Lightweight front end parts.What's out there? #442361
08/18/09 08:06 PM
08/18/09 08:06 PM
Port Alberni, British Columbia
MoparDonny Offline OP
Thinking of hoods, bumpers, steering box,Brake master, fans and Rad, etc.
Would be nice to lighten the Challenger's nose a bit. What stuff do you guys like?
Don.
Re: Lightweight front end parts.What's out there? [Re: MoparDonny] #442362
08/18/09 08:41 PM
08/18/09 08:41 PM
south louisiana
lowell66dart Offline
south louisiana
Easy stuff is a fiberglass bumper and aluminun radiator and waterpump. 9 inch drum spindles with Aeroapsce brakes. Manual steering. You can lighten up a stock K member some with a holesaw and patience. Eventually you will be chasing ounces not pounds if you get serious.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Lightweight front end parts.What's out there? [Re: MoparDonny] #442363
08/18/09 09:05 PM
08/18/09 09:05 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
contact Bob's Profab (bondobob)
he makes;
Chromemoly drag link,
CHromemoly strut rods w/aluminum washers,
Chromemoly steering shaft,
lightened K member
You are looking at approx 50lbs in weight savings!
Re: Lightweight front end parts.What's out there? [Re: nss guy] #442364
08/19/09 12:54 AM
08/19/09 12:54 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
what do you have for brakes heres my aerospace saved a bunch of weight
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Lightweight front end parts.What's out there? [Re: MoparDonny] #442365
08/19/09 12:56 AM
08/19/09 12:56 AM
fullmetaljacket Offline
If you have full length header flanges at the head mating point, cut off the excess metal in between the each exhaust port except obviously the two adjoining middle exhaust ports and you'll save a pound or two depending on your header flange thickness. it will also seal much better to the head surface because the tubes will be independent of each other. Just a little trick here and there to rid the ounces off the front end.
Look for all the small stuff that will add up big on the scale.
Re: Lightweight front end parts.What's out there? [Re: Stroker Scamp] #442366
08/19/09 01:00 AM
08/19/09 01:00 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i went from a full factory trim E body to a A body with a carbon 1 piece front clip. that was a major improvement. now i can sit on my front wheels while i work on my engine. no more sore backs from leaning over front fenders. this is one option that any future racecar in my life must have.
Re: Lightweight front end parts.What's out there? [Re: Stroker Scamp] #442367
08/19/09 01:11 AM
08/19/09 01:11 AM
The car (Dad's)is a 71 Challenger with a 496, Eddy heads, Alum water pump, Alum sheetmetal valvecovers ,Six pack on Alum manifold, all stock suspension other than SS leafs and Calvert shocks.
Mike, are those brakes streetable or race only? Car still has power steering and power brakes. I bet if it had a fiberglass hood and bumper,aluminum bumper brackets,Manual brakes and steering, then relocate the battery to the back the weight transfer would be WAY better. How much does a Lift off hood weigh compared to an RT hood?
Don.
Re: Lightweight front end parts.What's out there? [Re: MoparDonny] #442368
08/19/09 01:19 AM
08/19/09 01:19 AM
oust manual brakes, manual steering, YES.
replace fiberglass hood and bumper, YES.
the battery in the rear will for sure set some much needed weight transfer in the right spot.
oust the undercoating, sound insulation, heater box and motor, just to name a few of the easy things.
Re: Lightweight front end parts.What's out there? [Re: fullmetaljacket] #442369
08/19/09 07:44 AM
08/19/09 07:44 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
My Mag Force F/E and Wilwood disks knocked 180# off the front end. The ally block also helped .
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Lightweight front end parts.What's out there? [Re: chryco] #442370
08/19/09 10:45 AM
08/19/09 10:45 AM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Your factory brakes weigh ~83 lbs. The Aerospace street kit weighs 42 lbs. The Aerospace race kit weighs 30 lbs.
I'm a dealer for them and offer a Moparts discount - let me know.
Re: Lightweight front end parts.What's out there? [Re: Lil Demon] #442371
08/19/09 10:51 AM
08/19/09 10:51 AM
Kinda off topic but do the rear Aerospace disc brake kits require the "green" or non-adjustable bearings or can you use them with the factory adjustable timkins?
Re: Lightweight front end parts.What's out there? [Re: Lil Demon] #442372
08/19/09 11:01 AM
08/19/09 11:01 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
bumpers will save #13 each
front brakes around #40
rear brakes #35-40
battery around #45-50
power steering to manual about #32
power brakes to manual about #20
a light hood could save #60
Re: Lightweight front end parts.What's out there? [Re: sixpackgut] #442373
08/19/09 03:10 PM
08/19/09 03:10 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I am with lil Demon. I shaved 66 lbs off the nose with the Aerospace front brakes. And you gain safety.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Lightweight front end parts.What's out there? [Re: MoparDonny] #442374
08/19/09 04:24 PM
08/19/09 04:24 PM
kansas
farmboy Offline
farmboy  Offline
kansas
How about getting those crash beams out of the doors. As I remember, it was over 50 pounds.
Re: Lightweight front end parts.What's out there? [Re: Lil Demon] #442375
08/19/09 05:11 PM
08/19/09 05:11 PM
Are you saying the front factory Drum brakes are 83 lbs or the factory Disc brakes?
