Re: New Paint job on a budget thread Part III
[Re: Jerry]
#39477
11/12/10 10:53 PM
11/12/10 10:53 PM
Posts: 246 middleOnowhere CA
THEYOUNGGUN53
middleOnowhere CA
did you keep up with washing and waxing it? also polishing it occasionally will bring the shine back no problem. Any car will fade if not properly cared for and left out in the elements.
a car is never "done"
[Re: jae]
#39480
11/23/10 07:08 PM
11/23/10 07:08 PM
Posts: 66 NY
joeshmo
NY
I have simple question Help please~
What brand of rustoleum paints are we using? I went to homedepot and I see "regular rustoleum (white can)" and I see "professional high performance " paints.
I asked what brand dries harder? and the person at HD told me "it should be "professional high performance (grey can)" ( he is not 100% sure).
But! On professional high performance brand you can't thin it with "mineral spirits" but can thin it with acetone.
But, on regular rustoleum you can thin it with mineral spirits(only).
So which one is it???
Professional and stops-rust are pretty much the same. Both can be thinned with mineral spirits and I doubt one paint is truly superior to the other. The advantage to the stops-rust paint is that it comes in quarts and professional comes in gallons only. I would go with stops-rust myself simply for this fact, because a contaminated quart of paint is much less harmful than a wasted gallon. Just my
[Re: pdqvsix]
#39482
11/25/10 01:37 AM
11/25/10 01:37 AM
Posts: 3 new jersey, USA
jae
new jersey, USA
Ok Thanks... now whats this "Brightside paint" ? I thought everyone was using rustoleum paints??
[Re: jae]
#39484
11/25/10 04:12 PM
11/25/10 04:12 PM
Posts: 66 NY
joeshmo
NY
Brightside is a 1 part urethane yacht-paint that can also be rolled like rustoleum. It's a bit more expensive but they say it has better gloss and UV protection and ect.
[Re: sambo101]
#39487
12/16/10 05:32 AM
12/16/10 05:32 AM
Posts: 16 oz
sambo101
oz
paint after 3rd coat unsanded Where i have rubbed back to baremetal is seem to show through, is this normal or do i just need to do more coats?
[Re: sambo101]
#39488
12/16/10 05:46 PM
12/16/10 05:46 PM
Posts: 66 NY
joeshmo
NY
Just keep goin. With thin layers it takes many coats to get full coverage. What color was it originally? Also, what paint are you using?
[Re: sambo101]
#39490
12/17/10 10:08 PM
12/17/10 10:08 PM
Posts: 66 NY
joeshmo
NY
Hey, the car was originally a gold color,
And i am using bright side fire red marine paint which my dad had lying around, this is just a test piece.
Would a color such as black require less coats, and show results quicker?
I seem to have roller marks as well, do i need to thin the paint more?
Roller marks are taken out with wetsanding and buffing eventually but thinning more may help reduce them. What temps are to rolling at and what kind of roller are you using?
[Re: joeshmo]
#39491
12/18/10 02:51 AM
12/18/10 02:51 AM
Posts: 16 oz
sambo101
oz
The temp is about 24 degrees, and im using the 4" high density foam ones. Here is the mixture i used. * 100ml Penetrol * 75ml Turps * 375-400ml Paint Here is a pic of the the 4th coat unsanded.
[Re: sambo101]
#39492
12/18/10 02:53 AM
12/18/10 02:53 AM
Posts: 16 oz
sambo101
oz
would adding a white base coat make any difference?
Also I read way back in the thread some people were not putting any thinners in the bright side paint, and were getting full coverage after just 2 coats? any negatives to this?
[Re: sambo101]
#39493
12/18/10 03:23 AM
12/18/10 03:23 AM
Posts: 66 NY
joeshmo
NY
Not adding any thinner would make the paint apply much more thick and you would probably get a considerable amount more orange peel. Going over a base or primer will let you cover in a fewer coats but your progress looks pretty good. You're using actual turpentine for thinner though? I suggest mineral spirits or thinning fluid from brightside. Also, that seems like a bit much penetrol but I might be wrong. Try a coat without penetrol at all.
