Milodon Gear Drive / Super Dampner ??? #423821
07/30/09 12:23 PM
07/30/09 12:23 PM
U.S.
moparniac Offline OP
U.S.
Anyone know what the part number is for a ATI superdampner thats compatable with a Milodon gear drive.... also what is the little hole on the left side of the milodon gear drive unit for? thx
Mopar Performance
Re: Milodon Gear Drive / Super Dampner ??? [Re: moparniac] #423822
07/30/09 12:31 PM
07/30/09 12:31 PM
Lake Charles,Louisiana
BILLYJAY Offline
BILLYJAY  Offline
i just bought a ATI Damper(917122E)it was the wrong one.. and if you buy through jegs or summit they dont have the part number listed..i have a Indy timing cover and needed a 1/4" longer hub.. but instaed i had to buy the shim kit to make mine work..call ATI directly and get the right part number.. they offer 22 applications for BB dodge.. http://www.atiracing.com/products/dampers/index.htm 877-298-0539 speak to jim Beaty.. tell him your application..the part # for the correct hub should be 916663 but double check...
Re: Milodon Gear Drive / Super Dampner ??? [Re: BILLYJAY] #423823
07/30/09 12:36 PM
07/30/09 12:36 PM
U.S.
U.S.
thx... anyone know what the little hole in the side of the milodon gear drive is for..... never ran one before.. thx
Mopar Performance
Re: Milodon Gear Drive / Super Dampner ??? [Re: moparniac] #423824
07/30/09 12:40 PM
07/30/09 12:40 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Just went through this. I ended up with an ATI hub number 916663 as was mentioned above.
As for the hole, if it's the one I'm thinking of it's for the timing pointer.
Re: Milodon Gear Drive / Super Dampner ??? [Re: moparniac] #423825
07/30/09 12:41 PM
07/30/09 12:41 PM
Northeast Texas
MoparMuscle Offline
MoparMuscle  Offline
Northeast Texas
At the top of page six in the race parts for sale there is one listed as being for a gear drive.
100% Mopar No Juice Added
2016 Challenger R/T Blacktop 5.7 6 SPD
2009 Ram 1500 5.7
http://moparmuscle.biz
Re: Milodon Gear Drive / Super Dampner ??? [Re: MoparMuscle] #423826
07/30/09 01:47 PM
07/30/09 01:47 PM
U.S.
U.S.
Thx
Mopar Performance
Re: Milodon Gear Drive / Super Dampner ??? [Re: moparniac] #423827
07/30/09 02:05 PM
07/30/09 02:05 PM
Missouri
galen Offline
galen  Offline
Missouri
ATI will sell just the hub if you need it. They sent it right out. I cant find my invoice but the hub was $135. It fit like a glove.
Re: Milodon Gear Drive / Super Dampner ??? [Re: galen] #423828
07/30/09 09:19 PM
07/30/09 09:19 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Wedgie, i have one for sale if your interested.35 passes. The 916663 hub with a 2 ring damper (works with a belt drive) with the timing marks the correct way.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Milodon Gear Drive / Super Dampner ??? [Re: moparniac] #423829
07/30/09 09:35 PM
07/30/09 09:35 PM
AndyF Offline
AndyF  Offline
If you look on the ATI website you'll see the product listings for a gear drive. There are several different ones that will fit depending on if you want aluminum or steel, two ring or three ring, Chevy bolt pattern, etc.
Re: Milodon Gear Drive / Super Dampner ??? [Re: AndyF] #423830
08/03/09 06:05 PM
08/03/09 06:05 PM
U.S.
U.S.
well I just traded a edelbrock rpm intake for a ATI damner....
part# 916621
Hub part# 916661L
Will it work for a milodon gear drive?
Mopar Performance
Re: Milodon Gear Drive / Super Dampner ??? [Re: moparniac] #423831
08/03/09 07:15 PM
08/03/09 07:15 PM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
Which hole are you referring to?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Milodon Gear Drive / Super Dampner ??? [Re: hemi-itis] #423832
08/03/09 07:20 PM
08/03/09 07:20 PM
Different angle
