best way to clean a aluminum 6pak intake #470312
09/16/09 08:44 PM
09/16/09 08:44 PM
chicago Burbs
demoned Offline OP
demoned  Offline OP
chicago Burbs
hello all what would be the best way to clean my 6pk intake my my 340 and what does LD6B stand for on it thks ed
Re: best way to clean a aluminum 6pak intake [Re: demoned] #470313
09/16/09 09:58 PM
09/16/09 09:58 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
take it to your local autoparts and have it glass beeded , wash it good in warm soapy water befor you install it . it will look new !
ld = small block 6b = 6 bbl , it is a later edition not a 1970/71 .
Re: best way to clean a aluminum 6pak intake [Re: calrobb2000] #470314
09/16/09 10:25 PM
09/16/09 10:25 PM
CT USA
N
Nick Mineau Offline
Nick Mineau  Offline
N
CT USA
hi
you can polish it after that for a nice shine
Re: best way to clean a aluminum 6pak intake [Re: Nick Mineau] #470315
09/16/09 10:58 PM
09/16/09 10:58 PM
IN
ahy Offline
ahy  Offline
IN
Higher end rebuild/reman shops glass bead and wash. Home remedies include oven cleaner, simple green and the dish washer.
Re: best way to clean a aluminum 6pak intake [Re: ahy] #470316
09/17/09 12:26 AM
09/17/09 12:26 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Ford PM1 or PM2 Idle control cleaner (spray or bottle) does very well on unpainted cast aluminum. Let it sit, scrub, then compress air dry.
I think it's got a lot of ammonia in it. Smells like it.
Re: best way to clean a aluminum 6pak intake [Re: autoxcuda] #470317
09/17/09 12:30 AM
09/17/09 12:30 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't reccomend media blasting any part that comes into contact with engine oil or a fuel intake charge Intakes do both). Residual beads are nearly always hidden in cracks and crevices, behind pinch welds, baffles, etc. glass beads don't disolve in soapy water or anything else and can really cause havoc with your engines internals. The intake should be painted engine color anyway, no harm in just doing a thorough cleaning with the above solvent type cleaners and repaint it orange.
LD6B is Edlebrocks code name for the application (small block Mopar etc.)
Re: best way to clean a aluminum 6pak intake [Re: ScottSmith_Harms] #470318
09/17/09 09:34 AM
09/17/09 09:34 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
If, by chance the intake is still cast aluminum{no paint} there's a cleaner that does a great job...Eagle One brand rough cast{etching} aluminum wheel cleaner does the trick with intakes and trans cases...etc...It cleans without changing the texture as media blasting will do and has an active ingredient that will make the part look new...Just wear gloves and eye protection... You can buy it at any good auto parts store like Advance, Pep boys, etc...
Re: best way to clean a aluminum 6pak intake [Re: screamindriver] #470319
09/17/09 01:32 PM
09/17/09 01:32 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
I've done this before, but always results in a white residue showing up a week later.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: best way to clean a aluminum 6pak intake [Re: EWJ] #470320
09/17/09 05:42 PM
09/17/09 05:42 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
The white residue would be oxidation from the fresh metal being exposed to the environment.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: best way to clean a aluminum 6pak intake [Re: shanker] #470321
09/17/09 10:05 PM
09/17/09 10:05 PM
NJ
440challenger Offline
NJ
yes after etching you need to hit it with wd40 or clear coat it
