Page 7 of 7 1 2 3 4 5 6 7
Re: A Body Guys Post Your Vehicle Weight! [Re: BLONDE BARRACUDA] #367010
03/23/11 12:03 AM
03/23/11 12:03 AM
Kentucky
clovis Offline
clovis  Offline
Kentucky
'75 Duster, BB B, iron heads, tunnel ram 2x4, 8 3/4, 8 pt bars, stock dash, 2 racing buckets-no back seat, all steel except for some fiberglass bumpers- 2,980 lbs full of fuel and without me.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: A Body Guys Post Your Vehicle Weight! [Re: 11secdart] #367011
03/23/11 10:01 AM
03/23/11 10:01 AM
gregsdart Offline
gregsdart  Offline
full cage .134 x 1 3/4 on 2 x 3 .125 wall frame rails, glass hood and deck lid. All lexan, gutted doors, four wheel race disc brakes. Ladderbars, rack and stock upper/lower control arms on fabricated mounts. Dana 60, megablock with aluminum 440-1 heads and torqueflite. One battery. Car only 2750 lbs.
The chassis only needs the funnycar cage to be 7.50 legal.
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #367012
08/17/12 08:21 PM
08/17/12 08:21 PM
U.S.
moparniac Offline OP
U.S.
bump
Mopar Performance
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #367013
08/17/12 10:43 PM
08/17/12 10:43 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
3175 with me in it fiberglass hood only all steel full interior
Re: A Body Guys Post Your Vehicle Weight! [Re: one bad fish] #367014
08/18/12 10:34 AM
08/18/12 10:34 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
71 Dart all steel except front and rear bumpers, stock glass and superstock springs, with 8 point bar no back seat or carpet. This was when it had a all iron small block. Was weighed at IHRA pro am did the front then rolled on the rears. 1740 front 1562 rear with me in it.
Re: A Body Guys Post Your Vehicle Weight! [Re: B1MAXX] #367015
08/18/12 10:52 AM
08/18/12 10:52 AM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
76 duster 440 old indy aluminum glass hood and trunk. no interior 8pt steel bar frame connected 2x3 steel ford 9" 727 trans. 3170# with me in it.
took front bumper off @94lb made it 7 lb but new engine has 3/4 stud girdle and half fill. so i will be lucky to have half the 85 odd pounds i took off the front with the bumper
Re: A Body Guys Post Your Vehicle Weight! [Re: dmking] #367016
08/20/12 11:30 PM
08/20/12 11:30 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
70' Dart....
4-link backhalf w/sheetmetal housing, drilled 40 spline axles, spool and aluminum center.
4130 cage w/removeable aluminum trans tunnel and fabricated firewall.
Holeshot Pentastar rims...15x15-15x3.5 with M/T fronts and Hoosier QTP, 17x33 rear.
Stock front rails w/Alterkation and post column.
Aluminum Ron Davis rad with dual Spal fans.
21 pound battery.
R3-W8 w/420 intake.
Lightweight T-400 w/JW bell w/8in converter, B&M cooler and PPP shifter.
2 aluminum seats, lightweight rug and headliner.
Lexan windows.
Completely blasted steel clip with 2 new AMD full quarters.
One piece glass nose, hood, scoop, doors, decklid, dash, front and rear bumpers and rear splash.
PST carbon driveshaft.
Single chute.
Aluminum wing.
Magnafuel 500 pump w/12 gallon cell.
4130 wheelie bars.
Stock head and tail lights w/no side lights,or door handles and shaved drip rails.
Stock grille.
4in Spintech oval exhaust system....exit before rear tires.
About 2620# w/5gallons of C-25 and 200# driver.
Re: A Body Guys Post Your Vehicle Weight! [Re: jim sciortino] #367017
08/21/12 11:33 AM
08/21/12 11:33 AM
Finland
mafo Offline
mafo  Offline
Finland
You must have helium filled tires
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: A Body Guys Post Your Vehicle Weight! [Re: mafo] #367018
08/21/12 12:22 PM
08/21/12 12:22 PM
fresno ca
mikeysmopars Offline
fresno ca
Mine is typical minitubed ladder bar but has old school leafspring slider set up. Low deck with aluminum heads, glass hood,deck lid & front Bumper. weighs in at 3210 with me.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: A Body Guys Post Your Vehicle Weight! [Re: mikeysmopars] #367019
08/21/12 01:55 PM
08/21/12 01:55 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
My old 76 Feather Duster
fibreglass front bumper, hood and trunklid, lexan windows, 8.50 cert mild steel cage, LRT front moly front end, ladder bar backhalf, aluminu, shell trunk lid, four wheel discs, aluminum center section
498 RB Cast block, Indy SR heads, afco rad
was 2880 with 220 lbs driver race ready
76 Duster work in progress
Re: A Body Guys Post Your Vehicle Weight! [Re: Edge] #367020
08/21/12 02:47 PM
08/21/12 02:47 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
My car is 2925# with me in it. Stock floors and wheel tubs, SS springs, 6 pt cage, stock dash, one racing seat and a lowly 360 with a 727. Runs very consistent 11.21-11.23 no matter what the temp is outside.
Re: A Body Guys Post Your Vehicle Weight! [Re: mafo] #367021
08/21/12 03:28 PM
08/21/12 03:28 PM
Trumbull,CT.
Trumbull,CT.
Titanium.
I was thinkin' the weight was decent considering the big rad, dual fans, exhaust w/mufflers, 8 ply front tires and my brother in the car who's 20 pounds more than me.
Re: A Body Guys Post Your Vehicle Weight! [Re: jim sciortino] #367022
08/21/12 05:58 PM
08/21/12 05:58 PM
SO. FLA
W
W2WHO Offline
W2WHO  Offline
W
SO. FLA
STREET CAR. 3565 LBS. W/DRIVER FULL INTERIOR, MUFFLERS, ALUM HEADED BIG BLOCK DANA. BEST 1.35 60FT. 9.66 @138 MPH RADIAL DOT
Re: A Body Guys Post Your Vehicle Weight! [Re: W2WHO] #367023
08/22/12 02:21 PM
08/22/12 02:21 PM
SO. FLA
W
W2WHO Offline
W2WHO  Offline
W
SO. FLA
3200 LBS. W/DRIVER ALUM HEADED SMALL BLOCK BEST 1.37 60FT. 9.98 @ 133 ALL MOTOR, RADIAL TIRE STREET BEATER.
Re: A Body Guys Post Your Vehicle Weight! [Re: Al_Alguire] #367024
08/22/12 02:48 PM
08/22/12 02:48 PM
Ohio
3404 Offline
3404  Offline
Ohio
Fiberglass deck lid, hood, and bumpers. Mild steel cage with minimum bars for 8.50 cert. 4 link/Dana60 RB Mopar Mega block with glide. All lexan. 2x3 main frame rails.
2840 with me in it.
