Moparts Article Avail? Home-made 727 shiftkit? #448120
08/24/09 03:05 PM
08/24/09 03:05 PM
Friendsville, TN
Reverend_Ron Offline OP
super street
super street
Friendsville, TN
Is there a "how to" post archived here on making the 727 shift firmer?
Like: throw out this ball bearing,
drill this hole larger,
throw out this accumulator spring,
adjust this bolt to x-inches,
etc...?
I used to have a Mopar Magazine article that told you how to do all that but have since stored it where I no longer know where it is!
Thanks!
68 Roadrunner, 383,4-spd 71 Superbee, Citron Yella, 383,slapstick 71 Charger 500, Autumn Bronze, 383,4-spd, A/C 72 Imperial, 2-dr hdtp 74 Charger SE, 440-auto, sunroof 84 Crew Cab Dually, 440-auto 01 Quad Cab Dually, HO Cummins;6-spd 08 H-D, Softail Custom 08 Challenger, 6.1 Hemi
Re: Moparts Article Avail? Home-made 727 shiftkit? [Re: Reverend_Ron] #448121
08/24/09 03:20 PM
08/24/09 03:20 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
The BEST cheapO(but good) that I know of is as follows ....
Toss the acc spring, jack-up the line-pressure a tad and put in a higher up-shift gov-package.
uNless they have done something way WAY better with them in the last 10 or so years.....those trans-go(etc)shift-kits ..IMO ...are a big-time waste of money.
Re: Moparts Article Avail? Home-made 727 shiftkit? [Re: dOoC] #448122
08/24/09 03:47 PM
08/24/09 03:47 PM
remove one check ball
drill 1-2 holes in the seperator plate (depending on year)
remove accumulator spring
bump line pressure
I have the article but no way to scan....
Re: Moparts Article Avail? Home-made 727 shiftkit? #448123
08/24/09 04:28 PM
08/24/09 04:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Why?
Re: Moparts Article Avail? Home-made 727 shiftkit? [Re: Reverend_Ron] #448124
08/24/09 04:39 PM
08/24/09 04:39 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I remember that article and modified my 727, must have been about 25 years ago. There was a big improvement to the 1-2 shift but it didn't do anything for the 2-3 shift if I remember correctly.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Moparts Article Avail? Home-made 727 shiftkit? [Re: Reverend_Ron] #448125
08/24/09 07:24 PM
08/24/09 07:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The PDF file in the link below is the instructions for the TCI reprogramming kit, many of the mods can be duplicated at home...pay particular attention to the pic on page 11 concerning the orifice sizes in the steel separator plate.
http://www.tciauto.com/v002/Instructions/Files/220000.pdf
Rigidizing the rear servo piston is important when doing the other mods, the heavier spring included in the kit won't be as easy to find but should be added too.
Regardless of the TCI instructions and the common Mopar community myth, removing the outer accumulator spring has no effect on the upshifting; oldest myth in the Mopar world.
Re: Moparts Article Avail? Home-made 727 shiftkit? [Re: John_Kunkel] #448126
08/24/09 08:51 PM
08/24/09 08:51 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Thankx John , good info
Re: Moparts Article Avail? Home-made 727 shiftkit? [Re: John_Kunkel] #448127
08/24/09 10:26 PM
08/24/09 10:26 PM
Friendsville, TN
super street
super street
Friendsville, TN
Awesome Post John - Thank you!!!
