tube or not? #465570
09/11/09 11:09 AM
09/11/09 11:09 AM
Denver CO
bennydodge Offline OP
Denver CO
I'm running a solid roller setup and have oil dumping out of the bottom of 2 lifter bores. You guys think I should tube the oil galleys or will I be OK?
73 Challenger 340(416),E-heads, 727, 3.23 SG
2015 Challenger R/T classic B5, wife's car
2010 Ram 3500 Crew Cab SLT dually 4X4
2016 Challenger Hellcat Redline Red A8
Re: tube or not? [Re: bennydodge] #465571
09/11/09 11:17 AM
09/11/09 11:17 AM
Come on dude , it is talking to you by the oil leak It's great that you found it before running the motor Would you run fast and long with blood leaking out of a artery in your leg Which brand of soild rollers are you using? Some of the roller lifters have a longer skirt on one side that may cover the oil galley so it doesn't leak. It's odd that only two are leaking
Re: tube or not? [Re: Cab_Burge] #465572
09/11/09 11:54 AM
09/11/09 11:54 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Man if you pump up oil pressure on the starter motor with the oil hot you will be tubein or bushin it for sure
Re: tube or not? [Re: emarine01] #465573
09/11/09 12:29 PM
09/11/09 12:29 PM
Denver CO
Denver CO
The lifters are Doug Herbert's. The motor is still on the engine stand but the bottom end is assembled and the heads are on. Can I still tube it without getting metal chips everywhere? As you can tell I haven't done this before.
Re: tube or not? [Re: bennydodge] #465574
09/11/09 12:45 PM
09/11/09 12:45 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I had a set of Herbert lifters on an unbushed/untubed block several years ago. It had about 40 pounds peak oil pressure. I switched to Isky long bodied and problem solved.
Re: tube or not? [Re: BobR] #465575
09/11/09 02:02 PM
09/11/09 02:02 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Mopar sells a tube kit thats easy to do, We ran a hyd roller a few years back so we had full oiling to the lifters , engine held 50#s pressure hot but when the oil was hot it leaked lots of oil out the lifter bores, with a solid roller you are better off with all that oil down at the crank not blowin all over the lifter valley makin extra windage for the crank to pick up
Re: tubing the oil gallery.... [Re: bennydodge] #465576
09/11/09 03:12 PM
09/11/09 03:12 PM
PA
Z
zooom Offline
zooom  Offline
Z
PA
Drilling & reaming the oil gallery, the steps necessary prior to driving/pressing in the copper tube, generates many ferrous turnings & debris. Drilling the oil passageways into the copper tube generates many copper turnings. Enlarging the oil feed lines [recommended by Mopar] generates even more debris.
Only you can decide if this "easy" operation requires an engine teardown/block scrubbing step.
Also, you may find that the tools provided in the Mopar kit do not exactly "fit" your particular engine block casting [for various reasons] & it is necessary to invest in more precise tooling in order to finish the job.
When you consider these minor complications, the option of investing in a different set of solid roller lifters becomes the more economical choice....
Re: tubing the oil gallery.... [Re: zooom] #465577
09/11/09 03:36 PM
09/11/09 03:36 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
My hyd roller lifters never uncovered the oil gallery, they leaked from lifter bore ware, with the engine oil cold it did not leak on a drill on oil pump shaft when priming but hot oil on the starter motor pissed oil every where, I was surprised on how much oil loss there was,After that we bushed all our lifter bores, I can see how the change in lifter design may help if you think you are uncovering the gallery but if its from lifter bore ware a lifter change may not solve your problem
