Re: best way to clean a aluminum 6pak intake
[Re: demoned]
#470313
09/16/09 09:58 PM
09/16/09 09:58 PM
Posts: 2,001 s. e. pa.
calrobb2000
s. e. pa.
hi take it to your local autoparts and have it glass beeded , wash it good in warm soapy water befor you install it . it will look new ! ld = small block 6b = 6 bbl , it is a later edition not a 1970/71 .
[Re: calrobb2000]
#470314
09/16/09 10:25 PM
09/16/09 10:25 PM
Posts: 350 CT USA
Nick Mineau
CT USA
you can polish it after that for a nice shine
[Re: screamindriver]
#470319
09/17/09 01:32 PM
09/17/09 01:32 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
If, by chance the intake is still cast aluminum{no paint} there's a cleaner that does a great job...Eagle One brand rough cast{etching} aluminum wheel cleaner does the trick with intakes and trans cases...etc...It cleans without changing the texture as media blasting will do and has an active ingredient that will make the part look new...Just wear gloves and eye protection... You can buy it at any good auto parts store like Advance, Pep boys, etc...
I've done this before, but always results in a white residue showing up a week later.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
