Page 2 of 5 1 2 3 4 5
Re: B1 Guys what is the max HP [Re: 68CudaB1] #444061
08/20/09 03:06 PM
08/20/09 03:06 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Im curious as to what a OOTB B1 head numbers are?
We ran an OOTB B1 original head w/ T&D rockers and OOTB B1 intake for a couple years on a 3300# 68 Cuda. Engine was a low deck 500", 14:1, OOTB Ultra 1050 Dominator......
Car ran 9.20's all day long for a couple years, very consistant and very reliable.
what valve size did you use with a 4.380 bore ???
2.300
no valve shrouding issues??? I liek the sounds of box stock B1's ....
Mopar Performance
Re: B1 Guys what is the max HP [Re: Diego_Ted] #444062
08/20/09 03:17 PM
08/20/09 03:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW and for those who may not have known I had a 511" low deck B1 motor that went 9.0's at 3470lbs all motor with no issues, well other than the block not being real happy. Did break a cam as well but feces occurs. This was a good 400 block, had to buy and sonic check 7 to find a good one. It was filled, tall fill, had aluminum caps and I made an effort to keep the bobweight as low as possible. It worked well for what it was but not going to spend that kind of money again searching for a good block and the paying to have that one machined. I just dont need all the stuff lying around anymore. I do still have two good(sonic checked)230 blocks left though.
Re: B1 Guys what is the max HP [Re: moparniac] #444063
08/20/09 03:26 PM
08/20/09 03:26 PM
PA
68CudaB1 Offline
68CudaB1  Offline
PA
No problems, but of course they would work better w/ a bigger bore but for OOTB on a 400 low deck, IMO, they kick ass...
The OOTB Brodix deal comes w/ SS valves, Manley Nextek springs (good for up to .800 lift), etc....we utilized a .740" roller in our motor.
Rotating assembly was nothing special....Eagle Crank, Manley Rods, JE Pistons w/ basic 1/16 ring pack, etc. We used custom made billet main caps to get rid of the spacers on the girdle, this made the caps flush with girdle.....dont know if it helped but sounds good
IIRC, we did the entire motor for under $8K
Re: B1 Guys what is the max HP [Re: Diego_Ted] #444064
08/20/09 03:49 PM
08/20/09 03:49 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
Suck it up and buy a block Ted... LOL Its only money...
Re: B1 Guys what is the max HP [Re: moparniac] #444065
08/20/09 04:24 PM
08/20/09 04:24 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I invested a good amount into my 400 block but my budget didnt allow anything else at the time, but even though the car is not running, i am going to start an aluminum kb low deck for the car.
I am going to try to make 1200hp with a turbo in using a stock block...the turbo guys say it will work for a while since the rpms are so low, but i am still pretty nervous!
Re: B1 Guys what is the max HP [Re: joshking440] #444066
08/20/09 06:55 PM
08/20/09 06:55 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
You guys know how I see it.If it's a race car that is going to make 100 to 150 passes a year.Then yes get the better block.If the car will only see 40 passes a year,stock block all the way.You guys over do this stuff to death.Lenny
Re: B1 Guys what is the max HP [Re: 8secDart] #444067
08/20/09 07:45 PM
08/20/09 07:45 PM
Arizona
Chris'sBarracuda Offline
Arizona
If you want the answer from someone who has done more of these combos than anyone..IMO..
Call Scott Koffel..
The stuff Gecker has used..and is still using is stock 400 blocks.
I've known him for 25+ years and he has always used the low decks...Except when he had Hemis..
*NOTE* When Gecker had some catastrophic engine failures, it was always with the Hemi... rotating weight..
I've seen the 452" and 471" B1's go over 8500 rpm well over 600 runs a year when Gecker used to race on the National circuit.
He is still using a 400 block now in the dragster, making over 930hp.
Yes, he has broke a few in his day, but has many, many runs on them.
So ask Koffel what they do to these things to make them last..
Chris..
Re: B1 Guys what is the max HP [Re: Chris'sBarracuda] #444068
08/20/09 07:51 PM
08/20/09 07:51 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Call Scott Koffel..
Chris..
Or you can spend 1500 bucks more and use the right stuff. Running over oil or cranks isn't on my bucket list.
Re: B1 Guys what is the max HP [Re: BobR] #444069
08/20/09 07:58 PM
08/20/09 07:58 PM
Arizona
Arizona
Just giving an option..And opinion here Bob..
Not saying who is right or wrong.
Am only going by what I have personally seen..
Chris..
Re: B1 Guys what is the max HP [Re: Chris'sBarracuda] #444070
08/20/09 08:02 PM
08/20/09 08:02 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
That combo may likely last longer in a dragster than a heavy street car. Just like an 8 3/4..takes alot more grunting to move a 2 ton than a 1 ton.
Re: B1 Guys what is the max HP [Re: B1Fish540] #444071
08/20/09 08:19 PM
08/20/09 08:19 PM
Arizona
Arizona
Most of the 452" and 471" stuff was in the Shelby/Omni-Charger.. The Charger weighed about 2700#.
Chris..
Re: B1 Guys what is the max HP [Re: B1Fish540] #444072
08/20/09 08:20 PM
08/20/09 08:20 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
I just wish there were more low deck options. The indy max block is ok but $$$$$$$
Re: B1 Guys what is the max HP [Re: 70VcodeCoronetRT] #444073
08/20/09 09:03 PM
08/20/09 09:03 PM
Hemiroid Offline
Hemiroid  Offline
If I had a 230 block laying around that already had been machined and had the caps and I was building a 600hp bracket motor I'd use it no problem. If I was starting from scratch and was looking to build 800+hp no way I'm using a 400 block.
There was a time when those blocks were used out of necessity. With all of the blocks now available that time has passed.
Re: B1 Guys what is the max HP [Re: B1Fish540] #444074
08/20/09 09:41 PM
08/20/09 09:41 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
How do you figure this?
Were not talking 8 3/4 rears LOL
The engine doesnt know what its in, or cares for that matter.
Re: B1 Guys what is the max HP [Re: Diego_Ted] #444075
08/20/09 09:52 PM
08/20/09 09:52 PM
SoCal
Brian Hafliger Offline
SoCal
I should shoot for with a stock 400 block and expect it to live? I will have to go with some bic cubes because of the port size on my heads. I will half fill and use alum caps as per Koffel house recommedations. I will run Alky and hit it with some NOS, My goal is mid 8s in a 3k car.
Diego
Don't waste your time with a stock block. You WILL regret it!!
Brian Hafliger
Re: B1 Guys what is the max HP [Re: Bob_Coomer] #444076
08/20/09 09:56 PM
08/20/09 09:56 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Its just common sense. If the crank is working harder to turn the shaft there will be more flexing... and thats what tears those blocks up.
In this scenario, both cars would have the same gearing and trans. The lighter car runs faster because the motor is doing less "work" to move it. The motor is subject to the laws of physics just like you or I. Thats all I'm saying.
Re: B1 Guys what is the max HP [Re: B1Fish540] #444077
08/20/09 10:24 PM
08/20/09 10:24 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Work is force, happening over a measured period of time.
The engine you describe does the same amount of "work"
in either car.......It just takes less time to get it done at
a lighter weight.
Ants work but, move small amounts over long periods of time.
Otherwise you'd have 500 HP ants.
Re: B1 Guys what is the max HP [Re: gregsdart] #444078
08/20/09 10:56 PM
08/20/09 10:56 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ten years ago I had the chance to buy a 540 inch, low deck aluminum kb motor with B1mc heads that made over 1000 hp , and would push a local 2550 lb 9.90 car to 170 mph on the throttle stop! I am sorry I didn't figure out how to come up with the $$, and that same package appeals to me today. If you already have B1 heads, why not treat them to a block that will let them roar?
sounds like "Twist and Shout" leftovers.....
Paul split quite a few stock blocks before going KB.
Re: B1 Guys what is the max HP [Re: S/ST 3040] #444079
08/20/09 11:02 PM
08/20/09 11:02 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
You guy's all crack me up
You can spend 20-30 grand or even more on
your ride, but can't spend $1500 or a little more,
for a good safe block. Think on the safty side of it.
Only if 440source would of made a block, right?
But now they are having problems with the
water pump housing they sell.
Snap your neck, mega G-force launch, is all I want!
Re: B1 Guys what is the max HP [Re: B1Fish540] #444080
08/20/09 11:08 PM
08/20/09 11:08 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Sorry My common sense must be broken
How does it work harder, and make more stress?
If the engine makes 800 hp, and you shift it a 7K in car A weighs 3800 lbs.
Car be weighs 2000 lbs. The engine still makes 800hp, and the torque and power range doesnt change, so you shift it again at 7K
Explain to me in lamens terms how it works harder to achieve the same power level?
Were not looking at E/T time slips here, acceleration, 60 ft times...No increments.
How does the engine live longer in the lighter car?
If this were true they would never blow up on the dyno. The engine see's the load and tries to move it.
I have had some in depth college Physics classes, i dont see how weight of a vehicle or chassis setup can effect engine longevity.
Just a friendly debate here..
IMO vehicle size has nothing to due with the stability of a engine. Things like bearing clearance, and bore thickness, detonation does however.
Just think about what your trying to say.
If told you the weight of a vehicle in theory has little to do with max top end speed given a perfectly flat surface you would also think I am
