Re: B1 Guys what is the max HP
[Re: Diego_Ted]
#444043
08/20/09 09:29 AM
08/20/09 09:29 AM
Posts: 10,045 MN
JERICOGTX
MN
I wouldn't go over 800 with a stock block, even with good aluminum main caps. Anything more and it would be a wise investment in a aftermarket block.
Jeff
69 GTX
68 Road Runner
[Re: Diego_Ted]
#444044
08/20/09 09:33 AM
08/20/09 09:33 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You are asking a stock block to handle 950 + hp to go mid eights at 3000 lbs. Consider the cost of a good block, as compared to redoing another stock block, adding that expense to a lost weekend when it breaks, etc. On top of that, you could go aluminum block and really gain some weight savings up front. A well built aftermarket block with 528 or more cubes, B1 heads will get you mid eights before the power adder.
[Re: S/ST 3040]
#444045
08/20/09 09:39 AM
08/20/09 09:39 AM
Posts: 8,165 Left Coast
BobR
Left Coast
From my days with an alcohol burning 410" S/S NTPA team........much over 700 HP will split those blocks wide open, tall fill and aluminum caps.
I agree. Doesn't really matter what heads the blocks just aren't reliable for much more than this. You aren't going to achieve your goals(for long) with a stock 400 block.
[Re: gregsdart]
#444046
08/20/09 09:41 AM
08/20/09 09:41 AM
gregsdart
Ten years ago I had the chance to buy a 540 inch, low deck aluminum kb motor with B1mc heads that made over 1000 hp , and would push a local 2550 lb 9.90 car to 170 mph on the throttle stop! I am sorry I didn't figure out how to come up with the $$, and that same package appeals to me today. If you already have B1 heads, why not treat them to a block that will let them roar?
[Re: Diego_Ted]
#444047
08/20/09 09:42 AM
08/20/09 09:42 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
It will live awhile, maybe. The girdle, and aluminum caps do nothing for spit bores. If you decide to do it with a stock block, find one that has thick cylinder walls. No matter what you do to it, it will just find the next weak link in the block. By the time you add, aluminum caps, girdles, half fill, bore, decked, honed, lined bored. How much more would a World Block be at this point?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Diego_Ted]
#444048
08/20/09 10:08 AM
08/20/09 10:08 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Ask Al Alguire about stock low deck blocks making tons of power with B1 heads. I remember him saying he'll never build another stock block motor again, even though his was a "good" 230 casting. As well as NHRA Mark a few years ago when his last stock block motor grenaded. I'm not picking on these guys, just saying they just made some ridiculous power with stock blocks and proved they won't take it for long. CHIP
[Re: an8sec70cuda]
#444050
08/20/09 10:13 AM
08/20/09 10:13 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
What Chip said..
The asy answer is you can make WAY more power than the block will hold. You can pick up a World iron block for $2500ish dollars, price a GOOD 400 block, the aftermarket caps, filler and a girdle plus machine work and then tell me you are coming out ahead.
With a decent set(read some bowl work)of B1's you will make over 800hp. Adding nitrous to that is asking for more issues, not that you cannot get a 400 block to live but IMO it is not worth the effort with all the alternatives out there. Why underbuild a motor with those heads only in an effort to try and make it live? Kind of defeats the purpose of having the heads IMO. Yes I have doen it but that was when there were few alternatives. I killed two blocks and beleive me it is a HUGE cost.....
[Re: AndyF]
#444052
08/20/09 10:46 AM
08/20/09 10:46 AM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
Koffel has been building B1 400 block combos for a long time. He originally designed the B1 head to fit the 400 block because it was the only Mopar block that had a chance to handle the power. So if you follow their recommendations you should have a fighting chance at getting it to live.
Not sure why nobody has made a low deck aftermarket block yet in cast iron. Seems like a natural product to have. Lots of guys don't want to switch to the taller RB block after they are all set up with the low deck combo.
What is the attraction of a low deck when building a high horsepower combo? It's not that much shorter and the weight savings is nill. From my experience the low deck factory junk has shorter cylinders but most are all thinner than the 440's i've sonic'd. Unless it's going in an A-body with fenderwells still in it, what's the point? I'd like to hear what you guys think on this one.
[Re: CRE2004]
#444053
08/20/09 11:56 AM
08/20/09 11:56 AM
gregsdart
The lowdeck allows a lighter rotating assembly. First off, it WILL be lighter, maybe not a ton when in an all aluminum block, but the rotating weight reduction alone is worth it, not to mention you have a touch more room for stuff in the engine bay. Pushrods get shorter, con rods get shorter,bearings get less stress, rod/stroke ratio improves for huge heads, sounds like enough to me with those items alone. We do need an aluminum low deck option.
[Re: CRE2004]
#444054
08/20/09 01:13 PM
08/20/09 01:13 PM
BobR
Left Coast
I agree with you but I would never use a factory block in a race car.
[Re: moparniac]
#444056
08/20/09 01:40 PM
08/20/09 01:40 PM
Posts: 6,295 U.S.
moparniac
U.S.
Found some cleaned up bowl numbers...... man this would be awesome like this..... until I got a race block Lift Int. Ex. .200 139 102 .300 205 145 .400 267 183 .500 322 218 .600 358 242 .700 381 258 .800 387 268
Mopar Performance
[Re: moparniac]
#444057
08/20/09 01:56 PM
08/20/09 01:56 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
IMO, that could always be an option. Then when you had the bucks you could step up your program with a good block, crank, rods and then port the heads. I dont think my heads flow much more than that..maybe 390ish, but 800+ hp is enough for my Ohio crank and forged Oliver rods, But the block was something i did'nt want to chince on and forked out the cash for a Mega-block. Plus theres always the nice feature of going BIG if you ever want to..a 572 is easy to do.
[Re: moparniac]
#444058
08/20/09 02:28 PM
08/20/09 02:28 PM
Posts: 573 PA
68CudaB1
PA
Im curious as to what a OOTB B1 head numbers are?
We ran an OOTB B1 original head w/ T&D rockers and OOTB B1 intake for a couple years on a 3300# 68 Cuda. Engine was a low deck 500", 14:1, OOTB Ultra 1050 Dominator......
Car ran 9.20's all day long for a couple years, very consistant and very reliable.
[Re: moparniac]
#444060
08/20/09 03:03 PM
08/20/09 03:03 PM
Posts: 573 PA
68CudaB1
PA
what valve size did you use with a 4.380 bore ???
2.300
