Price is $14500. What do you guys think? I haven't started my build yet and started looking around for a complete engine.
YOU ARE BIDDING on a MOPAR 400 to 500 cid STROKER COMPLETE DYNO-TESTED ENG 746HP @ 6000 RPM and 697 ft/lbs TQ @ 4800 RPM ON PUMP GAS!
OEM 400 BLOCK, EDELBROCK MAX-WEDGE HEADS
CNC MACHINED ON ROTTLER F65A
CLEARANCE LIFTER BORES
INDY BILLET REAR MAIN SEAL ASSEMBLY
400 MAIN GIRDLE ASSEMBLY
MILODON ADJ OIL PRESSURE REG.
EDELBROCK 77929 MODIFIED TO MAX-WEDGE
CYLINDER HEADS MAX-WEDGE PORTED
COATED COMBUSTION CHAMBERS
COATED VALVE FACES & STEMS
2.250 INTAKE VALVES & SPECIAL VALVE TRAIN
4.150" STROKER CRANKSHAFT 4340
4340 FORGED H-BEAM RODS
FULL FLOATING PISTON PINS
PUMP-GAS DIAMOND FORGED COATED PISTONS
TOTAL SEAL GAPLESS TOP FILE TO FIT RINGS
CUSTOM SOLID ROLLER CAMSHAFT
HUGHES SHAFT ROCKER SYSTEM
MOPAR PERFORMANCE VALVE COVERS
HIGH VOLUMN OILING SYSTEM
SMITH BROS PUSHRODS
1.540 VALVE SPRINGS
SOLID ROLLER LIFTERS
MANLEY VITON SEALS
INDY PORT MATCHED MAX-WEDGE INTAKE
CUSTOM PC POWDER-COATED CARB
INDY VALLEY TRAY, ARP FASTENERS
MSD 8546 BILLET DISTRIBUTOR
3 BOLT BILLET TIMING SET
MILODON 30890 PAN WITH PICK-UP
COATED GROOVED BEARINGS
FELPRO GASKETS, ARP FASTENERS
ATI SFI SUPER HARMONIC DAMPER
MILODON BRONZE GEAR
BALANCED ROTATING ASSEMBY
SPEEDOMOTIVE EXPERT ASSEMBLY
DYNO-TESTED ON 91 OCTANE
746HP @ 6000 RPM
CALL FOR DETAILS
ADDITIONAL INFORMATION AVAILABLE. CALL US AT 626-869-0270, ASK FOR GEORGE.
Call SPEEDOMOTIVE @ 1-626-869-0270 if you have questions about this ebay listing [ask for George].
SHIPPING is FIGURED AT AUCTION END EXACT DEPENDING ON YOUR ZIP CODE. CALL OR EMAIL US FOR A PROMPT QUOTE. Call SPEEDOMOTIVE @ 1-626-869-0270 if you have questions about this ebay listing.
Engine building by Speedomotive using zero deck quench motor technology. If you would like to know the engine building secrets, specifically the ones used in this ebay listed item, click here>> SPEED SECRETS
Compression ratio is figured at zero deck quench motor build: To check our math, click here>> TECHNICAL INFORMATION
Seller accepts Paypal, Cashier's Check, Money Order, Visa/Master Card/Discover or
AT AUCTION END YOU MAY CALL SPEEDOMOTIVE @ 1-626-869-0270 TO USE YOUR CREDIT CARD AND GET FAST SERVICE.
Our ebay store has many other engine builds, check it out, click here>> EBAY STORE
SPEEDOMOTIVE is interested in YOUR engine build project. We are friendly and helpful to talk to. We THANK YOU for looking at this ebay listing. We would like to hear from you. Call SPEEDOMOTIVE @ 1-626-869-0270 if you have questions about this ebay listing.
FOR TECHNICAL INFO REGARDING THIS LISTED engine build, CALL George @ 1-626-869-0270
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
