anybody build or buy a 725 +++H.P. PUMP gas motor ? #452898
08/28/09 10:46 PM
08/28/09 10:46 PM
long beach,ny
10sec340 Offline OP
10sec340  Offline OP
long beach,ny
I'm so tired of spending $150 to cruise around in my race gas Dart !!
looking to drop to 11-1 no more of this 13 1/2-1
But I need to keep it over 725 horse..........
any tips on builds or places that sell combos without having to rob a bank !!
Tim
real 383 car now 440..
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: 10sec340] #452899
08/28/09 11:08 PM
08/28/09 11:08 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
E85
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: ProSport] #452900
08/28/09 11:33 PM
08/28/09 11:33 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
E85
Super cheap, and it will make a little more power It will also run a bit cooler
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: DemonDust] #452901
08/29/09 07:17 AM
08/29/09 07:17 AM
gregsdart Offline
gregsdart  Offline
E85
For the cost of the carb mods, you are in business. Just need enough fuel delivery capacity to flow forty percent more fuel for the E-85
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: 10sec340] #452902
08/29/09 07:27 AM
08/29/09 07:27 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Boost is what legends are made of
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: 10sec340] #452903
08/29/09 08:25 AM
08/29/09 08:25 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Shafiroff
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: Defbob] #452904
08/29/09 08:37 AM
08/29/09 08:37 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
RBRE 557 Cu.In. Pump Gas (11.5:1)
875 hp / 759Ft.Lbs
Good Gas Mileage !
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: gregsdart] #452905
08/29/09 10:13 AM
08/29/09 10:13 AM
long beach,ny
10sec340 Offline OP
10sec340  Offline OP
long beach,ny
E85
I set up with Magne 500 pump/filter, regulator...
Tell me more about this e85 stuff please......whats involved in converting, and does it run in a 13 1/2-1 motor ???
Tim
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: gregsdart] #452906
08/29/09 11:41 AM
08/29/09 11:41 AM
hemi-itis Offline
hemi-itis  Offline
E85
How much is e-85 a gallon????Considering you use 40% more volume and there is maybe one place in nassau county to purchase e-85,I,m not so sure that's the way to go.IMOP boost is the way to go.Cruzin on pump gas,and when you go to the track a pulley change and fill it with the good gas
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: hemi-itis] #452907
08/29/09 11:46 AM
08/29/09 11:46 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
E85
Its around 2.00 a gallon here in indianapolis.
As far as carb mods, call C&S Specialties, CSU, or Quickfuel.
We had C&S do my dads dominator and it only cost $250.00
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: hemi-itis] #452908
08/29/09 11:49 AM
08/29/09 11:49 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
As corny <no pun intended > as it sounds going E85 will help the racing industry as a green sport
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: hemi-itis] #452909
08/29/09 11:50 AM
08/29/09 11:50 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
E-85 here last I checked was 2.21 a gallon. All it requires is alchohol compatible fuel pump and E-85 carb.
Why spend thousands on a rebuild, turbo, or supercharger when you can spend about $1500 and be streetable.
E-85 is rated for 105 octane. There are guys running it in 15:1 applications.
When you compare $8-12 a gallon to around $2 the 30% more fuel usage to me goes right out the window
EDIT......
IF you already have a carb it won't cost you $1500 and if you are running a good race fuel pump more than likely it is compatible with alcohol so you won't have to buy that either. If you have the carb and pump you'll be out about $250-300 for the E-85 conversion kit for the carb.
Sounds like a good idea to me
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: DemonDust] #452910
08/29/09 11:56 AM
08/29/09 11:56 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Not to mention that a lot of the bigger pumps are good for e85 so all you are out is a little carb mod...and the fumes arent so toxic, and like emarine said, it is good for the green image!
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: joshking440] #452911
08/29/09 02:55 PM
08/29/09 02:55 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
E85 will support almost 16:1 compression, so your 13.5:1 will not be an issue.
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: Dragula] #452912
08/29/09 05:19 PM
08/29/09 05:19 PM
hemi-itis Offline
hemi-itis  Offline
Well,after what all of you have said,the only problem is the availabilty here on long island.Well Tim,what say ye'
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: 10sec340] #452913
08/29/09 06:56 PM
08/29/09 06:56 PM
NC
440Jim Offline
440Jim  Offline
NC
Availability of E85 in your area is part of the decision.
http://www.e85refueling.com/
http://www.e85refueling.com/distance.php?page=1
I love my switch to E85 in my race car. The mods were paid for by fuel cost savings from race gas in 1 season. Right now race 110 (VP) is $9.25 at the local track. In May I paid $2.09 for E85 and in July it was $2.29. Typically 5-20 percent cheaper than 87 octane pump gas!
13.5 CR, 279/287 at 0.050" cam, aluminum heads, flat top pistons, 0.039" quench. I ran a E85 carb in 2008 and got a good deal on a used Ron's flying toilet mechanical fuel injection ($800) for this year. I started injection with alky (methanol) and switched calibration over to E85.
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: hemi-itis] #452914
08/29/09 07:31 PM
08/29/09 07:31 PM
long beach,ny
10sec340 Offline OP
10sec340  Offline OP
long beach,ny
I saying this sounds like a way I might go !!
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: 10sec340] #452915
08/29/09 07:32 PM
08/29/09 07:32 PM
long beach,ny
10sec340 Offline OP
10sec340  Offline OP
long beach,ny
One more ? on e85
Anybody have a dyno # on there car with Gas then after just the mods to go e85 another dyno # ?
Or the same ? with track times before and after ??
Tim
The Legend
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: 10sec340] #452916
08/29/09 07:48 PM
08/29/09 07:48 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
One more ? on e85
Tim
The Legend
There was someone that changed carbs and tried E85 and power dropped off alot but i think most of us thought there was something else going on. i dont want to scare you off but those were the results from one member.
seems many other members have had positive results at the track
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ? [Re: sixpackgut] #452917
08/29/09 11:16 PM
08/29/09 11:16 PM
long beach,ny
10sec340 Offline OP
10sec340  Offline OP
long beach,ny
I need to hear those #'s
