Page 9 of 13 1 2 7 8 9 10 11 12 13
Re: VIN Stamping: MYTH or FACT [Re: cudaboone] #342577
03/27/11 10:55 AM
03/27/11 10:55 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
It's tough to stamp an engine block or transmission correctly after a 12 pack of beer and/or a couple of joints at the factory.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: VIN Stamping: MYTH or FACT [Re: 70HemiGTX] #342578
03/27/11 11:44 AM
03/27/11 11:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Were the blocks, trans, rad. support, and the trunk seal lip all stamped at the same time? I have thought about this before, but never saw anything posted anywhere. You would think this would make sense, because I assumed they would make a "stamp pad" up with the numbers on and slam it into all needing areas at once, then change the next # for the next car and just keep going. Maybe I'm totally wrong also.
No they were not, the body was stamped before it was painted , the engine and trans were in a different part of the plant. They used different fonts for some digits , like the 6 and 1
Re: VIN Stamping: MYTH or FACT [Re: JohnRR] #342579
03/27/11 12:14 PM
03/27/11 12:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yep, and the engine ID top pad stampings were done at a different location (engine assembly area) and accordingly, done with a different set of stamping dies than the application of the VIN sequence stamping (assembly line) as well.
Re: VIN Stamping: MYTH or FACT [Re: MY340] #342580
03/27/11 03:17 PM
03/27/11 03:17 PM
Anchorage, Alaska
Iceman01 Offline
Challenged
Iceman01  Offline
Challenged
Anchorage, Alaska
I never fail to get a kick out of reading these types of threads where our resident experts authoritatively try to determine with 100% accuracy what happened 40 odd years ago in a distant factory -- particularly when they themselves were never in one!
The author above has accurately described my own recollections of working in the mid-late 1970s at Chevrolet Metal Fabricating, Buick Final Assembly and Fisher Body in Flint, Michigan. While I readily admit the details I observed in those GM factories likely differ from those found at Chrysler, I bet they don't differ that substantially. The general state of the blue collar, auto industry at that time was the same everywhere.
As such, it is difficult to see how anyone can authoritatively state that anything coming from those factories was either possible or impossible back then. Yes, you can know what the company's policies were. Yes, you can talk to the old timers who worked the line. But in the end, what happened each day out on the line was inconsistent at best. There was a lame effort at quality control, but it never got close to producing 100% positive results at anything! General statements about what we think likely happened at the factory are the best we can do.
Obvious fraud needs to be called out when seen, but be careful about what you definitively state. These discussions almost always end up putting a cloud of suspicion over the car in question. That's appropriate in cases of obvious fraud, but financially damaging to those whose only crime is that they happen to have a car built by a factory line worker who went out to his car for lunch that day and had a couple beers and a joint. DAMHIK...
Re: VIN Stamping: MYTH or FACT [Re: Iceman01] #342581
03/27/11 03:47 PM
03/27/11 03:47 PM
PNW
Beebuzzn Offline
Beebuzzn  Offline
PNW
I'll second that. When I worked at a big plane manufacture for many years you would see the same thing. With sub assy. part numbers most were hand stamped and even with everyone using the same tools there was still some variation. That's why they started using pin stamp machines and even then there was variations between the operators. It did help thou after those long lunches I heard.
Re: VIN Stamping: MYTH or FACT [Re: LimeliteAero] #342582
03/27/11 08:47 PM
03/27/11 08:47 PM
MO
cdp Offline
cdp  Offline
MO
regarding the issue of trans vs engine with the numbers not be in the same alignment.
Isnt it possible the production line worker saw the mis-alignment and corrected it before stamping the matching item?
On the trans, I believe that you are 100% right on that. The misplaced 7 probably was not deep enough, so they stamped it by hand separately. I had to do it myself at a previous job.
The block, I believe, was not done by ma-mopar. Too wide, too tall, etc. The machined pad being "too deep" I don't believe is true. It could be core shift, machine set up, etc., during original manufacturing. That doesn't necessarily mean it couldn't have been done at a dealership, etc., for a factory replacement. But, I'd be willing to bet 99% of the replacement motors were never stamped.
I worked for Stahl's Specialty aluminum foundry from 1993-1998 in the quality conrtol department.
The automatic stamping machines had their stamps changed out every shift. If a stamp was getting worn, allot of the times they would shim it to get more use. Which causes 1 stamp to gouge deeper into the metal than the rest, or sometimes, they would do nothing, and a few characters would be very faint.
I'd say 80% of the products were hand stamped. Replacement stamps were kept in the tool crib and workers would change out and return letters/stamps every day for the correct ones they needed. There was obvious room for human error, but the 1st thing for the day as an inspector was to check all the lines for correct dates/part #'s.
Re: VIN Stamping: MYTH or FACT [Re: cdp] #342583
03/27/11 11:11 PM
03/27/11 11:11 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
here,s an interesting one.. i bought this off craigslist a few weeks ago F 440 HP2 7 28..
ck out the vin pad on the block with 9B 292747 under it! i suspect this engine had a problem at the factory and when it was repaired it then went into a 70 car as based on the pad stamp also notice the funny little star.. dan
Re: VIN Stamping: MYTH or FACT [Re: ph23vo] #342584
03/27/11 11:13 PM
03/27/11 11:13 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
pad kinda hard to read some idiot hit it with a pretty heavy grinder to clean it off sometime..
Re: VIN Stamping: MYTH or FACT [Re: ph23vo] #342585
03/27/11 11:18 PM
03/27/11 11:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Dan the star is likely a line worker or inspectors mark which is likely there due to the re-stamp.
Re: VIN Stamping: MYTH or FACT [Re: ScottSmith_Harms] #342586
03/27/11 11:20 PM
03/27/11 11:20 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
so what do you think happened? the cast date is 11/18/68! dan
Re: VIN Stamping: MYTH or FACT [Re: ph23vo] #342587
03/28/11 01:03 AM
03/28/11 01:03 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
I agree with Scott and have one like that in my collection. I'll try to post some pics.
Re: VIN Stamping: MYTH or FACT [Re: Paul Jacobs] #342588
03/28/11 01:37 AM
03/28/11 01:37 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
so something happened to the block/engine and it never got out of the factory possibly? then it was repaired and re used at a later date? correct? maybe? thanks guys dan
Re: VIN Stamping: MYTH or FACT [Re: ScottSmith_Harms] #342589
03/28/11 02:02 AM
03/28/11 02:02 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
So my car doesn't have the original motor. If I restamp the pad and ad a star, am I good?
Re: VIN Stamping: MYTH or FACT [Re: pacifica] #342590
03/28/11 02:38 AM
03/28/11 02:38 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
2 stars. 1 for effort.
Chris from New Jersey
Re: VIN Stamping: MYTH or FACT [Re: JohnRR] #342591
03/28/11 09:45 AM
03/28/11 09:45 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Yea, I should have thought of that. Old age...
Re: VIN Stamping: MYTH or FACT [Re: ph23vo] #342592
03/28/11 11:11 AM
03/28/11 11:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The idiot was probably the guy that repaired and replaced whatever was wrong and needed to change that E to an F ?
Re: VIN Stamping: MYTH or FACT [Re: pacifica] #342593
03/28/11 11:12 AM
03/28/11 11:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: VIN Stamping: MYTH or FACT [Re: JohnRR] #342594
03/28/11 05:36 PM
03/28/11 05:36 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
The strangest factory VIN stamping I've seen. This is out of my Charger that my dad bought new, so there's no doubt about it's originality.
Re: VIN Stamping: MYTH or FACT [Re: Paul Jacobs] #342595
03/28/11 05:37 PM
03/28/11 05:37 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
PAD
Re: VIN Stamping: MYTH or FACT [Re: Paul Jacobs] #342596
03/28/11 05:38 PM
03/28/11 05:38 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Some more REAL stuff.
