Re: New Paint job on a budget thread Part III
[Re: 69DartGT]
#39515
01/24/11 12:13 AM
01/24/11 12:13 AM
Posts: 66 NY
joeshmo
NY
Sambo101 how long has the paint been on the car?
joeshmo, I didn't like rustoleum either reason I used brightside.
Gorgeous truck, I am planing to put real urethane paint on mine. I just cracked. Roller paint definitely has some advantages and it has it's uses but when you have a compressor and a gun available, there is no reason to use it.
[Re: joeshmo]
#39516
01/25/11 01:07 AM
01/25/11 01:07 AM
Posts: 246 middleOnowhere CA
THEYOUNGGUN53
middleOnowhere CA
if you don't want to deal with messy overspray its a better alternative.
a car is never "done"
[Re: THEYOUNGGUN53]
#39517
01/25/11 01:31 AM
01/25/11 01:31 AM
Posts: 66 NY
joeshmo
NY
Absolutely true. Rusto-black just doesn't suit me as it is grayish. I will however post my findings of putting real auto-paint over rustoleum. Most people say it will lift but I plan on doing a test-hood and I bet with proper primer it'd be fine.
[Re: sambo101]
#39519
02/06/11 03:55 PM
02/06/11 03:55 PM
THEYOUNGGUN53
middleOnowhere CA
if oyu let the paint cure for about 3 weeks to a month and then do the final wet sanding and polishing you will get much better results. Soft paint doesn't wet sand or polish to well.
[Re: joeshmo]
#39520
02/06/11 07:14 PM
02/06/11 07:14 PM
Posts: 129 Springfield, MO
Steve88
Springfield, MO
That looks great younggun! I have a slight problem with my rusto paintjob however. It has been snowing/freezing here for weeks and it finally thawed and melted and I found that there is a spot where paint is missing on my hood. The odd thing is that my paint is gloss black and where the paint is missing is white. I used brown-oxide primer (the rustoleum for rusty metal primer) so where in the world did the white come from? I'll post pictures tomorrow.
I have been reading some info on the Rustloeum forums and the company recommended not using the rusty metal primer on any meatal that was not covered in rust. They said that the rusty metal primer contained fish oils and other additives that is used to coat the rust but if it was used on clean metal it would likely cause the top coat not to adhere properly.
[Re: Steve88]
#39521
02/07/11 10:35 PM
02/07/11 10:35 PM
Posts: 66 NY
joeshmo
NY
I have read this as well but it has only had adhesion problems on select parts. Mainly parts immersed in UV.
[Re: joeshmo]
#39522
03/21/11 02:21 PM
03/21/11 02:21 PM
Posts: 13 toronto, ohio
andyoucankeepit
toronto, ohio
has anyone had good luck with rolling rustoleum paint over or even using it under rustoleum brand paintable undercoating?
i didn't get to fully finish my car, and i have surface rust showing through the areas where i used spray undercoating.
my process for undercoating: sand regular and prep as regular put down 2 thin coats spray undercoating following directions for time, follow up with multiple coats of undercoating
i drilled holes in my new fenders to mount some trim, and touched it up with white paint. the paint never seemed to dry over top of the undercoating, turned brown, and i still wound up having rust around my drilled holes (in my new fenders!).
i planned on doing two tone on my older fox hatch and have a color mixed to match the original lower gray, but now i am wondering if the paint will just even change color, not adhere, or even rust from the backside-out......
has anyone used other products? anyone try the spray bedliner with rustoleum roll paint?
thank you for any tips and advice.
03 cobra, 85 mustang, 59 galaxie, 68 sportster
[Re: joeshmo]
#39524
03/29/11 11:45 AM
03/29/11 11:45 AM
andyoucankeepit
toronto, ohio
mine held up through ohio winter(tons of salt in my specific area).
i am just upset that what i had used to protect certain vulnerable areas had failed me. i honestly think that the paint looks really good, and without washing it through the winter, i am very surprised at the shine that it had kept.
[Re: andyoucankeepit]
#39525
04/18/11 12:10 AM
04/18/11 12:10 AM
Posts: 1 Simi Valley, CA
Vinnems
Simi Valley, CA
First off, I'd like to thank everyone here for ruining my life ![](/ubbthreads/images/graemlins/tongue.gif) I discovered this topic via a link from The Samba, which I see many of us have made the pilgrimage from. I as up until sunrise last night reading this, and not sleeping because I couldn't stop thinking about it. I paid $5K for a paint job for one reason and one reason alone: I didn't have the facilities. If I could build a booth in my garage, I would've sprayed this thing, but I'm already pressed for space with just the car. Seeing this topic made me feel crushed. But, this car has been a learning experience for me, so the next one will be better (and $5K cheaper!) Have a few questions, though: 1. Definitely want to go the Brightside route. Sounds all around better. Has anyone put together a thorough guide on how to do it, yet? I've picked up bits and pieces from this topic, but hoping someone collaborated everything in one place. 2. Can Brightside paints me mixed with each other? As in can I add some white to the light blue to make it even lighter? I'm talking only using Brightside paints, not mixing other brands into it or tinting it. 3. How does the paint store? I was hoping to buy a gallon of the stuff, mix up my color, and save it to fix up dings and such without having to worry about mixing more and not getting the right color. 4. Foam rollers are awesome, I laid down Masterseries on my chassis with one beautifully, but not applicable in certain places. What about doing car rims, for example, which aren't very flat and full of curves and holes and such? Thanks guys. Hoping to use this stuff to paint my rims and some interior pieces I have left. And to do many, many more cars in the future ![](/ubbthreads/images/graemlins/smile.gif)
[Re: Vinnems]
#39526
04/20/11 11:56 AM
04/20/11 11:56 AM
Posts: 1,160 Cruising!
QuickDodge
Cruising!
To paint wheels,brackets, and other odd shaped pieces, I'd spray the paint. The easiest and cheapest route is to use rattle cans from the hardware store. A better plan is to use the little Preval sprayers. These sprayers are similar to the rattle cans, but allow a person to spray better quality paint. In fact, regular automotive paint can be used with these. (but wear all the necessary safety gear) These little sprayers are available at Hardware stores, paint stores etc. To see what they look like: www.preval.comIt is critical to get the paint mixed thin enough so it will spray properly. If it's to thick the results will NOT be good!! (or it may not spray at all!) I'd suggest spraying some on a practice piece first.
[Re: Payton]
#39528
05/08/11 09:31 AM
05/08/11 09:31 AM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
How does the flat black do with dust, dirt, bird droppings, etc.?
It looks great by the way.
[Re: Exit1965]
#39529
05/08/11 10:20 AM
05/08/11 10:20 AM
Posts: 4,085 Mo.
racerx
Mo.
I wood like to know also so i'll just ![](/ubbthreads/images/graemlins/bump.gif)
[Re: Payton]
#39531
05/14/11 09:05 PM
05/14/11 09:05 PM
Posts: 51 CA
Peckinpah
CA
Seems like that flat finish would be a magnet for dust, dirt, tree sap, etc., since there's no protective layer of wax, no clearcoat, and not even a buffed out finish.
I used Rusto Gloss White, and have tons of problems with things like bird crap, tree sap, road tar, and bug juice soaking right into my paint, requiring me to use bleach to get rid of etched-in stains.
Plus, with no protective clearcoat, I have to scrub twice as hard to get the paint clean.
I am considering either a spray-on clearcoat or simply painting over the Rustoleum with Brightside that's the same color (Gloss White).
Anyone have any suggestions?
