Moparts Article Avail? Home-made 727 shiftkit?
#448120
08/24/09 03:05 PM
08/24/09 03:05 PM
Posts: 449 Friendsville, TN
Reverend_Ron
super street
super street
Friendsville, TN
Is there a "how to" post archived here on making the 727 shift firmer? Like: throw out this ball bearing, drill this hole larger, throw out this accumulator spring, adjust this bolt to x-inches, etc...? I used to have a Mopar Magazine article that told you how to do all that but have since stored it where I no longer know where it is! Thanks!
68 Roadrunner, 383,4-spd
71 Superbee, Citron Yella, 383,slapstick
71 Charger 500, Autumn Bronze, 383,4-spd, A/C
72 Imperial, 2-dr hdtp
74 Charger SE, 440-auto, sunroof
84 Crew Cab Dually, 440-auto
01 Quad Cab Dually, HO Cummins;6-spd
08 H-D, Softail Custom
08 Challenger, 6.1 Hemi
Re: Moparts Article Avail? Home-made 727 shiftkit?
[Re: dOoC]
#448122
08/24/09 03:47 PM
08/24/09 03:47 PM
remove one check ball drill 1-2 holes in the seperator plate (depending on year) remove accumulator spring bump line pressure
I have the article but no way to scan....
[Re: Reverend_Ron]
#448124
08/24/09 04:39 PM
08/24/09 04:39 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I remember that article and modified my 727, must have been about 25 years ago. There was a big improvement to the 1-2 shift but it didn't do anything for the 2-3 shift if I remember correctly.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: Reverend_Ron]
#448125
08/24/09 07:24 PM
08/24/09 07:24 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The PDF file in the link below is the instructions for the TCI reprogramming kit, many of the mods can be duplicated at home...pay particular attention to the pic on page 11 concerning the orifice sizes in the steel separator plate. http://www.tciauto.com/v002/Instructions/Files/220000.pdfRigidizing the rear servo piston is important when doing the other mods, the heavier spring included in the kit won't be as easy to find but should be added too. Regardless of the TCI instructions and the common Mopar community myth, removing the outer accumulator spring has no effect on the upshifting; oldest myth in the Mopar world.
[Re: John_Kunkel]
#448127
08/24/09 10:26 PM
08/24/09 10:26 PM
Reverend_Ron
super street
super street
Friendsville, TN
Awesome Post John - Thank you!!!
