned all the treads. I have a leak. Did I use the wrong silicone.
Re: changing exhaust manifold [Re: 1BAD383] #484022
09/30/09 09:31 AM
09/30/09 09:31 AM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Ultra copper seems to be what most recommend. May have to let it sit overnight before refilling. The only thing I can think of that might have gone wrong is the special bolt is actually a special nut on a stud which came out when you took it apart. When you put it back together the stud may have barely started in the head and then the special nut may have tightened on the stud, with the stud not being far enough in the head to seal. That's just a guess of course! Good luck!
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: changing exhaust manifold [Re: johnedod] #484023
09/30/09 09:39 AM
09/30/09 09:39 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
www.remflex.com
last gaskets you will buy
