What's your take on this engine? #344569
06/12/09 07:45 AM
06/12/09 07:45 AM
Ontario, Canada
500ciBee Offline OP
500ciBee  Offline OP
Ontario, Canada
Price is $14500. What do you guys think? I haven't started my build yet and started looking around for a complete engine.
YOU ARE BIDDING on a MOPAR 400 to 500 cid STROKER COMPLETE DYNO-TESTED ENG 746HP @ 6000 RPM and 697 ft/lbs TQ @ 4800 RPM ON PUMP GAS!
OEM 400 BLOCK, EDELBROCK MAX-WEDGE HEADS
CNC MACHINED ON ROTTLER F65A
CLEARANCE LIFTER BORES
INDY BILLET REAR MAIN SEAL ASSEMBLY
400 MAIN GIRDLE ASSEMBLY
MILODON ADJ OIL PRESSURE REG.
EDELBROCK 77929 MODIFIED TO MAX-WEDGE
CYLINDER HEADS MAX-WEDGE PORTED
COATED COMBUSTION CHAMBERS
COATED VALVE FACES & STEMS
2.250 INTAKE VALVES & SPECIAL VALVE TRAIN
4.150" STROKER CRANKSHAFT 4340
4340 FORGED H-BEAM RODS
FULL FLOATING PISTON PINS
PUMP-GAS DIAMOND FORGED COATED PISTONS
TOTAL SEAL GAPLESS TOP FILE TO FIT RINGS
CUSTOM SOLID ROLLER CAMSHAFT
HUGHES SHAFT ROCKER SYSTEM
MOPAR PERFORMANCE VALVE COVERS
HIGH VOLUMN OILING SYSTEM
SMITH BROS PUSHRODS
1.540 VALVE SPRINGS
SOLID ROLLER LIFTERS
MANLEY VITON SEALS
INDY PORT MATCHED MAX-WEDGE INTAKE
CUSTOM PC POWDER-COATED CARB
INDY VALLEY TRAY, ARP FASTENERS
MSD 8546 BILLET DISTRIBUTOR
3 BOLT BILLET TIMING SET
MILODON 30890 PAN WITH PICK-UP
COATED GROOVED BEARINGS
FELPRO GASKETS, ARP FASTENERS
ATI SFI SUPER HARMONIC DAMPER
MILODON BRONZE GEAR
BALANCED ROTATING ASSEMBY
SPEEDOMOTIVE EXPERT ASSEMBLY
DYNO-TESTED ON 91 OCTANE
746HP @ 6000 RPM
CALL FOR DETAILS
ADDITIONAL INFORMATION AVAILABLE. CALL US AT 626-869-0270, ASK FOR GEORGE.
Call SPEEDOMOTIVE @ 1-626-869-0270 if you have questions about this ebay listing [ask for George].
SHIPPING is FIGURED AT AUCTION END EXACT DEPENDING ON YOUR ZIP CODE. CALL OR EMAIL US FOR A PROMPT QUOTE. Call SPEEDOMOTIVE @ 1-626-869-0270 if you have questions about this ebay listing.
Engine building by Speedomotive using zero deck quench motor technology. If you would like to know the engine building secrets, specifically the ones used in this ebay listed item, click here>> SPEED SECRETS
Compression ratio is figured at zero deck quench motor build: To check our math, click here>> TECHNICAL INFORMATION
Seller accepts Paypal, Cashier's Check, Money Order, Visa/Master Card/Discover or
AT AUCTION END YOU MAY CALL SPEEDOMOTIVE @ 1-626-869-0270 TO USE YOUR CREDIT CARD AND GET FAST SERVICE.
Our ebay store has many other engine builds, check it out, click here>> EBAY STORE
SPEEDOMOTIVE is interested in YOUR engine build project. We are friendly and helpful to talk to. We THANK YOU for looking at this ebay listing. We would like to hear from you. Call SPEEDOMOTIVE @ 1-626-869-0270 if you have questions about this ebay listing.
FOR TECHNICAL INFO REGARDING THIS LISTED engine build, CALL George @ 1-626-869-0270
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
Re: What's your take on this engine? [Re: 500ciBee] #344570
06/12/09 08:48 AM
06/12/09 08:48 AM
Northeast Georgia
47hudson Offline
47hudson  Offline
Northeast Georgia
I wouldn't be as afraid of the engine being as its from an known engine builder as I would if it was "joe racer", but I would rather put that money into building an engine myself. Thats just me, but engines that I don't see going together or have my hands on worry me. You just hear too many horror stories. I understand that is not an option for some, but even if I ordered an engine I think I would want to at least be involved in the setup.
Re: What's your take on this engine? [Re: 500ciBee] #344571
06/12/09 08:54 AM
06/12/09 08:54 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
what exactly is a "special" valvetrain?
Re: What's your take on this engine? [Re: 500ciBee] #344572
06/12/09 09:27 AM
06/12/09 09:27 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have seen a couple of horror stories on here about Speed o motive
Re: What's your take on this engine? [Re: 70blackfish] #344573
06/12/09 09:39 AM
06/12/09 09:39 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
X2
Re: What's your take on this engine? [Re: 70blackfish] #344574
06/12/09 09:39 AM
06/12/09 09:39 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
to much money for a build around a"stock" 40 year old block
Re: What's your take on this engine? [Re: boatracer572] #344575
06/12/09 10:13 AM
06/12/09 10:13 AM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
x10---way too high!
Re: What's your take on this engine? [Re: hemiiroc] #344576
06/12/09 11:04 AM
06/12/09 11:04 AM
JohnRR Offline
JohnRR  Offline
x10---way too high!
I agree with that also , old tech build , should be a 4.25 stroke crank with BBC spec rods plus coatings that aren't really required and I'd be curious if they were really in there , plus I would want to WITNESS the actual dyno session on the actual motor ...
Re: What's your take on this engine? [Re: JohnRR] #344577
06/12/09 11:35 AM
06/12/09 11:35 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I agree, I could build that engine for around that price with a aftermarket block. And going with a cheaper stroker kit, end up with 572 cubes
Re: What's your take on this engine? [Re: Bob_Coomer] #344578
06/13/09 08:58 AM
06/13/09 08:58 AM
Ontario, Canada
500ciBee Offline OP
500ciBee  Offline OP
Ontario, Canada
Thanks guys!!
Our plan was to build a 500-512 stroker using a 400 block. Logistically it's been tough getting the time set aside to work on the build. Living in Ontario, Canada parts are more expensive to buy and ship. Also, I know of a few machine shops around but most seem to cater to the Mustang(ford) crowd.
We have a fairly strong running 383 with some good reusable parts to build our extra 400 into a 512. I'd much rather be apart of the build and not spend $14500 or $16500cdn if I don't have to.
Can you guys recommend a good shop in the Toronto, SW Ontario, area that have experience building Mopars?
Thanks!!
Re: What's your take on this engine? [Re: JohnRR] #344579
06/13/09 10:19 AM
06/13/09 10:19 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
X2
The member on here that bashing Speed-O-Motive had some serious credibility problems. He apparently was a scammer and constantly changed his Moparts screen name to cover up some of the shoddy deals he had in the classifieds. Most of what he claimed about the S-O-M motor were lies.
'68fastback' can fill in some of the details.
Re: What's your take on this engine? [Re: 500ciBee] #344580
06/13/09 10:38 AM
06/13/09 10:38 AM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
I have been using a shop in Aurora. They do build some Mopars but they mainly do stock car stuff and cylinder heads. I just have them do machine work and cylinder head freshen ups and I assemble the engine.
I'll be dropping a block off there next week.
87 dakota 6.1 hemi
Re: What's your take on this engine? [Re: B5 Bee] #344581
06/13/09 10:58 AM
06/13/09 10:58 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
A few years ago a buddy hydro locked a 360 stroker he got from them , He had a bad carb , flooded it and bent a rod cranking , He got it as a short block for around 3k , I fixed it for him and cant say that anything was out of spec or poorly done, not my choise of parts but thats what they said was it for 3k,I am not defending the builder but IMO there are two sides to every story and its not really fair if the builder cant represent himself , as far as the big stroker goes, I dont think its worth the big bucks outa a stock block
Re: What's your take on this engine? [Re: Bob_Coomer] #344582
06/13/09 06:04 PM
06/13/09 06:04 PM
Lehigh Acres, Florida
rickstershemi Offline
I agree
Rickster
Re: What's your take on this engine? [Re: rickstershemi] #344583
06/13/09 07:22 PM
06/13/09 07:22 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I agree
Rickster
Me 3 !
I am a little suspicious of those dyno numbers my self, that is a lot of power for a 500 turning 6000, I would expect just a tad less power and a much higher rpm. Not many motors can make 1.5 hp per cube at 6000
Re: What's your take on this engine? [Re: HotRodDave] #344584
06/13/09 09:41 PM
06/13/09 09:41 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
Muscle motors advertises some "Killer krate" engines that sound pretty reasonable.
Re: What's your take on this engine? [Re: Joshs68] #344585
06/13/09 09:49 PM
06/13/09 09:49 PM
PM arc on the board, he has a new 572 with a megablock that dynoed 931 hp with 572-13 indy heads for that price.all top of the line parts too.
Re: What's your take on this engine? [Re: HotRodDave] #344586
06/14/09 12:15 AM
06/14/09 12:15 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Me 3 !
Yes
I didnt want to say anything, but I agree 100%
Re: What's your take on this engine? [Re: B5 Bee] #344587
06/14/09 03:34 AM
06/14/09 03:34 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
X2
That wingnut is still on here after burning one member on a car and trying to do the same with another car. He always attacks the truth.
But for that amount of money check around especially on here you should be able to maximize your money in these times. Good luck.
Re: What's your take on this engine? [Re: 500ciBee] #344588
06/14/09 08:00 AM
06/14/09 08:00 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Thanks!!
In Toronto... Competition Automotive.
Further East... FHO For Hemis Only. He will build a wedge too.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
