Re: Good starter that will work with an Indy Maxx block....
[Re: silverfish]
#335095
06/01/09 11:49 AM
06/01/09 11:49 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I used the Factory Mini starter on the almost same engine. Mine was 557 CID, which was a 4.44 bore x 4.5 stroke. Compression was measured at 15.5:1 which I ran with alky injection. No problems at all.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: silverfish]
#335096
06/01/09 12:20 PM
06/01/09 12:20 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Just an idea? Starter just a bit of? Not lined up with fly wheel? To much heat by the starter?
I don't think powermaster will be any better. The 440 source starters are just as good.
You could try the MSD starter, or the Meziere. If that doesn't work, then something isn't lined up right or it's a heat problem.
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#335097
06/01/09 12:25 PM
06/01/09 12:25 PM
Posts: 202 Barboursville, VA
belvedere383
Barboursville, VA
i have powermaster xs on a 13:1 500 inch motor, it seems to work awesome. The powermaster starters to me look alot beefier but who knows.
65' Belvedere
496'' Stroker Indy Heads
[Re: belvedere383]
#335098
06/01/09 12:31 PM
06/01/09 12:31 PM
I use a MSD starter on my Indy alloy motor, works great, also Meiserie works well..I had no luck with the powermaster or the factory stuff...
Post deleted by Defbob
[Re: silverfish]
#335100
06/01/09 02:15 PM
06/01/09 02:15 PM
#335101
06/01/09 05:50 PM
06/01/09 05:50 PM
MEZIERE TS 104,best starter you will ever buy hands down. those powermasters wont help you, mezieres spin like youve never seen a starter spin before. also double check your ring gear to bendix contact point and double check your timing.
#335102
06/01/09 05:56 PM
06/01/09 05:56 PM
Posts: 858 Oklahoma
silverfish
Oklahoma
is it bottoming out on full engagement? JW's also have been known to be off center and need alighment
I think that it is a JW so I will check all that real close this evening when I get home. How do you align them and get them correct if they are off?
[Re: silverfish]
#335103
06/01/09 09:55 PM
06/01/09 09:55 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Not all mini starters are made the same, check with a dealer. I do have a mini, works fine, but my dealer buddy picked out a specific one.
Also, an 80's 318 starter is 1/2 way between a mini and a 60's full size starter size wise.
Hope this helps.
8.30's @3400 lbs
[Re: Mike Swann]
#335104
06/01/09 10:59 PM
06/01/09 10:59 PM
Posts: 753 San Diego, CA
brktracr
super street
super street
San Diego, CA
I too was breaking the Mopar mini starters, went with a Powermaster XS and haven't had a problem in 5 years now. The Meziere starter is an very excellent piece also.
1.298 60 ft
6.001 1/8 mile
114 mph
9.52 1/4 mile
140.87 mph
@ 3110 lbs
[Re: silverfish]
#335107
06/02/09 12:20 AM
06/02/09 12:20 AM
[Re: silverfish]
#335108
06/02/09 12:35 AM
06/02/09 12:35 AM
Posts: 961 Carson City, Nevada
RobbMc
Carson City, Nevada
Ok I put the car on jackstands to check everything out. It is all lined up perfectly. The wear marks on the flywheel where the starter gear is making contact with it are just right also. What I found is just what I expected, the pinion is broken on the starter. You can take a screwdriver and just freewheel it both directions. Thats usually what happens to every one of them. I think I will try the Meziere or Powermaster now. One other thing....does it matter that I am using a Chevy/powerglide flywheel with a mopar starter? Just wondering if the teeth still line up correctly?? Its a JW flywheel with the adapter to bolt to my Mopar crank. Nothing out of the ordinary that anyone else uses when utilizing a powerglide but I thought I would ask to make sure....
Where is the best place to get a Meziere starter?
I'm not sure how that works. Chevy 153 and 168 tooth starter ring gears are 12/14 pitch and Mopar 130 and 143 tooth ring gears are 10 pitch. The pinion teeth are not compatible. Unless I am missing something here..........
#335109
06/02/09 09:07 AM
06/02/09 09:07 AM
Posts: 858 Oklahoma
silverfish
Oklahoma
Are you guys using a start retard? If so how much...10 or 20 degrees?
no and if you are throw it away it's the reason they are breaking. it causes kickbacks
Well I had a 20 degree retard programmed into it and with this last starter I changed it to a 10 degree retard. I have heard mixed opinions about this issue so I guess I will take the retard completely out now and see how that works for me. Thanks for the info.
[Re: hemiiroc]
#335111
06/02/09 02:46 PM
06/02/09 02:46 PM
Posts: 858 Oklahoma
silverfish
Oklahoma
Are you spinning the engine then hitting the ignition?
Not on this car. My other car is set up like that but this car still has the stock keyswitch in it. Is that harder or easier on the starter? I've always heard its easier on it but not really sure.
[Re: hemiiroc]
#335113
06/02/09 03:28 PM
06/02/09 03:28 PM
Posts: 858 Oklahoma
silverfish
Oklahoma
Much easier to start.
I agree with that for sure. I hope to be able to rewire the Cuda this winter to make it that way also. I don't know if that has contributed to my starter problems or not. I'm gonna order a Meziere, Powermater, or CSR this time...I just can't decide which one to get. There good and bad opinions about all of them.
