Re: New Paint job on a budget thread.
#36674
06/11/07 06:22 PM
06/11/07 06:22 PM
Posts: 5,660 Flint, MI
Gusteve
I Love the Unicorn Song!!
Flint, MI
I only have 2000 grit on me since Im a cheapo. But I do have 320 grit, so I guess I will be alternating a bit then. Sand longer with 320 and sand less with 2000 grit, hopefully that will put me in between.
Dude - 320 might take off the entire coat (or more) that you just did. Spend $5 and buy five sheets of 600 or 800.
[Re: Gusteve]
#36675
06/11/07 07:13 PM
06/11/07 07:13 PM
I had good luck with 100 grit. I was putting the coats on so light that if i used 800 I would start to get through to the other layer of paint below after a bit. But, 800 works well also for getting the orange peel out, just be careful with it and dont overdo it ![](/ubbthreads/images/graemlins/smile.gif)
[Re: Gusteve]
#36676
06/11/07 08:03 PM
06/11/07 08:03 PM
Will do ASAP! I will go with 800 then.
#36677
06/11/07 08:05 PM
06/11/07 08:05 PM
plum500
I have two new fav words. FOAM BRUSH. I was pleased with my second attempt at a first coat -- but still not satisfied. Many bubbles solved with a blast of air, but still much peel and tricky to roll.. and again, bubbles and such were being a pain. I spent 1.29 on a 4" foam brush. I wet sanded the first coat down, thinned another batch, probably around 40%, maybe 45%, and hit it with the foam brush. Like glass. No bubbles, and it is incredibly easy to lay a *very* even and *really* thin coat. Very easy to blend. I coated in pretty much 4 quadrants of the deck lid and as I finished each one, blended with some nice long sweeps of the brush...well... here's what I got... And no brush marks. Those lines you see running front to back are the reflection of the ceiling boards. ![](http://img384.imageshack.us/img384/9466/1000550smwk0.jpg)
#36679
06/11/07 08:18 PM
06/11/07 08:18 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
Marq:
Should I use the interlux 333 brush liquid to thin down the brightside prior to spraying? or would mineral spirits be just fine?
thanks!
Both worked equally on my car. The mineral spirit might give you a little extra working time before the paint starts setting. The 333 evaporates slightly quicker giving you a little less time to work out any runs or bubbles.
Either way.. the end result is about the same once they dry.
[Re: plum500]
#36680
06/11/07 08:24 PM
06/11/07 08:24 PM
What kind of foam brush are you using BTW? Simple generic kinds? I am using this foam roller...I saw someone else use it so I think it should be okay? ![](http://img524.imageshack.us/img524/6051/roll1oo1.jpg)
[Re: Marq]
#36682
06/11/07 08:42 PM
06/11/07 08:42 PM
At various points during my painting I also made use of a simple foam brush for doing the bubble popping sweep.
At Home Depot and Walmart they sell these grab bags of cheap foam 'paint brushes' They look like a dowl stuffed into a piece of black foam, that is shaped like a paint brush. They had 3/4 inch, 2 inch, 3 inch and 4 inch foam brushes all packed in these assortment bags.
I used the 3 inch and 4 inch to do the bubble popping... because they did a better, less lines or streaks, then a bristol brush.
BUT I stuck with my high density foam roller to lay the initial coats - and then followed it up almost immediately with the foam 'paint brush' to do the bubble popping and quick surface leveling.
Later I also did the two high density foam roller trick when I ran out of the cheap foam 'paint brushes'...
One handy thing about those cheap foam 'brushes' is that I was able to poke and prod them into some spots where the roller could not go. I would hit those crevices first with the appropriately size foam brush.. and then smooth out the edges with the roller. I hope that makes sense... use the foamies to paint any hard to reach spots on a panel... then proceed with your rollering of the rest of that surface second - in order to blend in the paint between the edges of the crevices and the rest of the panel.
But I think plum5000 actually stated that he used those foam brushes to paint his hood?
#36683
06/11/07 09:11 PM
06/11/07 09:11 PM
plum500
Yup! Whole deck lid done with a brush. The biggest differences I found were: with pressure, the brush didn't produce the bubbles, and 2nd, the brush didn't require any pressure vs the roller to get an evenly spread coat. Could be I just don't have the roller technique down, ![](/ubbthreads/images/graemlins/shruggy.gif) but I am definitely sticking with the brush. This is the one I used: ![](http://img53.imageshack.us/img53/7710/1000555smgd7.jpg)
#36684
06/11/07 09:19 PM
06/11/07 09:19 PM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
those are the EXACT ones i used!!! ![](/ubbthreads/images/graemlins/beer.gif)
my stuff:
![](http://i32.photobucket.com/albums/d13/69martin/paint/DSC03024.jpg)
![](http://i32.photobucket.com/albums/d13/69martin/paint/DSC03018.jpg)
foam brush i used, 25 package for $3.99 on sale:
![](http://i32.photobucket.com/albums/d13/69martin/paint/DSC03023.jpg)
![](/ubbthreads/images/graemlins/drinking.gif)
[Re: plum500]
#36686
06/11/07 11:07 PM
06/11/07 11:07 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
Could be I just don't have the roller technique down, but I am definitely sticking with the brush.
Well... heed my advice about watching out for those foam brushes to start disintegrating after prolonged contact with paint reduced with mineral spirits or 333 thinner.
Underneath the foam is a small sheet of plastic, which is attached to the wooden shaft. The foam is enveloped over the plastic sheet. The plastic sheet gives a 'bit' of rigidity to the foam brush.
The mineral spirit will first separate the glue that holds the foam to that piece of plastic. That is the first hint that the foam brush is nearing the end of its life.
The next sign will be when you start noticing strange unexplainable black 'stuff' in your paint. That will be when the foam itself is starting to disintegrate.
Switch to a new brush at that point ![](/ubbthreads/images/graemlins/wink.gif)
#36687
06/12/07 12:33 AM
06/12/07 12:33 AM
Thanks much DartGT and Marq =)
I have everything set- car is completely sanded... just waiting for the rain to stop...
My camera died on the first shot- it's charging now...
#36688
06/12/07 06:44 AM
06/12/07 06:44 AM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
Well... don't forget our 'enviromental' hints about humidity. It might be worthwhile to wait a day or two extra after the rain - so that the air is not loaded up with humidity.
When I was doing my car.. it started raining when I was preparing to add the final coat of paint. Even though I was painting inside the garage ( protected )... I ended up delaying that final coat for several days after that last rainstorm. And the funny thing is that it rained for almost 7 days... so in total I had to wait almost ten days to get that final coat of paint on.
Now.... I may have been overcautious.. but I did not want anything affecting how that coat of paint turned out. And it certainly was testing my patience to keep delaying the painting.. but I did not want to give in to that impatience and botch up the paint job.
Timing of the painting is essential to obtaining an optimal paint job ![](/ubbthreads/images/graemlins/wink.gif)
[Re: Blackstone]
#36690
06/12/07 09:46 AM
06/12/07 09:46 AM
plum500
If you're looking to match a color, and have a sample -- I also suggest Sico they make a product called Corrostop which is tintable to anything in their regular color chart, and I suspect that they also have the color matching capabilities as others. Basically the same as Rustoleum - if not an improved formula. Direct to metal, rust inhibiting, alkyd. For the body of my car, I'm using Sherwin Williams DTM. Again, industrial/marine, direct to metal, rust inhibiting alkyd -- tintable to anything in their chart -- or custom/color match. This way, you can be fairly secure in the ability to get more if you need it. Obviously care should be taken as to where you start/stop/repair or whatever -- but I'm gonna trust their computer controlled mixing a lot more than trying to duplicate a limited home-made mix. I would certainly trust it enough to attempt a blended repair, patch, or a single panel in need of a refresh. Just my 2 cents for those looking to expand beyond the Tremclad/Rustoleum color chart. ![](/ubbthreads/images/graemlins/shruggy.gif)
#36692
06/12/07 01:22 PM
06/12/07 01:22 PM
I hate sanding. Went out and bought 800 grit sandpaper. I sanded down most of my air bubbles away, admittedly very quickly because I'm sick and tired of sanding.
Hopefully I can get these next 2 coats on nicely without any orange peel so I don't have to sand every coat.
It's very hot out today, so I plan to paint later on in the day, maybe around 7PM when the sun is down.
Should I thin my mixture down like milk again? Or should I use a less thinned but more paint mixture and use less paint on my roller?
#36693
06/12/07 01:44 PM
06/12/07 01:44 PM
I agree sanding is the worst part of this job. My friend and I spent about 18 hours sanding down my convertible this week with 400 grit. The previous paint color had so much peel. It took forever to wet sand through it all. It's all done and nice and smooth now so this new color should go on easy.
I'm hoping to have minimal sanding when finished. The hardest part is removing scratching if you use too low of a grit.
Trick is to do it right the first time. Which I did not in my rush to finish it last summer.
