Re: Lightweight front end parts.What's out there?
[Re: MoparDonny]
#442362
08/18/09 08:41 PM
08/18/09 08:41 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
Easy stuff is a fiberglass bumper and aluminun radiator and waterpump. 9 inch drum spindles with Aeroapsce brakes. Manual steering. You can lighten up a stock K member some with a holesaw and patience. Eventually you will be chasing ounces not pounds if you get serious.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: Stroker Scamp]
#442367
08/19/09 01:11 AM
08/19/09 01:11 AM
Posts: 1,760 Port Alberni, British Columbia
MoparDonny
The car (Dad's)is a 71 Challenger with a 496, Eddy heads, Alum water pump, Alum sheetmetal valvecovers ,Six pack on Alum manifold, all stock suspension other than SS leafs and Calvert shocks.
Mike, are those brakes streetable or race only? Car still has power steering and power brakes. I bet if it had a fiberglass hood and bumper,aluminum bumper brackets,Manual brakes and steering, then relocate the battery to the back the weight transfer would be WAY better. How much does a Lift off hood weigh compared to an RT hood?
Don.
[Re: fullmetaljacket]
#442369
08/19/09 07:44 AM
08/19/09 07:44 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
My Mag Force F/E and Wilwood disks knocked 180# off the front end. The ally block also helped . Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: Lil Demon]
#442371
08/19/09 10:51 AM
08/19/09 10:51 AM
Kinda off topic but do the rear Aerospace disc brake kits require the "green" or non-adjustable bearings or can you use them with the factory adjustable timkins?
[Re: Lil Demon]
#442372
08/19/09 11:01 AM
08/19/09 11:01 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
bumpers will save #13 each front brakes around #40 rear brakes #35-40 battery around #45-50 power steering to manual about #32 power brakes to manual about #20 a light hood could save #60
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#442373
08/19/09 03:10 PM
08/19/09 03:10 PM
Posts: 2,864 IN
Irun5snd8th
IN
I am with lil Demon. I shaved 66 lbs off the nose with the Aerospace front brakes. And you gain safety.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
