a833 4 spd question??? #468222
09/14/09 07:42 PM
09/14/09 07:42 PM
Long Island, New York
1971cudaNY Offline OP
I am in the process of purchasing a 71 barracuda 340 with a 4 speed.(project car)The motor and tranny are not original to the car. Both are in the car.
My question is "how can i tell if it is a hemi or a 23 spline tranny?" casting, serial #'s?
owner is not sure, which is a good indication it is probably a 23 spline...
Re: a833 4 spd question??? [Re: 1971cudaNY] #468223
09/14/09 07:52 PM
09/14/09 07:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If there are 23 splines on the input shaft it would be a REAL good indicator that its a 23 spline tranny !!!!!!!!!
18 splines = hemi box.
Re: a833 4 spd question??? [Re: Stanton] #468224
09/14/09 08:02 PM
09/14/09 08:02 PM
read the question again...
Re: a833 4 spd question??? [Re: 1971cudaNY] #468225
09/14/09 08:07 PM
09/14/09 08:07 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Appologies. See my PM.
Re: a833 4 spd question??? [Re: 1971cudaNY] #468226
09/14/09 08:11 PM
09/14/09 08:11 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
No serial number and casting number is iffy , for it to have been a hemi box on the back of a small block trans alot of swapping of parts would have had to occured as the bearing retainer that fits in a smallblock bellhousing and the only trans like that would have been a 66-67 hemi trans and it doesn't have an ebaody friendly tailshaft .
I'll go out on a limb and say it's NOT a hemi box in that car .
Re: a833 4 spd question??? [Re: JohnRR] #468227
09/14/09 08:35 PM
09/14/09 08:35 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
While not an absolute, pull the inspection cover off and look, you might be able to see the splines (and they look quite a bit different). Also you could look at the main bearing retainer, it is larger on the hemi ones (although the big blocks got the same ones).
While difficult, it should be possible to get a figure up and feel the splines you can tell the difference... - I have not tried though...
Also a 340 did not get the 18 spline, nor the big input shaft bearing, so it is not very likely (from what I remember from a conversation with Jamie Passon)... - although I have a big block 4-speed in my 340 73 cuda - but at one point someone machined the bellhousing out...
Re: a833 4 spd question??? [Re: 6T6Cuda] #468228
09/15/09 09:30 AM
09/15/09 09:30 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Pull the side cover and compare the gear tooth counts.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: a833 4 spd question??? [Re: CJK440] #468229
09/15/09 08:03 PM
09/15/09 08:03 PM
Thanks for all the feed back...
