anybody build or buy a 725 +++H.P. PUMP gas motor ?
#452898
08/28/09 10:46 PM
08/28/09 10:46 PM
Posts: 123 long beach,ny
10sec340
long beach,ny
I'm so tired of spending $150 to cruise around in my race gas Dart !! looking to drop to 11-1 no more of this 13 1/2-1 But I need to keep it over 725 horse.......... any tips on builds or places that sell combos without having to rob a bank !!
Tim
real 383 car now 440..
Re: anybody build or buy a 725 +++H.P. PUMP gas motor ?
[Re: ProSport]
#452900
08/28/09 11:33 PM
08/28/09 11:33 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
E85
![](/ubbthreads/images/graemlins/iagree.gif)
Super cheap, and it will make a little more power It will also run a bit cooler
[Re: Defbob]
#452904
08/29/09 08:37 AM
08/29/09 08:37 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
RBRE 557 Cu.In. Pump Gas (11.5:1) 875 hp / 759Ft.Lbs
Good Gas Mileage !
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: gregsdart]
#452906
08/29/09 11:41 AM
08/29/09 11:41 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
E85
For the cost of the carb mods, you are in business. Just need enough fuel delivery capacity to flow forty percent more fuel for the E-85
How much is e-85 a gallon????Considering you use 40% more volume and there is maybe one place in nassau county to purchase e-85,I,m not so sure that's the way to go.IMOP boost is the way to go.Cruzin on pump gas,and when you go to the track a pulley change and fill it with the good gas ![](/ubbthreads/images/graemlins/smoke.gif)
[Re: hemi-itis]
#452907
08/29/09 11:46 AM
08/29/09 11:46 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
E85
Its around 2.00 a gallon here in indianapolis.
As far as carb mods, call C&S Specialties, CSU, or Quickfuel.
We had C&S do my dads dominator and it only cost $250.00
[Re: hemi-itis]
#452909
08/29/09 11:50 AM
08/29/09 11:50 AM
DemonDust
Menomonee Falls
E-85 here last I checked was 2.21 a gallon. All it requires is alchohol compatible fuel pump and E-85 carb. Why spend thousands on a rebuild, turbo, or supercharger when you can spend about $1500 and be streetable. E-85 is rated for 105 octane. There are guys running it in 15:1 applications. When you compare $8-12 a gallon to around $2 the 30% more fuel usage to me goes right out the window ![](/ubbthreads/images/graemlins/Twocents.gif) EDIT...... IF you already have a carb it won't cost you $1500 and if you are running a good race fuel pump more than likely it is compatible with alcohol so you won't have to buy that either. If you have the carb and pump you'll be out about $250-300 for the E-85 conversion kit for the carb. Sounds like a good idea to me ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: DemonDust]
#452910
08/29/09 11:56 AM
08/29/09 11:56 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: Dragula]
#452912
08/29/09 05:19 PM
08/29/09 05:19 PM
hemi-itis
E85 will support almost 16:1 compression, so your 13.5:1 will not be an issue.
Well,after what all of you have said,the only problem is the availabilty here on long island.Well Tim,what say ye' ![](/ubbthreads/images/graemlins/popcrn.gif)
[Re: 10sec340]
#452913
08/29/09 06:56 PM
08/29/09 06:56 PM
Posts: 16,932 NC
440Jim
NC
Availability of E85 in your area is part of the decision. http://www.e85refueling.com/http://www.e85refueling.com/distance.php?page=1I love my switch to E85 in my race car. The mods were paid for by fuel cost savings from race gas in 1 season. Right now race 110 (VP) is $9.25 at the local track. In May I paid $2.09 for E85 and in July it was $2.29. Typically 5-20 percent cheaper than 87 octane pump gas! 13.5 CR, 279/287 at 0.050" cam, aluminum heads, flat top pistons, 0.039" quench. I ran a E85 carb in 2008 and got a good deal on a used Ron's flying toilet mechanical fuel injection ($800) for this year. I started injection with alky (methanol) and switched calibration over to E85. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 10sec340]
#452915
08/29/09 07:32 PM
08/29/09 07:32 PM
10sec340
long beach,ny
One more ? on e85 Anybody have a dyno # on there car with Gas then after just the mods to go e85 another dyno # ? Or the same ? with track times before and after ??
Tim The Legend
