airgrabber air cleaner #428806
08/04/09 09:56 PM
08/04/09 09:56 PM
Anonymous OP
Anonymous OP
Is the sixpac filter and lid the same,will it fit on the airgrabber 4bbl aircleaner?
THANKS EDDIE B
Re: airgrabber air cleaner #428807
08/04/09 10:15 PM
08/04/09 10:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
filters are the same ( on 69's with 4 barrels)
lids are different for 6 pack versus 4 barrel
( 1970 and later 4 barrel is a round lid )
Re: airgrabber air cleaner #428808
08/04/09 10:33 PM
08/04/09 10:33 PM
hemisurfer Offline
hemisurfer  Offline
I use a 1970 440 6 pack base with a six pack lid on a 440 six pack motor installed in a 1969 air grabber 383 car. It all works together and looks very factory. Most neophytes don't even know it's a six pack when they look at it. Even left the 383 emblems to complete the sleeper effect.
BTW if you have any real HP behind your motor I would suggest using a torque strap of some kind. If you bust a motor mount without it you will rip up some very expensive air grabber ducting.
Chris
Re: airgrabber air cleaner #428809
08/05/09 10:03 AM
08/05/09 10:03 AM
Anonymous OP
Anonymous OP
spacing of the wing nuts are different between 4bbl and six pack lids. that is good advice about a torque strap.
