tube or not?
#465570
09/11/09 11:09 AM
09/11/09 11:09 AM
Posts: 381 Denver CO
bennydodge
Denver CO
I'm running a solid roller setup and have oil dumping out of the bottom of 2 lifter bores. You guys think I should tube the oil galleys or will I be OK?
73 Challenger 340(416),E-heads, 727, 3.23 SG 2015 Challenger R/T classic B5, wife's car 2010 Ram 3500 Crew Cab SLT dually 4X4 2016 Challenger Hellcat Redline Red A8
Re: tube or not?
[Re: emarine01]
#465573
09/11/09 12:29 PM
09/11/09 12:29 PM
bennydodge
Denver CO
The lifters are Doug Herbert's. The motor is still on the engine stand but the bottom end is assembled and the heads are on. Can I still tube it without getting metal chips everywhere? As you can tell I haven't done this before.
Re: tube or not?
[Re: bennydodge]
#465574
09/11/09 12:45 PM
09/11/09 12:45 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I had a set of Herbert lifters on an unbushed/untubed block several years ago. It had about 40 pounds peak oil pressure. I switched to Isky long bodied and problem solved.
