Re: A Body Guys Post Your Vehicle Weight!
[Re: BLONDE BARRACUDA]
#367010
03/23/11 12:03 AM
03/23/11 12:03 AM
Posts: 554 Kentucky
clovis
Kentucky
'75 Duster, BB B, iron heads, tunnel ram 2x4, 8 3/4, 8 pt bars, stock dash, 2 racing buckets-no back seat, all steel except for some fiberglass bumpers- 2,980 lbs full of fuel and without me.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: 11secdart]
#367011
03/23/11 10:01 AM
03/23/11 10:01 AM
Posts: 10,035 Frostbitefalls MN (Rocky&Bullw...
gregsdart
full cage .134 x 1 3/4 on 2 x 3 .125 wall frame rails, glass hood and deck lid. All lexan, gutted doors, four wheel race disc brakes. Ladderbars, rack and stock upper/lower control arms on fabricated mounts. Dana 60, megablock with aluminum 440-1 heads and torqueflite. One battery. Car only 2750 lbs. The chassis only needs the funnycar cage to be 7.50 legal.
[Re: dmking]
#367016
08/20/12 11:30 PM
08/20/12 11:30 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
70' Dart....
4-link backhalf w/sheetmetal housing, drilled 40 spline axles, spool and aluminum center. 4130 cage w/removeable aluminum trans tunnel and fabricated firewall. Holeshot Pentastar rims...15x15-15x3.5 with M/T fronts and Hoosier QTP, 17x33 rear. Stock front rails w/Alterkation and post column. Aluminum Ron Davis rad with dual Spal fans. 21 pound battery. R3-W8 w/420 intake. Lightweight T-400 w/JW bell w/8in converter, B&M cooler and PPP shifter. 2 aluminum seats, lightweight rug and headliner. Lexan windows. Completely blasted steel clip with 2 new AMD full quarters. One piece glass nose, hood, scoop, doors, decklid, dash, front and rear bumpers and rear splash. PST carbon driveshaft. Single chute. Aluminum wing. Magnafuel 500 pump w/12 gallon cell. 4130 wheelie bars. Stock head and tail lights w/no side lights,or door handles and shaved drip rails. Stock grille. 4in Spintech oval exhaust system....exit before rear tires.
About 2620# w/5gallons of C-25 and 200# driver.
[Re: mafo]
#367018
08/21/12 12:22 PM
08/21/12 12:22 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Mine is typical minitubed ladder bar but has old school leafspring slider set up. Low deck with aluminum heads, glass hood,deck lid & front Bumper. weighs in at 3210 with me.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#367019
08/21/12 01:55 PM
08/21/12 01:55 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
My old 76 Feather Duster fibreglass front bumper, hood and trunklid, lexan windows, 8.50 cert mild steel cage, LRT front moly front end, ladder bar backhalf, aluminu, shell trunk lid, four wheel discs, aluminum center section 498 RB Cast block, Indy SR heads, afco rad
was 2880 with 220 lbs driver race ready
76 Duster
work in progress
[Re: mafo]
#367021
08/21/12 03:28 PM
08/21/12 03:28 PM
jim sciortino
Trumbull,CT.
You must have helium filled tires
Titanium.
I was thinkin' the weight was decent considering the big rad, dual fans, exhaust w/mufflers, 8 ply front tires and my brother in the car who's 20 pounds more than me.
[Re: jim sciortino]
#367022
08/21/12 05:58 PM
08/21/12 05:58 PM
Posts: 46 SO. FLA
W2WHO
SO. FLA
STREET CAR. 3565 LBS. W/DRIVER FULL INTERIOR, MUFFLERS, ALUM HEADED BIG BLOCK DANA. BEST 1.35 60FT. 9.66 @138 MPH RADIAL DOT
