Re: Milodon Gear Drive / Super Dampner ???
[Re: moparniac]
#423822
07/30/09 12:31 PM
07/30/09 12:31 PM
Posts: 1,416 Lake Charles,Louisiana
BILLYJAY
i just bought a ATI Damper(917122E)it was the wrong one.. and if you buy through jegs or summit they dont have the part number listed..i have a Indy timing cover and needed a 1/4" longer hub.. but instaed i had to buy the shim kit to make mine work..call ATI directly and get the right part number.. they offer 22 applications for BB dodge.. http://www.atiracing.com/products/dampers/index.htm 877-298-0539 speak to jim Beaty.. tell him your application..the part # for the correct hub should be 916663 but double check...
[Re: galen]
#423828
07/30/09 09:19 PM
07/30/09 09:19 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Wedgie, i have one for sale if your interested.35 passes. The 916663 hub with a 2 ring damper (works with a belt drive) with the timing marks the correct way.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: AndyF]
#423830
08/03/09 06:05 PM
08/03/09 06:05 PM
Posts: 6,295 U.S.
moparniac
U.S.
well I just traded a edelbrock rpm intake for a ATI damner....
part# 916621 Hub part# 916661L
Will it work for a milodon gear drive?
Mopar Performance
[Re: moparniac]
#423831
08/03/09 07:15 PM
08/03/09 07:15 PM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
Which hole are you referring to?
